GreenTC Posted December 13, 2015 Author Share Posted December 13, 2015 Aptly named Super Legere mode by ThreeOnTheTree, Triumph in full race mode. Later that day she went on to run consistent times around 21.6X. Back of bonnet popped because the Honda boys told me it increases airflow. 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted January 17, 2016 Share Posted January 17, 2016 Could be the fuel pump itself that's having trouble keeping up, perhaps a torn diaphragm or hole, etc. Alternatively there could be a blockage in the line or the tank/pick-up. If you don't have too much gas in you could try draining the tank to see if there's any sediment in it and if there is, blow out the lines and get the tank cleaned and sealed. 1 Quote Link to comment Share on other sites More sharing options...
MightyJoe Posted January 17, 2016 Share Posted January 17, 2016 i was going to suggest torn diaphram in the fuel pump. the level shoudn't fluctuate. it should be 95% full all the time. since you've had it apart you should check all bolts for tightness too. it could be sucking air. although thats usually a constant issue, not intermittent. have you got oil in the carbs too?  lovely car by the way. i love mine. really, really love it. they're so underrated and have so many features for a classic. i've never seen one that colour look as it should. the CHCH ones that colour are faded to fuck and resemble bile green. i get shit for painting mine blue and orange but i have no regrets. yours has history to your family thats cool, mine was a 1500buck fixer upper! 1 Quote Link to comment Share on other sites More sharing options...
Get it done Posted January 17, 2016 Share Posted January 17, 2016 Looking tidy , I've had 3 of these beasts ! Underrated for what they are , I've found them a bit wobbly in the rear end but a bit of punch up front too Quote Link to comment Share on other sites More sharing options...
Get it done Posted January 17, 2016 Share Posted January 17, 2016 Oh and don't do jumps in them they tear the struts clean out of the body and you bounce down the road getting sea sick FYI 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted January 17, 2016 Share Posted January 17, 2016 Have you taken the tops of those SU carbs yet? the slides get carbon on them, a very small amount causes them to run like shit, when you are starting in the morning and it dose a chuff back through the intake it makes the slides dirty.  I have had six 2500 Triumphs, I had major problems with one car witch turned out to be a worn bush in the dizzy, the fuel level in the glass fuel pump will change often, when you stop on a hot day they back feed into the tank and it will empty. 1 Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted January 17, 2016 Share Posted January 17, 2016 I had a torn diaphragm in my fuel pump on the 2500TC. Had very similar issues but replaced it and it seems to have solved the problem. I have another fuel pump diaphragm kit here that's brand new if you need one. Quote Link to comment Share on other sites More sharing options...
azzurro Posted January 17, 2016 Share Posted January 17, 2016 was gonna say fuel pump issues too had similar issues on my 125, (fuel bowl in the malpassi regulator emptying) - swapped in a new mechanical pump & done.   Im running sideys now too and ive added a small (low pressure) Facet pump by the tank as well which seems to have done no harm - certainly makes it easier to start if its been sitting for a while.  while you are there what about adding a drain back valve to stop the issue SOCH noted? Quote Link to comment Share on other sites More sharing options...
GreenTC Posted January 17, 2016 Author Share Posted January 17, 2016 Cheers for all of the quality suggestions. However I removed the fuel line into the carbs and shes pumping a decent amount of fuel through. I dont think the line is blocked either as when I removed the inline filter there was good clean flow.  My next guess is possibly the condenser. I've heart a faulty condenser can cause similar issues to what I'm having.  I've ordered HT Leads, condenser,  Dizzy Cap, and will see if that helps it. If not fuel pump diaphragm will be next.  I've also gapped and slapped some plugs in it.  Neal, how difficult is the diaphragm swap?  If neither of the above options help the carbs will be getting looked at. Quote Link to comment Share on other sites More sharing options...
GreenTC Posted January 21, 2016 Author Share Posted January 21, 2016 Swapped the coil out this afternoon, it now starts but runs like absolute shit. Whole engine shakes and the engine is quite hesitant. It dies if I don't give it gas. The coil I put in today was an old one, I've ordered a new one for the sake of ruling it out as a possible cause.I don't think the timing could be out as I haven't touched it.I'll check valve clearances over the weekend as well, mainly because it's about time for them to be done. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted January 21, 2016 Share Posted January 21, 2016 Sorry, I was meant to reply to this a while ago but forgot. Â Fuel pump diaphragm replacement is pretty easy. Just remove the pump from the engine, replace the diaphragm and seals while it's out of the car and throw it back on. Have you checked the float bowls on both carbs? Remove the three screws holding the lids on and take a peek in there. Quote Link to comment Share on other sites More sharing options...
GreenTC Posted February 2, 2016 Author Share Posted February 2, 2016 To anyone that guessed the fuel pump was at fault, you win. It was working intermittently due to one of the valves playing up. When I tested it, it was working. Probably why I missed it. Now it's been fixed she's running mint now. Quote Link to comment Share on other sites More sharing options...
GreenTC Posted March 22, 2016 Author Share Posted March 22, 2016 Does anyone know of any threads where people have made a trailer out of a 2500/2000? I've seen a stag one, but can't find any for the 2500. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted March 22, 2016 Share Posted March 22, 2016 No, but I have a mk II sedan body shell that you can cut up and use. I am cutting the front off it. Sling a trailer axle under there and call it a day. 1 Quote Link to comment Share on other sites More sharing options...
GreenTC Posted March 22, 2016 Author Share Posted March 22, 2016 Not thinking of making one until maybe next year.  Currently all monies are being diverted into a Hayabusa fund. Quote Link to comment Share on other sites More sharing options...
Snoozin Posted March 23, 2016 Share Posted March 23, 2016 Hayabusa powered Trump will sound cool I agree but might be a bit underwhelming in he torque department. Kiss the days of towing the pop top goodbye. 3 Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted March 23, 2016 Share Posted March 23, 2016 Not thinking of making one until maybe next year. Currently all monies are being diverted into a Hayabusa fund. Did I mention it was free? Will be killing it off in a couple of weeks. 1 Quote Link to comment Share on other sites More sharing options...
Bangbug Posted March 23, 2016 Share Posted March 23, 2016 How did you sex up the wood?Mine is looking rubbish and I'd like to keep it, but I might just veneer it with something sexy. Quote Link to comment Share on other sites More sharing options...
GreenTC Posted March 28, 2016 Author Share Posted March 28, 2016 The Hayabusa engine will have a frame around it, as well as some wheels, electronics and all the shit to make it work as a motorcycle. I was a motorcyclist before I was a Trump fiddler unfortunately. As much as I'd love a FREE rusty trump body shell on the front lawn, I'd probably be killed. I've got nowhere to put one or work on it yet. As far as the wood goes, that was a good condition dash that came out of a 75 2500 at pick a part, I just rubbed some Neopol on it. Have a go at doing some veneer, and then let me know how it goes. 1 Quote Link to comment Share on other sites More sharing options...
GreenTC Posted April 3, 2016 Author Share Posted April 3, 2016 Fair bit of TC action in Te Awamutu today. I quite liked the look of the below yellow sedan which was being driven by a couple of older guys. Also saw this 2500S being towed north past Hampton Downs, looks like it might be a good project for some lucky bastard! 1 Quote Link to comment Share on other sites More sharing options...
