Kieran Ebbett NZ 1974 Triumph 2.5 Pi and 1976 -77 2.5 TC/S
Hello all, I'm not new to oldschool but I haven't posted before. I have recently purchased a 1974 2.5 PI. (I'll try to add a few photos in as I go) sight unseen from Timaru no wof, no reg no worries?
Anyway I sorted a few obvious problems. Including a non functioning alternator, a new airel and a door mirror just off the top of my head. And then got it down to see what it needs for a wof. It came back needing both lower balljoints, an adjust on a wheel bearing and a small bit of rust which turned out to be nothing! As I write this I'm waiting for some bushes to arrive. The rust has been fixed, the wheel bearing has been adjusted and one new front strut insert shock thingy has been fitted. I have fitted the balljoints into some spare lower arms I had and am waiting for bushes to arrive so I can fit them along with new bushes (radius arm and lower balljoint arm ones to be exact). I decided not to be tight and replace them all at the same time as I was taking it all apart anyway.
I have also already got a white 1977 2500TC which has all the S goodies and even badges on. And she 1976 French blue TC which is being repaired body work wise and will be resprayed eventually.
I hope to keep you all up to date with what's going on with these cars etc.
I will also start a post over in the discussion area so we can all talk about it if you're that way inclined.
  • Like 7
  • 4 weeks later...
30490779194_833d2a9925_k.jpg20161002_125047 by Kieran Ebbett, on Flickr
The rest of these are all random, One is of when i met up with Blake in Feilding. One or two From Manfeild with a 2500 TC with a Rover V8 in and a photo of the seats Snoozin helped me get. Might be one of the Dolomite in there too
31197929261_990000c24b_k.jpg20161015_141635 by Kieran Ebbett, on Flickr
31312630255_98da5e048d_k.jpg20161112_171854(0) by Kieran Ebbett,on Flickr
31168582162_c0a5949898_z.jpg20161112_114616 by Kieran Ebbett, on Flickr
31197893331_d06c6e3ccc_z.jpg20161126_143126 by Kieran Ebbett, on Flickr
31312713945_a6c9b4e55b_z.jpg20161103_180426 by Kieran Ebbett, on Flickr
30505005823_0a1c54a6bc_z.jpg20161112_114621 by Kieran Ebbett, on Flickr
