Evo microtech and sensors
Jackbates
If its from an evo 1-3 then yes the cas and tps will work on your vr4 engine
If its from an evo 4-9 then no the later evos had a crank trigger buried down on the crank pulley and the Cam angle Sensor alone will not work.
Tps and throttle body will be a standard 0-5v output so any old one will do. Pretty sure the bolt pattern on the manifolds are the same.
