Adoom Posted January 11, 2016 Share Posted January 11, 2016 FYI: Idle Speed Control/Idle Air Control... On my CA18DET I need some crazy snake hose to plump the IAC valve to the intake pipe. Can I just stick a little filter directly onto the valve and not have to have the long hose? I can't think why it would not work. It's not like it needs boost pressure... it only opens when the engine is idling. Quote Link to comment Share on other sites More sharing options...
downtrail Posted January 11, 2016 Share Posted January 11, 2016 Itll leak plumb it in before throttle plate also if you have afm it will not meter that air at idle so itll be all out of wak Quote Link to comment Share on other sites More sharing options...
Adoom Posted January 11, 2016 Author Share Posted January 11, 2016 Itll leak plumb it in before throttle plate also if you have afm it will not meter that air at idle so itll be all out of wak I should have mentioned that the engine has a link ecu and is using a MAP, not an AFM. So if it leaks, it should make no difference if it leaks through its own filter or via the main intake pipe, right? 1 Quote Link to comment Share on other sites More sharing options...
Roman Posted January 11, 2016 Share Posted January 11, 2016 If you plumb it back into pre-throttle body somewhere, when it makes boost the pressure on both side is balanced so no leak.Depends on the ISCV unit I guess but not plumbing back to pipe and you'll have air blowing back out through it. Quote Link to comment Share on other sites More sharing options...
Adoom Posted January 11, 2016 Author Share Posted January 11, 2016 If you plumb it back into pre-throttle body somewhere, when it makes boost the pressure on both side is balanced so no leak. Depends on the ISCV unit I guess but not plumbing back to pipe and you'll have air blowing back out through it. Ah, I see the boost leaks out. spose I need that long ugly pipe. Quote Link to comment Share on other sites More sharing options...
