be4ver Posted May 2, 2016 Share Posted May 2, 2016 Have got a torsen from an altezza that I want to put into my gx61. Can anyone tell me if anything needs modified etc? Or will it bolt straight in if I change the crown wheel off the open head? I want to use the car for a motorkahana in the weekend so I don't really want to pull it all apart if its not going to be real straight forward. Thanks! Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 2, 2016 Share Posted May 2, 2016 If you already have a F series diff in this car then you just swap the LSD centre over the alteazza gears are useless too you. Only thing special you need is the ability to set the diff up again in the right position when you put it back together Quote Link to comment Share on other sites More sharing options...
Roman Posted May 2, 2016 Share Posted May 2, 2016 I want to use the car for a motorkahana in the weekend so I don't really want to pull it all apart if its not going to be real straight forward. Then wait until after... You're dealing with 30+ year old parts so something unexpected will happen. If you just swap the guts over, your contact patch on the gears might not be correct anymore. In which case it's a bit more tricky to setup from there. So long as you leave the pinion gear completely untouched, and use the same bearings you might be right. Just dont back off the nut on the pinion flange EVER unless you're replacing the crush tube etc inside. Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 3, 2016 Share Posted May 3, 2016 Agree with Roman. You will most likely need a couple shims to centre it as the old F series IRS housings don't have adjustment like some other Toyota diffs. Wait until you have a few weeks the car can be off the road, it's best to take your time. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted May 3, 2016 Share Posted May 3, 2016 thats not the OS spirit dave and speeno lol Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 3, 2016 Share Posted May 3, 2016 No offence but if you have to ask on the forum and have a short deadline chances are you are not prepared to do this. Wait until you can make a few mistakes and not miss the event completely. You can download the factory manuals for a few 80's Toyotas that have the procedure for setting up these diffs. Get that and read it, if you can follow that procedure and think you can do it, go ahead. Quote Link to comment Share on other sites More sharing options...
be4ver Posted May 3, 2016 Author Share Posted May 3, 2016 Thanks for the replys guys. I wont be missing out on the event,I was planning on doing it in my lancer anyway. I just had a last minute thought (as always) about putting this diff in the gx and using that. And if it's worth the bother to spend some evenings on it before the weekend. If it doesn't work out then I'll just use my lancer. I'll give it a go I think 2 Quote Link to comment Share on other sites More sharing options...
