Alasdair's 1974 KE25 Corolla
AALAWS
Little by Little.....the story of the noob car restorer.
cut off half the un-needed mounts on the ae86 diff and left the pan hard mount for now. T3 does a te27 bar and mount kit that may work depending on exhaust etc.
I cut into the tubing a little bit.....just wondered if I needed to fill/weld this up a bit for strength?
Also sent the engine and a few bits (hubs,callipers) to get dipped and checked over.
Nathan at Motor Preparations in Otorohanga is good to deal with. He's going to clean up the block and head, check the internals and let me know
what'll need replaced etc so that way I can budget for the rebuild - new cams, rwd water kit, cops.....port and polish.....whatever needs replacing.
I'll paint it up, make it pretty, and stash it away for rebuild time when I'm ready to mock it up in the shell.
....and the shell and a bunch of other bits is on the way to get sandblasted and primed on wednesday!!! Stoked!!
  • Replies 71
My project fund is rather low at the moment, so to keep things ticking over it's onto a few smaller jobs......which always seem to cost a bit anyway hah! So glad for the overalls and facemask etc - wire stalks flying everywhere!
I've wire wheeled all the callipers and hubs ready for paint and rebuild.
small problem of brushing off this little grommet....and theres none in the rebuild kit.
I'm asking though toyota at the mo....anyone have any ideas on where to get these?
Also some rust around the edge of the piston cylinder. I talked to a brake guy and he says they blast these parts....
Are they stuffed or saveable?
//oldschool.co.nz/index.php?/topic/49950-alasdairs-1974-ke25-corolla/page-3
  • 6 months later...
so I Painted the callipers almost a week ago with dupli colour high heat colour, and clear, and they're still tacky.
The clear can says to bake in an oven at 200deg, but I thought a few days in the sun atleast should be ok.....but it's still tacky.......any ideas?
i bought a convection heater from the warehouse to bake parts in, like the ones you use to warm up pies and savories  you could try one of those.
Thanks to the guys with the offers for help!
I gave the calipers another clear coat and they are finally coming right - will give them a bake soon too.
When I bought the Dupli Color paint, I didn't want silver, but a darker grey, so I got a high heat paint with the dark grey top, not caliper paint. But they still came out more silver like........went to get another can for the rears and discovered they have recently changed the colour of the lid to a light grey for the same paint because they knew it was a misrepresentation - thanks dicks!
Anyway.....teaser pic of very cool things to come........Recaro seat custom skinned ala TE27
  • Like 7
  • 5 months later...
  • 2 months later...
last year an old barry drove his lawnmower into a power transformer and shorted out the street......right when I was doing a computer backup.
I replaced my spa pool control board and the munted portable hard drive and wrote off the loss. A bit later I had to do a system restore from a backup to clean it up a bit (after watching a dodgy All Blacks live stream), but I had lost my recent ones with crashed hard drive so used an older one, thought nothing of it and moved on.........until I went to re-assemble my freshly blasted/painted/plated TE27 pedal box etc on the weekend.
All my "dismantling" pics were lost in the process, my caliper ones were in there too......Bugger!!
So I've put it all together the best I can remember. There may be a few washer or spacers out of order but meh we'll get there.
IMG_3810.JPG.65cb3dd2a68688670fade1fbc8210396.JPGIMG_3811.JPG.02e03039be2af21c4e048e07b626ccec.JPGIMG_3812.JPG.5f448dd39d03bf6215dd1ebbfbf2844a.JPG
I need to replace a couple of rubber stoppers/grommets that sit in the pedal and cushion them when inactive......all 4 of mine were worn and split, and I need the boot that sits over where the accelerator bracket meets the cable through the firewall.....anyone know where I can get something similar from?
IMG_3813.JPG.268298ae8975c51f799fe351ddd84c99.JPGIMG_3814.JPG.0d43ea3547c909cb663b39bb61b48abf.JPG27f6bb.jpeg.1b844bca82cd5cbb1ad6d23914de3d4c.jpeg18403100_1328041207250348_1037742485914843933_n.jpg.b627dca9c3a2930da3495f6adfc645ca.jpg
Yarns here:
  • Like 6
So the wiper motor is all cleaned up and fitted to the te27 pedal box
and I may have solved the grommet issue using some ae86 ones (if they arrive - that's another story)
IMG_3921.JPG.2b7abd948fa0bb9edefa7534d34b6010.JPGIMG_3950.JPG.b0daa39c3a30f8d3a7849413fc09bd87.JPG
Got some wheels - 14x6 SSR Mesh. I need it on wheels for the panelbeater so these are good placeholders until they get a refurb or something else could pop up.
The lips are a bit scuffed and one is a bit bent, but they'll be getting widened once the car is done if I use them.
I'm going to hold off on the final decision about rack and pinion coversion until the very last minute. I need to get all the subframe and steering etc back together to get it rolling so can't be stuffed getting tied up in all that conversion and maths shit (blahblah time $$ and frustration).
IMG_3935.JPG.fba9274f33178608fabc399da6414489.JPG5a6feba8c747e_IMG_3880copy.jpg.c4d683e0c7fc8e970ac5e745e43d5ce3.jpg
I've ordered a truck load of bits to get this ready (plus found some NOS outer tie rod ends and Pitman arm I had stashed away)
SW20 rear struts for coilovers
Idler arm, ball joints and outer tie rod ends
T3 RCA's
Cusco te27 Camberplates
Full set new rubber bushings
AE86 front & rear bearings and seals
Diff gaskets
Caliper rebuild kits
AE86 Rotors
Brake fitting kits and shims........theres more I've forgotten to list too....such a mission finding out all the parts you need and ordering them from all over!
and some box section to make up a jig for transferring the leaf spring perches to the AE86 Diff housing - which is hopefully this weekends job.So theres a bit of welding, painting, crack testing and assembling and hopefully by the end of Feb she'll be other wheels again.
  • Like 7
aargh!! Looking at the old pics of this!! Better bloody get a hurry up on and get this finished!!
Few more bits arrived to get it on it's wheels. Toyota diff gaskets and a few seals etc, cusco camber plates, front bushing kit ex eBay Thailand, AE86 discs and a replacement for a bent suspension arm (cheers Daz at Oldscool....eventually ha ha)....I'll get the bits off to the engineer on monday for a professional steel glue job.....then it's paint and assemble.
IMG_4040.JPG.28025be5898da707d0010b54d6c550e2.JPGIMG_4041.JPG.758bbbe10c2fde27bc5d8bdbdd62c6ac.JPGIMG_4042.JPG.fe983afb7c5bb49ab0a56d8b6eca854e.JPG
Ok so it's Wednesday tomorrow.....maybe I'll drop all those parts off in the morning :doubt:
My rear panel arrived via ML Racing! it looks like it's been a newish panel stitched on to a rustier car. It's been hacked off the back of the donor so thankfully all those rusty bits like the remainder of the boot floor etc can just be removed as I only need the actual face of the panel. It's got a bit of pitting along the bottom valance and a few small holes, but it's miles better than the bent swiss cheese on my car at the mo. Inner tie rod ends arrived too.......just waiting on one last delivery of gaskets and other small bits and we'll be in business.
IMG_4059.JPG.bdfe86c12a37ba811faf5501a9440a20.JPGIMG_4056.JPG.1987f19b75ae2902706f1cf5d8ae71bf.JPGIMG_4060.JPG.5ca6d296b07ff6c9c48b188b5748ac66.JPG
Found a ke25 shell today.........salvaged the windscreens, a few plastic clips and the door chrome.
Local engineer still hasn't sorted my diff and struts etc......and still a little boy waits......
Check out left to rot to see the two other wrecks hiding under the trees......
  • Like 7
  • 2 months later...
Just like a state house........Crack testing passed!
Gave a few bits a coat of primer the other day, then some top coats yesterday while the weather was......warmer atleast.
It got pretty cold once I had finished, hopefully that doesn't effect the6-8 hour cure time??
IMG_4393.JPG.5cdfb05e2a9439649e2def887a82e7a2.JPGIMG_4394.JPG.1ad129e69a8be3093fe38767f39de828.JPG
Had them all hanging together with the fan heater going to warm up the area....complete with hi-tech corrugated cardboard insulation barriers!
Powercleaned the diff housing, doused the inside with CRC and gave it a rub down with rust converter, and another coat on the leaf springs.
Also had the shitty paint blasted off the callipers and got some crappy tyres fitted to the wheels to get it rolling atleast.
IMG_4392.JPG.305ace3d2f9986bd0096fc772a2c419a.JPGIMG_4391.JPG.39a948c90e3b886b7f1d8581bdc9c7fc.JPG
Ordered some bigger U-bolts and the lowering blocks/brackets are being modified to fit them.
Now I just need another good day to finish off the top coats and the fun part of assembling all of this to get it rolling begins!
Shiny Goodness.
IMG_4491.JPG.1359936a479680b3c50acd095496e734.JPGIMG_4492.JPG.760a15a91f4f3e78855d7fdffda08fc5.JPGIMG_4493.JPG.61b1f4e39633741abd772f9a2ffbff31.JPGIMG_4494.JPG.ea91e7ea577d066311b11e38e3e06ba0.JPGIMG_4495.JPG.666ba74dda10419a13e240b0ad02b00b.JPGIMG_4497.JPG.d87919f0b4c2d38a9dfcd4cc26373361.JPG
All painted and ready to assemble.
Just not sure on the exact arrangement of my coil over kit........any advice?
1. There is two bits at the bottom for the spring to perch on. I assume having both of them threaded up tightly together is sufficient to hold the spring, but which way do they go? As in the picture? I've seen ones where the bigger one is flipped and at the bottom? and does one of the red plastic washers/spacers need to sit between the spring and the mount?
2. does the insert need a spacer between it and the outside of the strut tube or is having the threaded top enough?
IMG_4499.JPG.6fbb7f66f2fb3f29bc7ef4afb1714e89.JPGIMG_4500.JPG.8042b414eb141546b6d444aca42fe9ab.JPG
3. Does the larger spring go first, or the smaller one (the retainer spring i believe?) ....again I have seen both ways.
4. The extra red plastic spacer is seen in the last photo....doe this sit between the threaded base/perch and the first spring? or the top of the top spring? (which is where it was in the kit but that black one is already there so that raised the question for me. I'm leaning towards the first option but just wanted to double check.
IMG_4501.JPG.838316a90d80dee56691589f6ade61f9.JPGIMG_4502.JPG.3d920d42b09d7ada9941f98e2833e782.JPG
Cheers folks......help a noob out!!
