Kp60 starlet no spark
piazzanoob
Hey guys a couple of days ago I tried to start my 4k and as I was cranking it over I realised that I had removed the distrubtor rotor so I put that back in and still no go.
And it was going sweet prior to this
So as it is it has no spark
Still has a points ignition
Have tested the coil and found it had shorted itself
Placed another coil in and wired one to the positive feed and earthed the other to the engine
And I'm still not getting any spark
Have checked all the fuses
As it is water is leaking onto the relays
Still need to test them
Does anyone had any simlair issues
Any ideas would be greatly appreciated
Uh the negative of the coil needs to goto your points.
This is correct, but if modifying the wiring back to have the coil -ve post hooked up to the dizzy doesn't solve your problem then check your method of testing the coil before spending any more money. They have a lot of resistance in them by design
I wouldn't be keen on changing to an electronic distributor while you still have an unknown fault
Also: Are you saying it has no spark as the engine won't run, or have you had the plugs out (and earthed) when you are cranking the motor?
If your coil -ve is wired to earth then what you are seeing at the spark plug makes sense. Good luck
I'm not sure what would have caused the coil to die despite you cranking the motor over with no rotor. The points should have been opening and closing regardless. A coil will die if you leave the ignition on for an extended period of time with the points closed, so if there's anything else that happened prior to you trying to start the engine with no rotor let us know so we can help your diagnostics. It seems odd.
