cletus Posted December 23, 2015 Share Posted December 23, 2015 Hello. Is there any reason why I can't use argon in a mig welder apart from cost? I'm thinking about getting a tig welder, I already own a bottle so would like to have just one for both. Also can you fill an argoshield bottle with argon? Tell me why I'm an idiot here. Quote Link to comment Share on other sites More sharing options...
Bling Posted December 23, 2015 Share Posted December 23, 2015 http://www.mig-welding.co.uk/welding-gas.htm Great forum. Not 100% sure on filling, so won't say yes. Even though I believe this to be the case... Quote Link to comment Share on other sites More sharing options...
datlow Posted December 23, 2015 Share Posted December 23, 2015 I asked the same idiot questions when I was deciding on what to buy (as cheaply as possible) Straight argon isn't recommended for mig http://www.mig-welding.co.uk/welding-gas.htm Can change from argon to argon mix but not back (as now it won't be straight argon for Tig welding tho again you can Tig with argosheild but gets messy) Could buy co2 cheap for mig welding? Quote Link to comment Share on other sites More sharing options...
Llama Posted December 23, 2015 Share Posted December 23, 2015 Iirc, you should be able to fill an argoshield bottle with argon. Welding will work OK, kinda just like pure Co2 will work. Welds just will be cooler in this case with less wetting Quote Link to comment Share on other sites More sharing options...
datlow Posted December 23, 2015 Share Posted December 23, 2015 Beaten to it ah, also found a gas swap place after I bought a bottle and have to wait 2 weeks for it to be filled! (Wellington so has to be sent to Auckland for filling! http://eziswapgas.co.nz Quote Link to comment Share on other sites More sharing options...
SOHC Posted December 23, 2015 Share Posted December 23, 2015 Hello. Is there any reason why I can't use argon in a mig welder apart from cost? I'm thinking about getting a tig welder, I already own a bottle so would like to have just one for both. Also can you fill an argoshield bottle with argon? Tell me why I'm an idiot here. with the co2 argon mix the more argon the flatter and more penetration you get, I used straight argon in my MIG the other day aad it was nearly impossible to weld exhaust tube, it just burnt right though. I have an F size cylinder here, it was last tested in 1999 if you want to try your luck on getting it tested 1 Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted December 23, 2015 Share Posted December 23, 2015 Straight argon isn't recommended for mig interesting, i was told i needed to use str8 Argon in my mig for using silicone bronze wire....... might have a go with argon sheild next time i am doing thin panel work. Quote Link to comment Share on other sites More sharing options...
kpr Posted December 23, 2015 Share Posted December 23, 2015 we tried to do the same. argon for both mig and tig. results were pretty average with the mig on straight argon. to the point we got a second bottle (argon shield) for the mig Quote Link to comment Share on other sites More sharing options...
rusty360 Posted December 23, 2015 Share Posted December 23, 2015 with the co2 argon mix the more argon the flatter and more penetration you get, I used straight argon in my MIG the other day aad it was nearly impossible to weld exhaust tube, it just burnt right though. I have an F size cylinder here, it was last tested in 1999 if you want to try your luck on getting it tested Is this a owner bottle? did you wana sell it? cheers rusty Quote Link to comment Share on other sites More sharing options...
rusty360 Posted December 23, 2015 Share Posted December 23, 2015 I ran out of argoshield half way though a job so tryed straight argon from my tig. she was a big no go for me. Quote Link to comment Share on other sites More sharing options...
SOHC Posted December 23, 2015 Share Posted December 23, 2015 interesting, i was told i needed to use str8 Argon in my mig for using silicone bronze wire....... might have a go with argon sheild next time i am doing thin panel work. You need straight argon for silicon bronze wire, it dosn't work very well with mix, i tried. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted December 23, 2015 Share Posted December 23, 2015 What's silicone bronze wire for? Quote Link to comment Share on other sites More sharing options...
SOHC Posted December 23, 2015 Share Posted December 23, 2015 What's silicone bronze wire for? I use it for welding bronze castings, I have repaired cast iron with as well. 1 Quote Link to comment Share on other sites More sharing options...
Raizer Posted December 23, 2015 Share Posted December 23, 2015 Basically MIG brazing. http://www.mig-welding.co.uk/brazing.htm 1 Quote Link to comment Share on other sites More sharing options...
smokin'joe Posted December 23, 2015 Share Posted December 23, 2015 What's silicone bronze wire for? was advised to use it for very low temp panel welding............not a pro welder, but seemed to create far less heat related distortion than either co2/argonsheild with MS wire Quote Link to comment Share on other sites More sharing options...
Testament Posted December 23, 2015 Share Posted December 23, 2015 Anyone seen someone with a bottle of argon and a bottle of co2 and mixing them in situ for MIG welding? Quote Link to comment Share on other sites More sharing options...
Gaz Posted December 23, 2015 Share Posted December 23, 2015 My backup bottle is argon and I use it in mig without issue. Lately using to weld panel steel. Argosheild or panelmix is better though. Gaz Quote Link to comment Share on other sites More sharing options...
Spencer Posted December 23, 2015 Share Posted December 23, 2015 Man everyone trys to use the wrong gas to save on bottles/cash, just buy the right gas for the welding method and it works better. 4 Quote Link to comment Share on other sites More sharing options...
SOHC Posted December 24, 2015 Share Posted December 24, 2015 Anyone seen someone with a bottle of argon and a bottle of co2 and mixing them in situ for MIG welding? I was thinking about doing this but decanting them into a 3rd cylinder Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted December 24, 2015 Share Posted December 24, 2015 Man everyone trys to use the wrong gas to save on bottles/cash, just buy the right gas for the welding method and it works better. Yup! Quote Link to comment Share on other sites More sharing options...
