Adoom's Husqvarna Ride-on
Adoom
  • Replies 51
timelapse video please :)
Best I can do.
This is where it stopped the second time. The engine starting "hunting" and then stopped. I pulled the pipe off the pump and cranked the engine, pump seems to work...
I pulled the fuel pump apart and the diaphragms looked okay... So I put it back together and it would run kind of okay, but I had to have the choke out all the way. And the engine was "hunting". It would just die if I put the choke in.
I suspect some dirt in the fuel line/carb. I did replace some fuel hose, but just blew out the inline mesh filter with compressed air instead of replacing it. I'll get a new filter.
I made a bonnet, to try cut down some noise, or at least reflect it towards the ground.
I made it from rimu. LOL. The awesome finish is from the flap disc on the grinder.
And on concrete, it cuts down almost, possibly, absolutely NO noise at all. WINNING!
I finally got my a into g and put the deck back on after sharpening up the blades, tracking down a missing link and spring that connects the brakes..
Got about 5 mins into the job then found it kept dying when I had the deck down and put it into reverse. Noticed a bit wiring running to switch on the selector. Maybe I'm not supposed to mow in reverse? fuck you switch you get unplugged.
another 5 mins and 1st drive belt goes ping. Fucker.
Didn't look great when I bought it and pretty sure more smoke was coming from belt than engine. (which is none cos it's ace. thanks Guypie.)
