Is this sandblaster any good?
malarky
Are you talking about on a chassis or something you can't put in a booth? I had a supercheap handheld gun in a cabinet, never had any issues with it. IT was just a basic pistol + suction pipe setup. If you're doing it outside, then you'll want to have some respirator half mask or similar if using sand. I had some pink garnet in my cabinet as I don't think it's as bad for you as sand. But it was a sealed booth, so don't take my word on that.
tl;dr even basic sandblast tools work, it's just sand blown by air after all.
If you want a quality but basic unit then Syntech do one that's just a gun with a hose. You put the end of the hose into your bucket of garnet and sand away. I wouldn't go anywhere near using normal sand for blasting due to the dangers of silicosis. More info here:  https://www.cdc.gov/niosh/docs/92-102/
Use garnet which Syntech can supply you also. Comes in sacks in 3 different grades if I remember correctly. Let them know what you're doing and they can advise you on the correct grade.
http://www.syntechnz.com/
