piazzanoob Posted May 8, 2017 Author Share Posted May 8, 2017 Im also on the lookout for a standard starlet steering wheel As i have this wheel but doesnt match the boss kit pattern but the wheel came with a boss kit to suit the wheel but not the car as you can see in the RH corner. so i am needing the standard spline to be cut off a factory wheel to then be put onto the wheels boss kit Quote Link to comment Share on other sites More sharing options...
piazzanoob Posted July 24, 2017 Author Share Posted July 24, 2017 long time since an update but i have been making progress making and welding in patches been doing this door which had to be made in multiple pieces for it to work in my head so i cut multiple holes in this area and ended up with this so i added a patch here and this one and started making the main patch which this piece here was made from 5 different pieces all welded together but before it was placed into the door is was coated with some crc zinc it paint on the underside then welded in too look like this this is now 2 of the 4 doors done for their patch work Quote Link to comment Share on other sites More sharing options...
piazzanoob Posted July 24, 2017 Author Share Posted July 24, 2017 And with the other 2 doors being sent off to be sand blasted i thought i would do some of the body patches so i started with the one around the fuel flap area but before i could start grinding and welding i thought i would be safe and remove the fuel tank as was abit close but gave me a chance to give that a cleanup also and lick of paint so i cut the old rusty crap out then gave the inside a sandblast then applied some rust converter before welding this patch in one down another million to go 1 Quote Link to comment Share on other sites More sharing options...
piazzanoob Posted July 24, 2017 Author Share Posted July 24, 2017 so with all the fun of cutting and welding in patches i also received some more goodies for this toyota te71 T series disc brake rear end with the sad thing it only be a open diff so will have to sort a Lsd unit for this once its been shorten and fitted in the car A a pair of gimore pulleys to pull me in some school girls but with the purchase of these items i would like to thank mighty Joe for being a total GC and collecting these for me storing them then mounting them on a pallet and sending them to dorkland for me A pair of work equip 01's in 13inch scored these off a mate who had got them out of the inorganic collection many years ago. and have since given them a 10 hour job clean up they now both look like the top one. nothing flash but not too over the top. also still on the hunt for a standard kp steering wheel only wanting it to cut the spline off it so would like a rough condition one. 2 Quote Link to comment Share on other sites More sharing options...
