bigfoot Posted March 14, 2022 Share Posted March 14, 2022 5 hours ago, Raizer said: Anyone interested? Could be, depending on the price 1 Quote Link to comment Share on other sites More sharing options...
kicker Posted March 14, 2022 Share Posted March 14, 2022 Work looks good! Wish I had waited a bit longer when sorting my surge tank but I have already painstaking fabricated a hanger to fit in an off the shelf one. I might still need a larger coolant header tank so will keep you in mind 1 Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 14, 2022 Share Posted March 14, 2022 3 hours ago, bigfoot said: Could be, depending on the price Was thinking about $100, have a fair bit of time and consumables in them. That's pretty much in line with a smaller China spec baffled can etc. And yeah, can do with either M16 threaded or welded on barb fittings. 2 hours ago, kicker said: Work looks good! Wish I had waited a bit longer when sorting my surge tank but I have already painstaking fabricated a hanger to fit in an off the shelf one. I might still need a larger coolant header tank so will keep you in mind Hadn't even thought of surge tanks, looks like something I could do too! 1 Quote Link to comment Share on other sites More sharing options...
Popular Post flyingbrick Posted March 14, 2022 Popular Post Share Posted March 14, 2022 8 2 9 Quote Link to comment Share on other sites More sharing options...
63Ragtop Posted March 15, 2022 Share Posted March 15, 2022 On 14/03/2022 at 22:17, Raizer said: Was thinking about $100, have a fair bit of time and consumables in them. That's pretty much in line with a smaller China spec baffled can etc. And yeah, can do with either M16 threaded or welded on barb fittings. Hadn't even thought of surge tanks, looks like something I could do too! Would be keen as for that price. I'm going to be building my engine over winter so will be much later this year. Just simple welded on barbs etc, if I was to give you dimensions and shit could you make one to suit or is that a massive ballache? 1 Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 15, 2022 Share Posted March 15, 2022 1 hour ago, 63Ragtop said: Would be keen as for that price. I'm going to be building my engine over winter so will be much later this year. Just simple welded on barbs etc, if I was to give you dimensions and shit could you make one to suit or is that a massive ballache? Yeah I'd be keen to give it a go. Been doing 100x100 ones as I've got a full 5m length of it/dunno if I'm equipped or skilled enough to do sheet metal fabricated cans yet. 1 Quote Link to comment Share on other sites More sharing options...
63Ragtop Posted March 15, 2022 Share Posted March 15, 2022 All good bro, as I say no rush. 100mm will be a bit tight in the vw tiny engine bay, would be more like 70-75mm, but will have to mock up everything first to see. Thank you kindly. 1 Quote Link to comment Share on other sites More sharing options...
Raizer Posted March 15, 2022 Share Posted March 15, 2022 Looks like 75x75 should be easy enough for me to get my hands on, or rectangle tube opens up options too 1 Quote Link to comment Share on other sites More sharing options...
Popular Post GuyWithAviators Posted March 16, 2022 Popular Post Share Posted March 16, 2022 On 08/03/2022 at 18:46, Raizer said: Made a couple catch cans First one for @GuyWithAviators Thinking of making some more to sell, the 2 pictured are both 100x100x200mm, I made plate baffles etc Finally found time to install mine today. Top quality bit of kit! Big upgrade over the small one I had before, couldn’t drain it easily so it’d overflow etc. /wheezy +T TD27 life. Mounted to the inner guard with rivnuts and some spacers so the wiring loom can run behind it still. Drain pops out under the guard with a tap. So handy! See the mess from the old one Just needs some hose clamps and oil rated hose. But running rad overflow hose and no clamps hasn’t failed yet lol. 10/10 top notch thank thank @Raizer 10 Quote Link to comment Share on other sites More sharing options...
GuyWithAviators Posted March 16, 2022 Share Posted March 16, 2022 Drain tap and mess from old small one and then still found room for air horns. Good stuff 7 Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted March 16, 2022 Share Posted March 16, 2022 On 17/02/2022 at 17:43, SOHC said: Bloody handy, lifted the crank, motor mount and motor Fuck I rolled into work the other day and ine of the boys had made a similar setup and had a 350kg (dry) gearbox, with 18L of oil and a power take off and pump on it swinging from the thing. Sketchy hab 1 1 Quote Link to comment Share on other sites More sharing options...
felixx Posted April 17, 2022 Share Posted April 17, 2022 Hammo Can Quote Link to comment Share on other sites More sharing options...
Popular Post felixx Posted April 17, 2022 Popular Post Share Posted April 17, 2022 Has this inside.. 2m/70cm radio USB ports Battery and charging plug 22 Quote Link to comment Share on other sites More sharing options...
Popular Post MaxPower Posted May 8, 2022 Popular Post Share Posted May 8, 2022 Some of you may remember my welding skills from such episodes as welding a tow coupling on with half a damp rod on east cape ride. Today I put those skills to use and made a steel rack and wished I had done so a long time ago, am planning on putting a drop saw in the middle. 15 Quote Link to comment Share on other sites More sharing options...
GuyWithAviators Posted May 8, 2022 Share Posted May 8, 2022 2 minutes ago, MaxPower said: Some of you may remember my welding skills from such episodes as welding a tow coupling on with half a damp rod on east cape ride. Today I put those skills to use and made a steel rack and wished I had done so a long time ago, am planning on putting a drop saw in the middle. How many pairs of sunglasses did you wear? 1 4 Quote Link to comment Share on other sites More sharing options...
Bearded Baldy Posted May 14, 2022 Share Posted May 14, 2022 I like the rapid deployment tapemeasures. 1 1 Quote Link to comment Share on other sites More sharing options...
Popular Post ajg193 Posted May 16, 2022 Popular Post Share Posted May 16, 2022 I stopped by an electronics recycling place today and found a computer I have been looking for for a while. I then proceeded to upgrade it from a pentium three with 128mb of ram to an i5 with 32gb. Was good fun at pbtech when the guy couldn't figure out what I was doing. 23 2 Quote Link to comment Share on other sites More sharing options...
Popular Post Yowzer Posted May 16, 2022 Popular Post Share Posted May 16, 2022 Fuck yeah that'll play Doom real good 11 Quote Link to comment Share on other sites More sharing options...
HighLUX Posted May 16, 2022 Share Posted May 16, 2022 Perfect accompaniment https://www.trademe.co.nz/a/marketplace/gaming/pc-games/strategy-puzzle/listing/3596563464?bof=By9rxp2Y 2 1 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted May 17, 2022 Share Posted May 17, 2022 23 hours ago, HighLUX said: Perfect accompaniment https://www.trademe.co.nz/a/marketplace/gaming/pc-games/strategy-puzzle/listing/3596563464?bof=By9rxp2Y First need to track down a beige SATA optical drive Quote Link to comment Share on other sites More sharing options...
