sheepers Posted May 7 Posted May 7 Fuck I should add, One of the main goals for this shed build is to keep the noise down. The generator is sold as a "silent" generator. Yea, na. It is fucking loud. like, FUCKING loud. It's supposed to be 70db at 7m. No, it's closer to 85db at 12m Anywho, long story short I've been measuring noise levels at the fence line so I can gauge if the neighbours will be able to hear it or not. my goal was to get it to 45db at the fence. Started out at 68db, after noise insulation, a couple of false walls and a way better muffler on the zorst we're down to 55db at the fence. Still got a couple of things to do that will make it louder (need to cut in some extraction fans in the walls) and quieter (doors still don't close tight so there's air gaps all around ) so we'll see where we end up 9 Quote
Popular Post AllTorque Posted May 7 Popular Post Posted May 7 2 hours ago, sheepers said: Installed. 6 11 Quote
chris r Posted May 7 Posted May 7 Stick the pipe up with a tractor flap on top. Noise will then point 'up' to the sky and may be quieter /s Shed looks lush and I'm jealous 2 Quote
Vintage Grumble Posted May 8 Posted May 8 17 hours ago, AllTorque said: Lols, made me think of, 2 1 Quote
Muncie Posted May 10 Posted May 10 Gave the work bench a bit of fresh board today as my PCM programming has gotten a bit busier (successful too) built a new interface for my holden v6 flash PCM'S as my old one was cobbled together used computer bits and when I measured all the connections it was bloody terrible im surprised it worked at all. Big upgrade from old setup. V2 setup. Ive got same setup now for doing LS P01 and P59 PCM'S. Lab PSU is handy as for all kinds of things too. Smallest change but biggest changer of success was mounting the PCM In the original bracket from car while flashing if you bump a cable or work bench it can brick the PCM, locked the bracket its way less worries I need to find some nice pine or something to screw that to. 4 Quote
Muncie Posted May 10 Posted May 10 On 07/05/2026 at 17:05, sheepers said: Fuck I should add, One of the main goals for this shed build is to keep the noise down. The generator is sold as a "silent" generator. Yea, na. It is fucking loud. like, FUCKING loud. It's supposed to be 70db at 7m. No, it's closer to 85db at 12m Anywho, long story short I've been measuring noise levels at the fence line so I can gauge if the neighbours will be able to hear it or not. my goal was to get it to 45db at the fence. Started out at 68db, after noise insulation, a couple of false walls and a way better muffler on the zorst we're down to 55db at the fence. Still got a couple of things to do that will make it louder (need to cut in some extraction fans in the walls) and quieter (doors still don't close tight so there's air gaps all around ) so we'll see where we end up Considered sending that outlet into a water bath through some perf tube? Water is amazing for sound suppression (Actual rocket science) jealous of the shed by the way. 2 Quote
igor Posted May 17 Posted May 17 Got a hang on the wall style electric heater which has somehow parted company with its mounting brackets so I found some things and made a thing. Pretty sure the yellow foot piece is from a long since disused or repurposed work lamp. The steel straps which have been hanging in the shed here for decades are almost certainly power pole crossarm stays. The two bolts fastening the heater body to the upstand are spares that came with my new composting toilet. 3 Quote
Ned Posted May 17 Posted May 17 On 07/05/2026 at 17:05, sheepers said: Fuck I should add, One of the main goals for this shed build is to keep the noise down. The generator is sold as a "silent" generator. Yea, na. It is fucking loud. like, FUCKING loud. It's supposed to be 70db at 7m. No, it's closer to 85db at 12m Anywho, long story short I've been measuring noise levels at the fence line so I can gauge if the neighbours will be able to hear it or not. my goal was to get it to 45db at the fence. Started out at 68db, after noise insulation, a couple of false walls and a way better muffler on the zorst we're down to 55db at the fence. Still got a couple of things to do that will make it louder (need to cut in some extraction fans in the walls) and quieter (doors still don't close tight so there's air gaps all around ) so we'll see where we end up Can i ask how much power it can provide and how it won over solar/battery in your situation? 2 Quote
Popular Post Bearded Baldy Posted May 28 Popular Post Posted May 28 Brother gave his old site radio the other day, with a buggered volume switch and no antenna. In standard builder condition covered in shit. Pulled it apart this arvo, desoldered the volume knob and pried the tabs open. And promptly realising my fingers are not designed for this sort of caper, dropped all the bits off the edge of the table and onto the floor. Cleaned and rebent the contacts then put it back together for a test run. Jammed a screwdriver in the antenna hole and it all works mint. So now all i have to do is order an antenna and i have a camping/boating whatevering stereo. Fuck yeah. 12 Quote
igor Posted May 28 Posted May 28 4 hours ago, Bearded Baldy said: Jammed a screwdriver in the antenna hole and it all works mint. So now all i have to do is order an antenna Coathanger mate. It'll work a treat. 2 Quote
Bearded Baldy Posted May 28 Posted May 28 My old throwaround i drove a screw into and attached a length of wire to hang on a branch/fence etc. Worked well too. But for the cost of 20 bucks plus shipping, i will go for the proper fold away antenna this time. 1 Quote
Bearded Baldy Posted May 28 Posted May 28 Interestingly, did ya'll know the te reo word for antenna/aerial is kotunga? Not really, but that joke was funny as fuck when one of the uncles told us kids 30 years ago. 4 2 Quote
Popular Post lowlancer Posted May 30 Popular Post Posted May 30 Working through the window hardware in my place. Pretty happy with the results. Phosphoric acid, watered down a bit and a soft metal brush bring it back. Paint gets the stripper treatment as wire brush wheel is too harsh. 19 1 Quote
Yowzer Posted May 30 Posted May 30 Noice. I gotta do all mine one day since they've all suffered the landlord special.. 1 Quote
lowlancer Posted May 30 Posted May 30 1 hour ago, Yowzer said: Noice. I gotta do all mine one day since they've all suffered the landlord special.. Once the paint is off, it's super-fast to sort. But any keint that paints hardware is reserved a special place in hell 5 1 Quote
Popular Post Vintage Grumble Posted June 7 Popular Post Posted June 7 My million dollar idea, I give you the Notch buddy HD Pro V1 Scrap Edition Plus, Benefits include but are not limited too: Perfect notch, every time. No need to change your skill saw back and forth from a full cut to 25mm depth over and over again. Unable to over cut. Shit tons faster due to not having to adjust skilly, no measuring, and only two cuts vs shit tons + chiseling/grinding. Less mess, rather than piles of thin wood wafers you just have one 100x100x25mm bit of wood, which can be used for other projects or thrown at cats. It seems my genius knows no bounds. Regards, V "retiring a millionaire due to this amazing idea" G 15 Quote
Thousand Dollar Supercar Posted June 8 Posted June 8 On 30/05/2026 at 18:34, lowlancer said: Working through the window hardware in my place. Pretty happy with the results. Phosphoric acid, watered down a bit and a soft metal brush bring it back. Paint gets the stripper treatment as wire brush wheel is too harsh. I have the exact same ones as those, and I've polished some of them on a buffing wheel or by hand. I get worse results and it takes me longer. Where do you get the acid? Are you going to coat the metal with something to prevent it tarnishing again? Quote
