Xsspeed's 1988 Z31 Nissan Fairlady Z 200ZR 2+0
xsspeed
  • 4 months later...
  • 3 months later...
Back in August I went for a fang enjoying making poosts but then wamp wah. Started getting hot and steam from engine bay. I could see water and steam coming out under the intake manifold.
Got a ride home thanks to AA plus and left it in the garage while I went around Europe for a month
Finally did some further investigating yesterday and found it.
So much room under the nose...the condenser is bolted to the nose cone and you can only access the bolts by half pulling the nose off the car...3x2 bonnet stay ftw
Also great intake duct
Peekaboo
Twennydebt
Radiator is out and Ill get that checked and flushed if its worth it
Then do some fluids and aim to be at drag day
Disgust:
  • 8 months later...
Does anyone know where id get one of these easy enough in nz maybe a swept bend not a mitre. https://www.jegs.com/i/JEGS/555/511176/10002/-1
I played match the radiator hose at supercheap with @GuyWithAviators today. Got a VL rb30 bottom hose which is sweet engine end but with my V mount radiator under the nose cone I need to make an additional turn
I made some things, took me fucking ages cos im a noob
Because new radiator (300zr) is bigger than old radiator (200zr) - 50mm taller and different top mounts. Y u do dis nissan? /i gambled on 300zr being the same via rockauto
Using the existing mounts it would stick up
New:
Old:
So also had to cut and reweld some lower mounts. Now it fits inside the nose cone again
Dummy up of how the radiator cradles will work with mk1 prototype lol
  • Like 6
  • 1 year later...
