Legendlives VTR1000
legendlives
I think the big Hondas are lightweight enough. I had a Fireblade before this and the weight was never an issue.
Anyway, yesterday I wasted a whole day of my life polishing the exhaust system. Doesn't look fantastic until you compare it with the original 'as bought' picture.
Still haven't fitted the HEL lines (From GSS Performance in Penrose. Plug plug....) but that's this week's job.
HEL gold brake hoses. I did look at the yellow ones but the colour clash was horrible....
I've also had the calipers off and given them a dan good clean:Clutch line;
Rear brakes:
Front brakes:
With the front brakes I went with twin hoses rather than the original linked hose.
As mentioned, when I bought my VTR it had a hideous carbon hugger which was so much the wrong shape that it had been worn through by the tyre. The design was terrible also, directing all of the road shit and grime straight onto the chain.
The obvious thing to do was therefore make my own out of aluminium. :rolleyes:
Just after starting to beat out the mudguard section it occurred to me that it would be virtually impossible to do it nicely without an English wheel. I didn't have an English wheel so I delayed the project while I knocked up this:
Made from tube left over from a previous car project, two old clutch release bearings pressed into a bit of stainless tube, and an old iron caster wheel.
It works well enough:
The chainguard was the first thing I made. This needs a bit of fettling as it was copied from the dimensions of the hugger which bears no relation to the run of the chain!
You can see the 'mod' line in marker pen.
These are the two sides which will join everything together. They also need some shaping:
Hopefully will have it largely finished this week. Will keep you posted!
