Bearded Baldy Posted October 4 Posted October 4 Out of curiosity how thick can these go. As i might need a 10mm rocker cover spacer cut. Buying ex aussie gives me the shits lol Quote
ThePog Posted October 4 Posted October 4 23 minutes ago, Bearded Baldy said: Out of curiosity how thick can these go. As i might need a 10mm rocker cover spacer cut. Buying ex aussie gives me the shits lol Its mostly about the tooling, that perimeter cut is 5mm deep but I did it in 1mm imcrements cos I was scared. So 10mm would be doable. Quote
Stu Posted October 5 Posted October 5 We use Cimlube 703H via a mister when cutting ali and it works really well without creating too much of a mess. It was available through Mytools but they've since closed their doors - a quick search now shows TradeTools sell it although 20ltr container which is a bit OTT unless you are cutting ali all the time. I can decant a small amount off if you guys want to try some. After quite a bit of trial and error we have settled on some tooling from alix which work as well as if not better than tooling available from Tungsten and Tool etc who are very expensive by comparison. We have also got some 6mm tools I could spare one or two of if you wanted to try some. We can cut up to 30mm if you get stuck. 3 1 Quote
Thphantum Posted October 5 Posted October 5 1 hour ago, Bearded Baldy said: Out of curiosity how thick can these go. As i might need a 10mm rocker cover spacer cut. Buying ex aussie gives me the shits lol Got a mate in rotorua with a Lazer cutter might be a good option? He's currently working on a 10mm alloy plate head board for my ute with custom designs cut into it. 1 Quote
Bearded Baldy Posted October 5 Posted October 5 2 hours ago, Thphantum said: Got a mate in rotorua with a Lazer cutter might be a good option? He's currently working on a 10mm alloy plate head board for my ute with custom designs cut into it. Send me his details please. Vegas is close and handy. Of course i haven't started drawing up the spacer yet. Have the rocker cover just sitting there doing nothing on a spare engine. Need to get off my arse. Quote
NickJ Posted October 5 Posted October 5 6 hours ago, ThePog said: Its mostly about the tooling, that perimeter cut is 5mm deep but I did it in 1mm imcrements cos I was scared. So 10mm would be doable. You'll do 10mm easy on your machine, recipe i've found to work is single flute cutter, step down no more than 1/2D and CRC mist. The problem i've found with deeper cuts is without flood coolant to flush the chip, recutting or rubbing risks galling up then snapping the tool. Without lube is totally possible, its just easy insurance at preventing the chip galling up Quote
ThePog Posted October 5 Posted October 5 14 minutes ago, NickJ said: You'll do 10mm easy on your machine, recipe i've found to work is single flute cutter, step down no more than 1/2D and CRC mist. The problem i've found with deeper cuts is without flood coolant to flush the chip, recutting or rubbing risks galling up then snapping the tool. Without lube is totally possible, its just easy insurance at preventing the chip galling up I am not too sure about the misting as the spoilboard is mdf and I am guessing it will mess with that... maybe I can screw some acm down to protect it. although I am currently printing a hood that hooks up to the vac cleaner that should suck a lot of it out. I'll experiment some more probably. Quote
NickJ Posted October 5 Posted October 5 yeah the mdf soaks it up, I usually screw the ali to a scrap sheet to protect the main table Iso alcohol works well too for no mess if your insurance is robust Quote
Popular Post 63Ragtop Posted October 12 Popular Post Posted October 12 I been wanting to build a wee work/welding table for awhile now, the main reason is to have home for my two cheap wee welders to live, as the power is in the one spot, the generic trolley was in the way, the cables were always on the ground and would jam the wheels when I moved it, so... I found a GC on marketplace that was a lazercutter in his shed, got this plate cut, 900x600, plus 40mm strips. Got some 40mm for legs. Made some feet. Not part of the original plan, but thought these old drawer would be good to keep welding stuff in. Made less room for the welders so I removed that big plastic handles off the top. Found this thick black plate for the bottle to sit on, fabbed a big hook to secure the top, made another hook for the torches, used the off cuts from the last project for shelves. Pretty happy with that! Stuck on so old wheels I had, painted the frame with penitrol, done. 28 Quote
Popular Post chris r Posted October 26 Popular Post Posted October 26 Learned some basic blacksmithing and made some hooks today 12 Quote
Popular Post SOHC Posted October 28 Popular Post Posted October 28 Made this with some old junk, it works extremely well, it was intended for a pisstake and I dont believe in dodgy crap. 12 3 2 Quote
tortron Posted October 28 Posted October 28 Seems more robust than those pruning pole chainsaws 1 1 Quote
Popular Post SOHC Posted October 28 Popular Post Posted October 28 On my Facebook there is a video of it going, it is better than the scissors I had on before 2 11 Quote
RUNAMUCK Posted October 28 Posted October 28 11 hours ago, Alfashark said: @RUNAMUCK Rudi's speaking your language... One can never achieve absolute genius without a touch of madness..... 5 1 Quote
