ToMitz
ToMitz' 1981 Mitsubishi Sigma
57 posts in this topic
New D2 shocks arrived with weld on tube sleeves. Shocks are sporting custom camber plates design courtesy of Poo and water jet out of 10 mm aluminium thanks to Adam.
7 people like this
Share this post
Link to post
Stub axles welded to D2 tubes thanks to Josh. Ready for crack testing
1 person likes this
Share this post
Link to post
The beginnings of priming and sanding the engine bay for fresh paint. Tossing up whether I keep the stock green under here or something different. Any suggestions what colour the engine bay might suit?
2 people like this
Share this post
Link to post
Little bit of progress with the ECU. Got the board populated. Need to buy all the sensors etc now and start designing how the harness will work.
5 people like this
Share this post
Link to post
Stripped and rumbled the L200 LSD. Turned out to be a clutch pack 2 way assembly. Pretty happy to discover this. Nice and shiney after a day of rumbling.
2 people like this
Share this post
Link to post
Finally found some valve locks and got the cylinder head finish assembled. Still needs lash to be set. Time to bolt it down to the block and time it up ready for exhaust and intake mockup.
4 people like this
Share this post
Link to post
Engine bay now officially satin black. Rubber Underseal still to go for wheel arches, transmission and driveshaft tunnel and fuel tank as well as anywhere else I can get out of the tin.
3 people like this
Share this post
Link to post
LS Coils purchased today. Along with plugs, IAT sensor, Coolant Temp Sensor, Inline thermostat housing and new Head bolts
1 person likes this
Share this post
Link to post
Drew up the parts required to mount coils in solidworks. Spaced out as per spark plug spacing
2 people like this
Share this post
Link to post
Machined teeth into damper for crank angle pickup. Hopefully enough to provide an accurate pickup.
3 people like this
Share this post
Link to post
Made my own catch can out of aluminium pipe with press fit end caps. Pretty happy with the result.
4 people like this
Share this post
Link to post
Front shock mocked up in place. Will need to be removed for crack testing later.
Share this post
Link to post
Not my proudest bit of fabrication but does the job nonetheless.
2 people like this
Share this post
Link to post
Yummy bits today to make up the new loom. Basic wiring from link plus a Deutsch connector kit and 33pin bulkhead plug for the fire wall. Also an inline thermostat for the fresh water systems.
2 people like this
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
