tortron Posted July 19, 2025 Posted July 19, 2025 i believe machineries handbook refers to that as a 'Japseye' 1 7 Quote
Popular Post 63Ragtop Posted July 21, 2025 Popular Post Posted July 21, 2025 Father in-law asked me if I could fix his numberplate light off his 1953 Ford Prefect. Some Barry had given him piece of 2mm acrylic but he reckoned a old coke bottle works better. From when tail lights were glass. Stripped it down, blasted it clean, primed and painted it. Cut out a seal for the clean glass. Found some thin frosted plastic sheet. Only problem is now it's the nicest thing on the car! 22 1 3 Quote
Popular Post 63Ragtop Posted July 24, 2025 Popular Post Posted July 24, 2025 Fuck you sistema and your shitty little clips. 9 3 18 Quote
Popular Post SOHC Posted July 25, 2025 Popular Post Posted July 25, 2025 I made a Kukri, the long curved one and a British jungle knife, the round one and some more clevers 21 Quote
h4nd Posted July 25, 2025 Author Posted July 25, 2025 Was cobbling up an RF field strength meter, so blobbed this up: but it was deaf as a post. I figured out that the junk shop meter is open circuit. I guess someone put more than 100uA through it at some point I dragged out the microscope, but I couldn't see any burst wires on the coil, Though at 0.063mm, I'd be unlikely to be able to repair it edit: amusingly, it later looked like the steel spring had been cooked, the 0.063mm wire copper wire outlasted it! 8 Quote
Popular Post tortron Posted August 17, 2025 Popular Post Posted August 17, 2025 man why would anyone do drugs when you could make wooden handles on a lathe 17 Quote
Popular Post tortron Posted August 17, 2025 Popular Post Posted August 17, 2025 was there a woodworking tools thread anyway for $2 i felt there might be something decent under this santas workshop display piece 15 minutes with wire wheel, a couple grades of sandpaper, and some penetrol on a grey scotchpad unfortunately someone had gone all over the blade with a file for some reason (but not the still kinda sharp tip? paint keying i guess), so theres no makers stamp. i could probably bring it back with the stuff i use for ground out motorcycle frame numbers. will tidy the steel up a bit and put it back to work without thinking too much on it 13 Quote
Popular Post SOHC Posted August 19, 2025 Popular Post Posted August 19, 2025 Reclaimed reinforcing steel 26 Quote
Popular Post SOHC Posted August 24, 2025 Popular Post Posted August 24, 2025 New gas forge almost done, all that plate I found, its 3/8" and 1/2" so its super heavy 18 Quote
SOHC Posted August 24, 2025 Posted August 24, 2025 3 hours ago, h4nd said: Nice, how you gonna insulate it? I am going to use that 50mm ceramic fiber board and a layer of high temperature refractory cement in the bottom and a layer of board in the roof and then a layer of Kawool under the arched roof cover. actually thinking about it someone gave me some of the 25mm board. 4 Quote
Popular Post Bearded Baldy Posted August 30, 2025 Popular Post Posted August 30, 2025 Have been learning cad to do car related activities. First off the screen is this winch mount for my cruiser. After lots of mistakes and remeasures, i sent it off to the local metalshop and got the part yesterday. Gave it a quick etch prime and some satin black before i left work for the day. Spent today fitting it and trimming the bumper/wiring the winch up. Turned out mint i reckon. 30 1 Quote
Popular Post h4nd Posted September 2, 2025 Author Popular Post Posted September 2, 2025 Prius replacement lamp, goes from 8W to about 0.25 for the same light, so more time before dome lamp does the 12V battery in. Works perfectly, except... ... except I screwed up the measuring, and it's about 3mm too short. LOL. I'll pad it out with nickel strips 10 1 Quote
h4nd Posted September 5, 2025 Author Posted September 5, 2025 From V0 to V1, works and fits now. I mean, it's not rocket-appliances 8 Quote
Popular Post h4nd Posted September 11, 2025 Author Popular Post Posted September 11, 2025 I'm glad I used the bigger size of the ol' 103, so I could gob another one on here It's a board for monitoring nature thingies, and someone's hiding under it... 11 Quote
yoeddynz Posted September 21, 2025 Posted September 21, 2025 On 17/08/2025 at 12:31, tortron said: man why would anyone do drugs when you could make wooden handles on a lathe why not do both? 2 Quote
Popular Post h4nd Posted September 22, 2025 Author Popular Post Posted September 22, 2025 My syringe of lead solder paste arrived with a broken plunger. This did for the 1st day But it took me a couple of days to mull over a better solution Sustainable, reusable and an excuse to get/make a wee wood lathe 12 2 Quote
h4nd Posted September 22, 2025 Author Posted September 22, 2025 So I used that to make an updated version of a 'Solar Engine' - saves solar up in a cap, turns on for a moment when there's a worthwhile store of energy (think cat toy motor, enviro monitor etc) 5 2 Quote
