h4nd
  • Replies 1.3k
Fitted the bench top with 4 coach bolts on the corners. I also construction adhesived the rest down, but it didn't hold on the front left (there's a bit of tension here so I will probably throw another couple of bolts through on each side
IMG_20220809_095924_edit_174253682669244.thumb.jpg.42dca2d39a2c6019da50a87e6619aa0f.jpg
Also fitted bottle opener
Long overdue carving.
This COVID 19 pandemic has allowed me to take a bit of time to create a Tiki Racer garden ornament.
Inspired by Mr Tiki, nd a toy I bought t a boot fair years go.
8D7C5215-254A-4CAC-BEFD-20B571DB2FFD_zps
So I went down to my -lie of blocks.
4159DF1B-784C-426F-87B7-8367088DAA21_zps
Pulled a special one out/
783136A1-67B3-4283-B387-C84CFE5336E0_zps
Basic design
D4A98F40-FD7A-4F7B-A187-5F7D21C3B8F8_zps
Excess cut away.
978EB72F-AF04-4941-AEB0-CCBFD1FE4A09_zps
Of course cutting this part between the wheels will be interesting
90EF9B22-6F0C-490B-B5A2-AE732B7C52F7_zps
Baby steps.
EE02C56D-9AB5-4C78-9206-785DE34063B4_zps
Seat cut out.
E33ED44F-8CD1-4159-A4EA-727944DB23CB_zps
Quick prototype Tiki driver from an off cut.
0AEFE094-D782-4B57-8A91-5CEAC95441CE_zps
Shaped.
5FDC5341-BA46-410E-BB2C-B2EDECB9272D_zps
And in place.
DE4DD0A1-C03C-4227-9054-D7A2969D30B9_zps
At this point I come inside.
Tomorrow the hard part starts, carving and defining the wheels, recessing the drivers cab and seat.
Plus getting the front and rear curves just right.
Later.
Carried on tonight, doing the sides.
Original plan was to do lattice work sides, but decided to keep it very plain, so as not to detract from the front detail that I finished as well tonight.
http://i294.photobucket.com/albums/mm90/niknakpix/cross10_zps50315d72.jpg
Side details completed.
http://i294.photobucket.com/albums/mm90/niknakpix/cross11_zps1c20ad4e.jpg
http://i294.photobucket.com/albums/mm90/niknakpix/cross12_zps8a5ea886.jpg
Altogether now.
http://i294.photobucket.com/albums/mm90/niknakpix/cross13_zpsea1e5e79.jpg
Next up will be doing Nicola's birth year in Roman numerals across the back.
MCMLXIV
Then I need to keep my mouth shut till the 5th Feb.
Carried on tonight after work.
Roman Numerals for 1964 pencil drawn, but as you can see, freehand left some space, so I just freehand carved over the pencil.
http://i294.photobucket.com/albums/mm90/niknakpix/cross15_zps37cdfce1.jpg
http://i294.photobucket.com/albums/mm90/niknakpix/cross16_zps63994539.jpg
http://i294.photobucket.com/albums/mm90/niknakpix/cross17_zps4192bfc0.jpg
Back where we started, a before and after together.
http://i294.photobucket.com/albums/mm90/niknakpix/cross18_zpscd4f9727.jpg
Now to wait till the 5th February.....
Going to be difficult to keep quiet and not show her.
One more try.
Been tossing this idea around in my head since making the Celtic Cross.
Today, after helping a mate move some gym equipment (two trips) I came home, and got going with it as Nicola was out shopping.
First up, I drew up a rough robot to get placement and size on the block.
http://i294.photobucket.com/albums/mm90/niknakpix/rob1_zps1c346e10.jpg
Started by cutting away the excess.
http://i294.photobucket.com/albums/mm90/niknakpix/rob2_zpsbe1262b0.jpg
Hand held blade works a treat to get into tight spots.
http://i294.photobucket.com/albums/mm90/niknakpix/rob3_zpsbed5e7fd.jpg
http://i294.photobucket.com/albums/mm90/niknakpix/rob4_zpsd2501da3.jpg
Arms made thinner.
http://i294.photobucket.com/albums/mm90/niknakpix/rob5_zps26684abf.jpg
About four hours later my wife thinks I am a hero.
http://i294.photobucket.com/albums/mm90/niknakpix/rob6_zps1f744bd3.jpg
And in my opinion ...... enough of a reason to spend more than 4 hours in the garage sucking dust.
http://i294.photobucket.com/albums/mm90/niknakpix/rob7_zps7cfe9ae0.jpg
Ohhhh, and she still does not have the Celtic Cross.
Was going to buy one of these but thought, what I need is another project!
Salvaged some angle steel.
Some other junk.
Weldie weldie.
Welder was running like a bag of dick's, finished it off with my bros.
Seems to work. So this will allow the case to be open, receive the crank, cam etc. Then get sandwiched with the top half.
  • Like 7
Must be getting close to 20 years since I started this garden archway. I bent the hoops to an elliptic profile (which looks better than 1/2 round) in the early/mid 2000's then it sat around getting in the way like this until the first 2020 lockdown when I finished the lattice on the top
  • Like 8
