tortron
Whats next?
Il probably rub the frame down with bees wax
Adjust the seat
I have some nicer track cranks but as of yet no suitable chainring for them
I have some high flange Miche flip flop hubs
or probably none of the above and save all that for a custom frame
might want a front brake IDK, I'm probably too old for that stuff. Might go do some laps at the wee velodrome in hillcrest
no doubt I missed the boat on fixies being hip, but whatevs, I'm pretty much a professional cyclist and bright coloured bikes with bmx bars are lame
Il probably sell it if you want it bad enough
  • 6 months later...
Things i have done recently
Front brake - i dont like the lever, havnt found one i think suits. alsmost swapped it for a centrepull but it looked horrible
longer stem. doesnt handle like total crap now that the weight isnt so far behind the front wheel
longer chain so its not only half in the dropouts
I torched off the pully mount, pump pegs, and front guard mounts. THis was a silly thing to do because they all had locator tabs and left holes in the frame, which i then had to braze up. But i dont have a grinder here so whatevs
I think thats is. I didnt file off the rear guard mounts because i have some track ends im going to braze in
So i have another bike
Its Terrible
Mustang Sports.
Was a 3speed
An 8ft tall person had tried to stretch the frame to fit them i guess
it wasnt good
Im going against week before bike summit rules and am shrinking it and turning it back to normal, so I can sledge into some crowds
First, the yuckness. it was covered with red tape
13433337_1044734525561888_36394146708546
13419019_1044733745561966_90227231561096
13423979_1044733785561962_47875369017874
not even any tubing to cover it
13483215_1045262168842457_16365726017736
13432140_1045262215509119_30838619679936
And tidied up a little. I think that bottom headtube lug is bent, the tubing is nearly spot on straight going into it. Maybe its an illusion because I need to clean it up some more.
13497632_1045752315460109_13927706255277
Threw some bits at it to see what it looks like. Not too bad
Almost have enough spares to have it ridable, don't have a bottom bracket tool because I only ever deal with cup and cone, or the phil wood one on my touring bike. So waiting till then.
Will bomb around as is for a while. The ultimate beater, just to see how well my joints hold. I silver brazed them. If it falls to bits then whatever because I only really paid for the fork.
If it doesn't fall to bits -
then gloss black
High flange flip flop hub for fixed/single speed
blacked out everything else
  • Like 6
Overnight parts from Russia
should work alright.
These are 5mm thick. the original are a whopping 1/8", so I think il just cut them off and grind them out, this should get rid of any old brass, then il zap them with a welder
