Poor thing got a hiding going up the Bombay hill. Had to pin it in third and throw my mechanical sympathy away for a little while
  • Like 8
  • Sad 1
  • Replies 150
I've got a lead on a healthy high compression 173 which barry said has some trick head work and was built for boost, might be a easier option than pulling and refreshing 202 and putting the cam etc in
  • Sad 1
Just leaving this here so I can find it again. https://spareto.com/products/valeo-clutch-kit/835013
On of the Facebook om60x groups a  person had a recommendation for a sprinter single mass conversion clutch kit for a 'upgrade' if the dual mass shits the bed.
Yes the dual mass flywheels are much smoother and less vibration but it's not a in a Mercedes any more,its a old Holden and it was never overly smooth or refined (and the manual musso have a solid flywheel but with a t5 behind them)
I've sand blasted the rust off the flywheel and it looks less bad so it'll crash around the work van for a while, as I said earlier I'll be a cheapskate and just replace the pressure plate and friction disc and see how things go
  • Like 9
So after more digging and hours of cross referencing part numbers I'm 90% sure the gearbox I have needs a single mass flywheel.
Good as its going to last forever, bad is it's pretty much rocking horse shit to find.
I've found a new mb140 van /ssangyong van flywheel in Australia but it's about 1200 landed. I've emailed a place to see if there's a second hand one in nz but I'm not super hopeful
Mercedes Lego is good that the inline engines from 80s- 90s ish are all the same bellhousing and flywheel bolt pattern. There are quite a few clutch options in various diameters but it appears they all are the same input shaft spline, just have to match the clutch to the flywheel
If you check the Wreckers in Melbourne I can see if I can go grab one for you, I think ive still got luggage allowance for when I fly over to Wellington on the 16th or I can get a freight quote.
Just need to know what im grabbing :)
Jollys you pull as an example but there is a pickapart here too
Thanks will have a look, I've found a second hand listing in Germany with a weight of 15kg so may not be suitcase friendly. From what I've seen everything sprinter is dual mass. Maybe the early Tn/T1 vans would have a single mass but they are most likely gone by now
1 hour ago, CaMpylobacter said:
tried spareto?
That was my first port of call.
After market makes heaps of replacement dual mass flywheels. Or valeo do a single mass conversion flywheel kit but that matches the dual mass dimensions so I'd need to space the bellhousing for that to work.
From what I've found and other forum posts in a similar position it seems genuine new or used merc (or ssangyong/mercedes van thing) is the option for the single mass
The irony is the first gearbox I got was for a dual mass but had no speedo cable output so I would have had to muck around with sensors and controllers which may have ended up cheaper than finding a unicorn poo flywheel
3 hours ago, shrike said:
@chris r I wonder what the cost of a custom flywheel would be?
https://www.precisionengltd.co.nz I believe can do them, and I think when I last spoke with Barry at MRP he could also get custom ones made.
I did have that thought tbh, But with my limited accurate measuring tools and even more limited measuring abilities I think that'd be a painful exercise for all involved
The ssangyong/mercedes van flywheel looks more appealing than the mercedes option. Both appear to be the smaller 8.5" clutch but at this point any clutch will do (and rock auto have a clutch kit to suit 190 for $200 at the moment)
and according to this random german site (yes I'm clutching at straws) it is a cross refrence to the merc flywheel
190flywheel.png.242bab46c851f7f0358ae0c71db296ac.pngssangyongflywheel.png.3912ce4e4a412f2dff41ba26a27d3a16.png
Went out to the carport and had a measure /look
Assuming the ring gear needs to be in the same position in auto and manual I used it as a reference point
About 6mm of ring gear poking out past the bellhousing face.
Assembled the dual mass (om606?) flywheel and clutch. Pushed it in and held it by hand
The ring gear is fully exposed past the edge of the bell.
If my maths is mathing I should have 6mm of ring gear inside the gearbox bellhousing and I don't have that with the dual mass.
How much will a pressure plate deflect without reducing clamping force?
And how much throw will it need to release?
My gut feeling is that the dual mass sticks out too much (atleast 6mm)
Interestingly the spare om662 musso motor I have has a pilot bearing in the crank. The dual mass has the pilot bearing in the flywheel. That tells me that there is a musso single mass flywheel attached to a turbo musso/om662 so I'm looking for the poop or two unicorns now so it's easier right?
Could you machine 6mm off the flywheel?
Maybe my gut feeling is it may need more than 6mm taken off as the pressure plate fingers are currently rammed against the release Bearing which is pushed against the gearbox casing. I'm thinking it'll want a tiny bit of free space and not be bound up all the time
Ideally the current dual mass needs to be replaced as it's been used and can't be machined. that then means I could get a conversion flywheel/clutch kit but it would be a gamble if that would have enough material to machine off to work with this gearbox.
The whole dual to single mass conversion kit ends up being a similar cost landed to the unicorn poo flywheel and I'd have to get it machined /hope like fuck it could be machined. So for practically the same money I may as well just get the (hopefully) correct single mass flywheel off the bat
