tortron Posted October 11, 2020 Share Posted October 11, 2020 I think the Webber might be a bit over jetted? 2 2 3 Quote Link to comment Share on other sites More sharing options...
chris r Posted October 11, 2020 Author Share Posted October 11, 2020 Might explain why it was a bit quieter than usual Quote Link to comment Share on other sites More sharing options...
tortron Posted October 13, 2020 Share Posted October 13, 2020 windscreen man has a lot of imps and a too low hunter wags and had a minor just like mine, except not 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted October 13, 2020 Author Share Posted October 13, 2020 4 minutes ago, tortron said: windscreen man has a lot of imps and a too low hunter wags and had a minor just like mine, except not His minor runs? Quote Link to comment Share on other sites More sharing options...
tortron Posted October 13, 2020 Share Posted October 13, 2020 yes, but not uphill Quote Link to comment Share on other sites More sharing options...
chris r Posted October 13, 2020 Author Share Posted October 13, 2020 Did they ever run up hill? 1 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted January 27, 2021 Share Posted January 27, 2021 https://www.trademe.co.nz/a/motors/car-parts-accessories/holden/exterior/listing/2951475689?bof=mmlx2Oxd 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted April 18, 2021 Share Posted April 18, 2021 Oh man, I had a catch up. Saw the rust and was like omg... And then super happy to see you fix it and get it all back together ASAP. Well done! 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted April 19, 2021 Share Posted April 19, 2021 rust aint shit nathan 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted April 26, 2021 Share Posted April 26, 2021 nother webber if yours is still no good https://www.trademe.co.nz/a/motors/car-parts-accessories/performance/carburation-induction/listing/3070038990?bof=i6Ca9FvP 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted April 26, 2021 Author Share Posted April 26, 2021 Probably should get around to putting the other weber back on Quote Link to comment Share on other sites More sharing options...
tortron Posted April 26, 2021 Share Posted April 26, 2021 Where theres a webber, theres a snag m8 1 Quote Link to comment Share on other sites More sharing options...
Raizer Posted June 6, 2023 Share Posted June 6, 2023 @chris r had a fancy Weber adapter CNC machined, but somewhere along the way it gained an extra 10mm in the base. So I made it a lot less fancy but a lot more functional. I haven't welded alloy in way too long/needed to preheat more, but it's solid! 8 1 Quote Link to comment Share on other sites More sharing options...
Popular Post Raizer Posted June 10, 2023 Popular Post Share Posted June 10, 2023 Even less pretty, but still hopefully functional. TBI to Holley adapter made from a couple scrap bits of 12mm alloy plate. 10 Quote Link to comment Share on other sites More sharing options...
chris r Posted June 28, 2023 Author Share Posted June 28, 2023 Rough idea I have for idle control is a inline style motor off a bmw/euro thing. Should be able to hide a hole in the manifold and air cleaner base fairly easy. I know port injection is much better overall but for learning/playing around with tuning the single point/throttle body will be good enough to get started Quote Link to comment Share on other sites More sharing options...
vk327 Posted June 29, 2023 Share Posted June 29, 2023 2002 ford mustang idle valve is easy to fit and works well https://www.rockauto.com/en/catalog/ford,2002,mustang,4.6l+v8,1385670,fuel+&+air,idle+air+control+(iac)+valve,6072 3 Quote Link to comment Share on other sites More sharing options...
chris r Posted June 30, 2023 Author Share Posted June 30, 2023 4 hours ago, vk327 said: 2002 ford mustang idle valve is easy to fit and works well https://www.rockauto.com/en/catalog/ford,2002,mustang,4.6l+v8,1385670,fuel+&+air,idle+air+control+(iac)+valve,6072 Thanks! I was hoping something like that existed Quote Link to comment Share on other sites More sharing options...
