oldrx7 Posted November 27, 2018 Author Share Posted November 27, 2018 1 hour ago, dabuzz said: there are two different sizes for rx4/929 models, and not by much, put a vernier across the small end of the taper to compare - going by images (eyecrometer) you have the wrong ones Knowing my luck - sounds like you're right - I checked through catalogue's for year / model of 929/rx4, but often don't know until you go to fit them I guess Quote Link to comment Share on other sites More sharing options...
rivalrx Posted November 27, 2018 Share Posted November 27, 2018 I have the bloody wrong inner tie rods on my car. There is a difference 2mm at the thin part of the taper which causes a problem. Where did you get the tie rods from? Quote Link to comment Share on other sites More sharing options...
oldrx7 Posted November 27, 2018 Author Share Posted November 27, 2018 1 hour ago, rivalrx said: I have the bloody wrong inner tie rods on my car. There is a difference 2mm at the thin part of the taper which causes a problem. Where did you get the tie rods from? I got these off a shop in Aussie - Ringwood auto parts https://www.ebay.com.au/itm/NEW-SET-OF-4-FRONT-STEERING-TIE-ROD-ENDS-SUIT-MAZDA-RX3-RX4-808-929/331735510264?_trkparms=aid%3D333200%26algo%3DCOMP.MBE%26ao%3D1%26asc%3D20180228161002%26meid%3D86e679b024de4f85acfc25ffd29f01ed%26pid%3D100008%26rk%3D2%26rkt%3D8%26sd%3D152828666897%26itm%3D331735510264&_trksid=p2047675.c100008.m2219 Was half the price of most nz shops but of course that doesn’t matter now that they’re wrong Could always look at trying to machine these a bit to suit, but have found a local shop with some in stock so will take in the old ones to compare either tomorrow or Thursday and see 1 Quote Link to comment Share on other sites More sharing options...
