chrisr's non automotive Nixie, electrical and random stuff barrying thread
Double post.
I'm tempted to sell my other factory made speakers and make more now...
I don't need more projects
  • Replies 199
Six ish years ago I bought a Analogue scope clock kit to do a crt clock. Have been too cheap to buy a crt so it's sat in my electronics barrying drawer for a while.
Figued I'd make a start on assembling the kit.
I'd managed to loose the instrucions so had to use the newer instrucions with different component identification on the silkscreen and try to match them up that way.
20260615_1733272.thumb.jpg.4bef16edf2f9a466fb16a6055f7637b3.jpg20260615_2030432.thumb.jpg.c68fc48512f990a5b040d5b8a7130024.jpg
Got that much figured out and emailed the seller on the off chance they still cheeked that email address the gc did and has replied with the correct instructions which is epic.
Will continue assembling the board when I'm in the mood
A community program I volunteer at had a oscilloscope turn up. They plugged it in and nothing happened.
I had a quick poke around with the multimeter look at it and it looks like it's got a sad 24v regulator chip on the power supply side, no other signs or smells of sadness so I may replace it and see if it comes back to life. In saying that I'm leaning towards salvaging the tube out of it for the clock.
Again the mega gc from https://oscilloscopeclocknixiecrt.com/AnalogScopeKit.htm (what a sick website BTW) has been helpful with a datasheet and will get back to me with pinouts for this tube with his board
I can't find much information at all on this scope other than its made in India so finding a service manual or any information on it has hit a dead end
I'm figuring out what I want to do for a case for this one, don't want to reuse the scope body. Might do something similar to the Nixie clock with the copper and steel as I've still got some stuff leftover
1 hour ago, h4nd said:
or, just make it go, and ...
You wouldn't have a L7824cv reg in your pile of bits? I could gamble on a aliexpress one but also cbf digging more to see if there are any other faults. I de soldered it and did a quick resistance check on output side and no shorts or super low resistance to earth but what caused the reg to die?
I do have a known good working crt scope so another project to add to the list Screenshot_20260620_204436_Photos2.jpg.86f2e7eca0c70f8760e1b7145bc1e417.jpg
On 20/06/2026 at 20:56, chris r said:
L7824cv reg
I thought I would, but no, sorry.
Wild arsed guess, Electros around it have gone dry, and it's oscillating then doing thermal shutdown?
SiCom here only have the 7824 1A version
Caps looked okay haven't tested them.
Could de solder it again and test it outside the circuit.
Had 0v on input and output but when (7824) de soldered had a nice 30 something volt dc.
No shorts to ground /0v rail on the output side (after I de soldered)
So could be reg being dumb, rectifier circuit being dumb, or transformer winding somehow shit the bed
I could just feed that part of the circuit with 24v and see if it comes alive...
But i have to finish my power supply project
Of course, you could put a 12V Zener || 100nF  inline with the ref (Gnd) of a 7812, just check if the heatsink is insulated...
Ooh good idea, but heatsink unfortunately is grounded.
I like the idea of fixing the scope but I've already got one that works and would rather spend that Barry time progressing the project
The repair guys at work had a spare 7824 in their stash so I grabbed it.
Solderd some test leads on.
Had ac going into the rectifier but no dc coming out of the circuit, de soldered the rectifier and it tested fine.
Tested the capacitor and that was also fine.
Decided I've spent enough time on it
Started pulling knobs,shafts and buttons out. It's cold and I cbf getting a socket set so that's enough for tonight
So as someone who has too much shit and needs or organise it, do I A: actually sort it out or B: get a 350kg industrial vending machine?
No points for guessing the answer there
May I present the latest in procrastination. The autocrib, 2 meters tall weighing in at 350kg. It is(was) a automated vending machine (automated and vending does not apply at this point in time)
Messenger_creation_47B5A545-FD65-44DE-8EA9-C5FBF82341DD.thumb.jpeg.23f7180286e331140bc6b1bf023d679a.jpeg
Slightly sketchy unload with lots of puckering
Messenger_creation_74AB05EB-F51C-4FF0-ABEC-0F21409CA09B.thumb.jpeg.f0014a763fb37bc121273f1ac5c58c96.jpeg
Me to myself. "it'll fit in the carport"
Yeah just
Messenger_creation_1609FFAB-4976-4A6B-9B30-EE402B68201A.thumb.jpeg.ebfe434be5f50fddaf7108d03f95d0ae.jpeg
I'm a qualified personnel Messenger_creation_77A3BBDD-3008-438B-974B-49B721A6A1AE.thumb.jpeg.d0d9b547358830738b7235ee0ed606d3.jpeg
Took the side off
Messenger_creation_BFC6B82A-C0B7-4DB3-84B5-3439D9228F73.thumb.jpeg.4c7dd3f0c478da05d8d501ed61e7a3b5.jpeg
Look at all the storage possibilities
Messenger_creation_9E7E9225-5210-4BCF-ADF2-93127CBE8E51.jpeg.c2cc92a3211d504a9c27b40eb71325c7.jpeg
I'd wondered how it knew the positions of the bins/stacks. Got a wheel on the bottom with various holes for the positioning Messenger_creation_E48ED337-8C6D-4704-9233-66F123306AB2.jpeg.e0979908e098164cca4971d4f3b5576c.jpeg
The seller advised me that the hard drive had died. I extracted the pc out of it and the hard drive was indeed dead and buried
Messenger_creation_79BABF11-FED8-41DC-AD2E-E051DCD70A1B.thumb.jpeg.54b0b50b4272f61079a620d4084b8da6.jpeg
A friend has a old hard drive I can have so I'll collect that at some point, reinstall windows and see if I can track down the software for it
Awesome, it will run a POS (in every sense of the acronym) XP build
You might be able to recovery some of the data on the drive even if its mostly dead?
It would be cool to set those trays up with all the sizes of nuts and bolts, and just dial in the ones you need and BING they pop out hot and fresh
  • Haha 1
Hard drive is totally missing unfortunately my hope was some attempt at data recovery. It has a windows 7 sticker on the side of the pc so might a replacement pc from the og xp machine who knows
Will plug my laptop in and see if it recognises any of the usb devices and go from there
8 minutes ago, Thousand Dollar Supercar said:
Once you get it working, you can fit it into your daily life as a high-security pantry with inventory management and automated online reordering, while you work your way up to building a Rube Goldberg breakfast machine.
Why limit it to just the pantry!
One stop automated password controlled vending machine.
Shitty nuts and bolts, beers, rums and snacks at the push of a button
It looks like the software was a fancy Excel sheet that could run a macro and pop a solenoid. You can probably get Claude to vibecode something similar if you can figure out the signals
It's the interfacing with the rs232 port on the vending machine side that'll be the fun part
Plugged it in again and smoke came out of the fan hole
Messenger_creation_9D11C5FE-85C3-4DDE-AB76-62DA8FD8D3E2.thumb.jpeg.95e115d85450c208ce54192c1a299201.jpeg
Yup that'll do it
Messenger_creation_AD79C85E-3CAE-4458-9C1A-D209BFDE0974.thumb.jpeg.ccc9cdf36e11fa1541226f0d4c77df27.jpeg
Wacked a spare slightly smaller 24v power supply in
Messenger_creation_C9C148BD-132D-42E3-A000-B66066DE33ED.thumb.jpeg.8121a61ee5c1519fc4eda59e4c275021.jpeg
It was flashing on and off like it was hitting overload. Hopefully when the smoke came out of the old power supply it didn't take anything else out with it.
Had a go at the thin client that came out of it. Yup it's dead. Full fan noise and nothing happening
Messenger_creation_7A976557-830F-42E3-8962-6CF88D5A8A15.jpeg.4639555cf18e48846f2c6aed41262328.jpeg
Only thing I have with a vga port is the old xp laptop
Messenger_creation_74A48435-F733-4364-8032-1F71F540FC50.jpeg.66dd7528d61e7f6c6aaaf325b33f3dd4.jpeg
Touch screen works
Messenger_creation_D6C92B17-102C-49A0-8262-70F26FBDE74D.thumb.jpeg.f086b00b6d8b32733e264d79757f3113.jpeg
It is now being used to hold its own parts
Current state of affairsMessenger_creation_9A878229-3A76-4C20-80F6-2DCC011ABA81.thumb.jpeg.f8d0eac7c2ccca83174caf19497e5456.jpeg
It's about to get 24v from a couple of car batteries with a headlight bulb in series to hopefully stop the smoke coming out and I'll see if I can get any sort of communication out of the usb - rs232 converter and will see if the manual controls work
I decided to use two car batteries to power the robocrib 24v stuff today Messenger_creation_D42467C4-7E08-4028-B5BD-8DDF47ACF267.thumb.jpeg.dd3be12ac5560423bb15d3ed53b24a54.jpeg
Messenger_creation_353D5034-A01E-4167-99F0-BBE507F87532.thumb.jpeg.c87b93dafaad41c346e2d9edd1e5c9a5.jpeg
Initially had a headlight bulb in series but it popped. Thought I'd try a 10a fuse but it's pretty angry. Maybe when the smoke came out of the power supply it cooked something else
Marked up the connectors and removed the board
Messenger_creation_5B1629E1-5BCA-4676-9AFA-9A35FD20C3A9.thumb.jpeg.3bb3ae2190bca5bc58460ecdbb5f0dad.jpeg
No obvious skid marks or stinky components
Might be able to learn then do some nerd shit with that micro controller, or even watch the rs 232 comms stuff when I manually activate it
Messenger_creation_35B2D2C4-0A8C-4A06-8FA6-7CB79482261A.thumb.jpeg.0da6df07cc4b130fdb2618a386660d64.jpeg
