Guypie
Nominal's 1961 Morris Oxford Discussion
71 posts in this topic
We don't all have a van to haul junk around.
I got some taller 185 tires from pick apart fitted. Hyflys ftw.
Share this post
Link to post
Regarding front wheel dilemma and reading through the thread I may have some advice. MGB front discs should fit with a bit of matching of kingpins and the likes
but not sure if it's a complete bolt over job. The two share a common ancestor. I used to work on a mad Wolseley 16/60 in Auckland for a customer, with a 260 Ford motor, the Y block having the right dimensions and of course the best sound the yanks have made to date. In that situation with the added weight and power, we cannibalised the discs and five stud hubs off the six cylinder as well as the tougher back axle. Loads of ratio options and the diff at least was a bolt in job. Loads more wheel options too.
Ended up with Rover P5 Rostyles on it which suited it, the other less fun option is get an earlier Oxford drum and shoes, the later cars had an extra half inch of material hence weird shaped drums.
1 person likes this
Share this post
Link to post
Hi
I think I may have discussed your Traveller with you mid last year. My computer got zapped and I lost all email. You are doing a great job. I looked at this car three owners prior to you and the corrosion put me off! Particularly in the front crossmember and tailgate area. We should talk as you and I have similar projects on the go!
Cheers
Sparks
Share this post
Link to post
Great work seeing an old wagon being restored and kept on the road.
Share this post
Link to post
Thanks guys.
@Sparkfarmer That looks like a bigger project than I'm doing.
Changed the oil and filter yesterday. The bolt-on canister is a pain, made even worse by the lack of access with is stuck up above the engine crossmember.
Share this post
Link to post
Share this post
Link to post
Share this post
Link to post
Share this post
Link to post
Wow not sure why I haven't stayed up to date with this- damn you are good at this rust repair stuff.
Where did you get those neat magnets from?
Share this post
Link to post
Thanks - I really just make it up as I go.
Search for neodymium magnet on aliexpress, plenty there.
Another APU!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
