Steelies Posted September 18, 2015 Author Share Posted September 18, 2015 already got a clown bike and a chopper, going for dirt look here! square headlight or number plate?? 1 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 18, 2015 Share Posted September 18, 2015 jesus fuck Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted September 18, 2015 Share Posted September 18, 2015 fuck jesus Quote Link to comment Share on other sites More sharing options...
Steelies Posted September 18, 2015 Author Share Posted September 18, 2015 let's do this Quote Link to comment Share on other sites More sharing options...
Shakotom Posted September 21, 2015 Share Posted September 21, 2015 What's the rear hub/how's the cog attached (Stealing your ways) Quote Link to comment Share on other sites More sharing options...
Steelies Posted September 21, 2015 Author Share Posted September 21, 2015 ah good shit! it's bog standard coaster brake hub, minus brake arm. i pull old sprockets off 10spd crank sets, bore the centre and put 3 blobs of weld to suit the hub input drive thingy. have a 46t ready to go if you'd like it. have also in the past just mangled the centre out of a sprocket and welded it to the side of the original 18t driver on the hub. slowly building a pile of spare tip shop wheels in case of failure haha. 2 second swap out Quote Link to comment Share on other sites More sharing options...
Popular Post Steelies Posted September 22, 2015 Author Popular Post Share Posted September 22, 2015 really went to town on the tank/old oil can. chop, fit, solder, smack repeatedly with things to 'adjust fit', leaks like a shower rose, of course. one more attempt at soldering leaks up then it goes in the bin. driveline coming together, had plenty stuffing round with the clutch which is on the other side. coming in just over 20kg as it sits. 14 Quote Link to comment Share on other sites More sharing options...
Rookie Posted September 22, 2015 Share Posted September 22, 2015 Fuck that looks cool Manu, good job. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 22, 2015 Share Posted September 22, 2015 the anticipation of seeing you in riding position on this thing is killing me 2 Quote Link to comment Share on other sites More sharing options...
Goat Posted September 22, 2015 Share Posted September 22, 2015 This looks super rad! Quote Link to comment Share on other sites More sharing options...
kicker Posted September 22, 2015 Share Posted September 22, 2015 Any idea on it's speed? 20kg is rad Just needs a nod to its origin 2 Quote Link to comment Share on other sites More sharing options...
Steelies Posted September 23, 2015 Author Share Posted September 23, 2015 bahahaha! i've been looking for a flymo nod actually, so now i have to make sweet orange plastic skirts. aero etc? got tank sealed up and outlets put in, tank/shifter mounts on. just need a frayed bungy cord to secure the tank appropriately weighed up at 22kg minus motor internals and some levers and stuff. so maybe 25-30 at the end? holds 1.5l of juice just sort of assumed similar speeds to the villiers. could only get to 4th or 5th gear on that thing, mathsed maybe 7th gear on this, given all the reduction changes. Kirk got his tecumseh to 70Kph with a belt system on a 20" steed on the beach.. so given losses in 16" sizing, gains in chain vs. belt, and a sprinkling of carb, compression, seals and conservative exh porting, first goal may as well be 70kph without dying. villiers topped out at 70 on a good day. main goal this year is spraying one or more of the Ellis brothers with dirt, and/or forcing them into the long grass. 4 Quote Link to comment Share on other sites More sharing options...
Steelies Posted September 24, 2015 Author Share Posted September 24, 2015 time for some of this soon. that sprocket then got the grinder treatment to get the teeth down to width, shit was way too hard to turn and i was too impatient to anneal it etc. clutch mounted-ish, shifter and neutral selector thingy whatsit in place. starting from the motor and grouping everything as close as possible together has pretty much meant everything was too close and needed notching, hammering, cut off and moving, all over the show. riding position wont be any different, will have to go around one knee to operate gears which, as per velobike stz, arent on the bars /cable too short so it goes there 2 Quote Link to comment Share on other sites More sharing options...
Steelies Posted September 29, 2015 Author Share Posted September 29, 2015 business at both ends for this hussy, oowee 4 Quote Link to comment Share on other sites More sharing options...
Rookie Posted September 29, 2015 Share Posted September 29, 2015 Looks great. I hope this going to have a wild spanny on it. Quote Link to comment Share on other sites More sharing options...
Steelies Posted September 29, 2015 Author Share Posted September 29, 2015 myeehh, probably just a bit of chair leg to start with. it seems a spanny built for conservative RPMs is long and boring, and i dont really want to encourage this thing to throw a rod/flywheel till later. Quote Link to comment Share on other sites More sharing options...
Popular Post Steelies Posted October 4, 2015 Author Popular Post Share Posted October 4, 2015 hey, it runs! smoked out the workshop on 20:1. 11 Quote Link to comment Share on other sites More sharing options...
DodgySam Posted October 11, 2015 Share Posted October 11, 2015 Im hoping for ludicrisly undersprung front end which results in mad diving into each corner and more repeats of this... Quote Link to comment Share on other sites More sharing options...
Steelies Posted October 11, 2015 Author Share Posted October 11, 2015 haha, dont worry sam, all signs are pointing to wipeouts already. took it for a test at the velodrome carpark yesterday, as usual a lot of time pulling carb apart and then trying to find all the bits on the ground. reminds me of summer haha. first impressions - sheit, might need to put gearshift on the handlebars, it's about as wheelie-happy as it looks. motor seems ok, a bit spluttery in places. too rich with the filter on, see new airbox design exhaust is loud and splattery, tick standard clutch tests have resulted in spinning the hub axle/mincing gear change cable so that needs sorting out. it somehow also threw and jammed up the rear chain at the same time, sparks and all. for gearing comparison, the carpark was a 1st gear affair on the villiers, flymo was happy tootling around in 3rd. 5 Quote Link to comment Share on other sites More sharing options...
Steelies Posted October 14, 2015 Author Share Posted October 14, 2015 ok this thing has got all the mod cons, i dont know whats going on. heres a list to service mainly my own amazement/must be getting old fuel on/off choke with lever mudguard/airbox horiness standard handlebar foot pegs and mig-grip try and stoppy axle spinny things on the gear hub, fingers crossed there kill switch with keys, bishes next is gut the meddling brake pads out of the rear wheel, new rear chain and shift cable, and more (non?) destructive testing. 3 Quote Link to comment Share on other sites More sharing options...
