Philco Radio Revival
kicker
Little bit more today
Secured and wired up the crossovers, switches etc. Waiting for the glue holding the rear panel to dry. Powered it up, amp and speakers sound good.
Still need to fit the old dial and a backlight for it and finish the BT side but typically I can't find the converter so I have some more on their way.
Found out it's a 1937 model (ID is 37-620) and according to some old radio foamer sites it looks like it was an export from the USA, the ID and info sheet back this up. After '37 they started making them here because of import restrictions.
Being so old, that radio would have been the olden day equivelent of a flash 60" LCD tv. And during the war, the owner would have listened to news reports about the war intently, hearing about battles won and lost.
That is a fucking cool bit of kit you have there man!
Cheers guys, pretty happy with the outcome, not having to refurbish the cabinet made it pretty easy.
Dayfe, I used one of these for bluetoofs.
http://www.trademe.co.nz/electronics-photography/home-audio/home-theatre/auction-935034577.htm
and have it hooked up to the power supply for the amp so I don't have to bother with having to charge the unit separately.
To avoid ground loop issues I use one of these which also drops the voltage to 5V (the same it gets when charging off USB).
http://www.ebay.com/itm/DC-DC-Converter-Isolated-Power-Supply-1205-1W-In-12V-10V-16V-Out-5V-200mA-UL-/161045828977?hash=item257f145571
These are the switches I used, they have a little plate that lets you select from 2 to 12 positions, I just used 2 on both, on/off for the amp and the same for the BT unit.
http://www.ebay.com/itm/1x1-Pole-12-Position-PANEL-PCB-Wiring-Rotary-Switch-1P12T-TW-/131282293073?hash=item1e9108d151
So of the four knobs, bottom centre is volume, left is amp power, right is BT power and the upper middle turns the og dial (which is obviously just for show now).
As far as the amp I used the TA2020 which seems to have a good rep as a low cost mini amp.
http://www.ebay.com/itm/Tripath-TA2020-Class-T-Audio-Amplifier-Amp-20W-Updated-Board-DIY-/400772448392?hash=item5d4fe64088
I also chucked in a 3.5mm jack for hooking up stuff via a cable, it's a switched one from jaycar so when you put the plug in it disconnects the BT feed.
http://www.jaycar.co.nz/Interconnect/Plugs%2C-Sockets-%26-Adaptors/Phono/3-5mm-Stereo-SWITCHED-PCB-Socket/p/PS0133
doope.
Turns out mine is a 1936 Courtenay model 108 produced by the Radio corp. of NZ in wellys.
Is it wrong that I now want to become a radio foamer?
ps, what is the purpose of the crossovers if you arent splitting that shit up into its different frequencies? My audiophileness extended to 2 x 12" subs and nothing else for maximum kidney bleed.
Crossovers split signal for the woofers and tweeters, only used them cos I had them spare otherwise would have just jammed in some 2ways or something.
I'm keen to do another now but something smaller for the kitchen/bedroom
The Courtenay sounds sweet, does it still work?
