BlownCorona Posted September 17, 2020 Share Posted September 17, 2020 shit that's going to be a large motor! i had in my head that those parts were the profile of the crankcase and that part housed the crank gear like a standard engine would have a timing gear case on the front of the block Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted September 18, 2020 Share Posted September 18, 2020 5 hours ago, BlownCorona said: shit that's going to be a large motor! i had in my head that those parts were the profile of the crankcase and that part housed the crank gear like a standard engine would have a timing gear case on the front of the block Yeah its pretty big. Banana for scale. Also mm for scale. Its about 1020mm long. About 700mm tall 6 2 Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted September 29, 2020 Share Posted September 29, 2020 The mandrel is spaced apart like that so that if we cant form it by hand and need to make hydraulic tooling theres some room to put it behind the rail. Ideally it would only be 100mm apart. Save some weight! 2 Quote Link to comment Share on other sites More sharing options...
anglia4 Posted September 29, 2020 Share Posted September 29, 2020 It looks awesome! Quote Link to comment Share on other sites More sharing options...
anglia4 Posted September 29, 2020 Share Posted September 29, 2020 what thickness is the chassis that you have to form over it? Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted September 29, 2020 Share Posted September 29, 2020 32 minutes ago, anglia4 said: what thickness is the chassis that you have to form over it? 4mm mild steel. Though they did them out of G350 by accident. So that may or may not suck. Hopefully they can replace them with mildsteel. Quote Link to comment Share on other sites More sharing options...
anglia4 Posted September 29, 2020 Share Posted September 29, 2020 I guess its a good thing if you are able to form it Quote Link to comment Share on other sites More sharing options...
M.H. Posted September 29, 2020 Share Posted September 29, 2020 58 minutes ago, Not-a-number said: 4mm mild steel. Though they did them out of G350 by accident. So that may or may not suck. Hopefully they can replace them with mildsteel. Whats wrong with using 350 as opposed to 250? Quote Link to comment Share on other sites More sharing options...
anglia4 Posted September 29, 2020 Share Posted September 29, 2020 Its higher tensile material. Nominally 350MPa yield strength as opposed to 250MPa. To form it over the mandrel you need to be able to "yield" it, so the higher tensile would need more force to bend to yield. @Not-a-number will you be heating it to form? 1 Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted September 29, 2020 Share Posted September 29, 2020 1 hour ago, 00quattro00 said: Whats wrong with using 350 as opposed to 250? Nothing, just that it will be harder to do by hand. 6 minutes ago, anglia4 said: Its higher tensile material. Nominally 350MPa yield strength as opposed to 250MPa. To form it over the mandrel you need to be able to "yield" it, so the higher tensile would need more force to bend to yield. @Not-a-number will you be heating it to form? Hopefully not but probably. Ive heard if it was G350 that would probably crack and distort it. Since it would be locally annealing. Quote Link to comment Share on other sites More sharing options...
dabuzz Posted October 11, 2020 Share Posted October 11, 2020 absolutely amazing build love seeing updates 1 Quote Link to comment Share on other sites More sharing options...
anglia4 Posted October 11, 2020 Share Posted October 11, 2020 What an eye opener... you're not an old barry at all 2 2 Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted October 11, 2020 Share Posted October 11, 2020 9 minutes ago, anglia4 said: What an eye opener... you're not an old barry at all Haha. Low 30s... In the shade. 2 Quote Link to comment Share on other sites More sharing options...
M.H. Posted October 11, 2020 Share Posted October 11, 2020 Is that tomato sauce in the bottle? 2 Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted October 11, 2020 Share Posted October 11, 2020 25 minutes ago, 00quattro00 said: Is that tomato sauce in the bottle? Ketchup* since im in America. *actually ceramic core paste 1 Quote Link to comment Share on other sites More sharing options...
IvyMike Posted October 15, 2020 Share Posted October 15, 2020 What resin do you use for your castings and at what ratios? The quality looks great. Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted October 16, 2020 Share Posted October 16, 2020 On 14/10/2020 at 22:36, IvyMike said: What resin do you use for your castings and at what ratios? The quality looks great. Techniset 6435 with catalyst 712. Its a 3 Part system. Part 1 + 2 = 1.8% of sand mass P3 = 3% of Part 1. Sand is #90 so quite fine. 3 part system works way better than the 2 part I used in NZ. Mixes really evenly with hardly any effort. 2 1 Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted November 12, 2020 Share Posted November 12, 2020 Ill do a timelapsy video for the Sump. What sort of stuff do you guys like to see in a video like the last one? 1 Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted November 26, 2020 Share Posted November 26, 2020 . 1 Quote Link to comment Share on other sites More sharing options...
Arifidyan Posted December 22, 2020 Share Posted December 22, 2020 On 16/10/2020 at 21:55, Not-a-number said: Techniset 6435 with catalyst 712. Its a 3 Part system. Part 1 + 2 = 1.8% of sand mass P3 = 3% of Part 1. Sand is #90 so quite fine. 3 part system works way better than the 2 part I used in NZ. Mixes really evenly with hardly any effort. Super cool! Can you reuse the sand after is has been used with the resin in it? can you give an example of the sand recycling process? #thumbsup 1 Quote Link to comment Share on other sites More sharing options...
