Zac's 1998 RX7
ProZac
Chur :wink:. It's all the same stuff though, just what we're all used to we find easier. Thing about electrons is that you can't see em, so you have to have some tools that you trust to tell you what's going where, but it's just a different way of getting the job done :-).
  • Replies 269
Got the loom out last night, while procrastinating about writing this report. I also did the dishes, two loads of laundry, and vacuumed. I'm sure any other students out there can relate.
The covering was in a real state, super brittle and cracked, oil soaked and pretty stuffed. The actual loom itself underneath isn't in bad shape though, and will repair up nicely.
Looks like quite a mess eh? It's not actually that bad, pretty simple as far as modernish looms go really.
I also found something...
Those are the four injector plugs, from right to left being Front Secondary, Front Primary, Rear Primary and Rear Secondary. I've confirmed this by matching the wiring colours, and toning the wires back to the ECU plug. I'm sure that when I pulled them off, the two with tape on them were on secondary injectors. Thus the two without tape were on the primary injectors, meaning the Rear Secondary injector was being fired instead of the Rear Primary, it supplies almost twice as much fuel, so it was never going to run right. It's possible the two with the tape were on the Primary injectors, not the secondaries I'm not 100% sure which way around it was, but they were definitely a pair, this would give the same result, but on the front rotor.
I won the auction on a series 7 solenoid block, will grab it this week and try to get it apart without fucking it. Will tone out the rest of the loom too and figure out which solenoid is which :-).
Now I might have to actually continue on with this report. Stink.
  • Like 9
Cool. I made a cup of tea and ate some chocolate. I think you should blue tack those pictures on the back of the toilet door so you can scan them when a blokes brain is in the height of concentration (which is why we read on the bog)
Got a couple of hours this afternoon, so started reassembly. Got the injectors all cleaned up, new filters and o-rings on and put back into the rails. Gave a few other things a quick clean and removed a bit more stuff (counter-intuitive, I know) to make more room.
Figuring out the solenoid block was the majority of the battle for the vacuum system, but I still have to map out where all the steel hard vacuum lines go so I can make use of them correctly and keep it all tidy. Not overly hard, just time consuming.
I'm also testing all the sensors and actuators against the factory specs during reassembly. It would suck to get it all back together and then find something that should have been fixed while it was apart. I've gone as far as I can today (all the fuel evap system is tested and plumbed). I loaned my vacuum brake bleeding kit to Dad, so I can't test anything further. I'll be doing some tuning in at uni tonight, so I'll borrow the mighty-vac they have there, as it can apply pressure too, so I'll be able to fully test everything :-).
Bullshit update? Yeah, kinda. Pic of what the engine-bay currently looks like:
Some of what I put up here will just be reference for me, so when it's back together, and has issues, I can look through and hopefully find the cockup :-).
Fuel Vent Plumbing:
As far as I've gotten tonight with the on-car side of the vacuum plumbing:
Dinner time now, so an end to the fun for the day.
Id be keen as on a copy of the later model vacuum plumbing of you could please sir. Like you we have the info on series 6 but hard to find anything on the later stuff.
I'm sure you have already but make sure all the check valves are in place and are round the right way. Spent ages trying to fix a non boosting batty following the standard process. Then noticed a missing valve. Boom! All the boosts had come back. (Different problem I know, and I'm sure Brad and Jon had that stuff right anyway)
a guy i know just vents the tank to the ground, on the firewall, where the hard lines finish. i can see you are too thorough for that. I'm led to believe the fuel pressure solenoid is only for hot starts and not necessary in nz conditions, i've got away with it missing for ages now, have checked the tune with wideband. I just plumb the regulator to boost source post throttle. You're going well man keep it up
Wasn't really tired when I got back from uni in the wee hours this morning, so spent some time in the garage. Once again, this post is more for my reference than any actual progress.
Air Bypass (Blow Off) and Charge Relief Valves both tested and functioning correctly.
Vacuum Tank tested and held vacuum fine.
Pressure Tank tested and held pressure fine.
Check Valves that goes inline with the Pressure Tank is fucked, will need to source another.
Airbox to Turbo Intake accordian pipe is fucked, will need to source another.
Figured out how the Secondary Air Injection system is routed through the manifold.
Tested the Secondary Air Injection unit and is functioning correctly.
Tested Deceleration Control Dashpot and is working correctly, however will need to be set once the car can be run to normal operating temp. Cold start system looks like it's bee played with, set to somewhat logical settings, but will need to reset once car can be run and warmed up.
Tested both Wastegate Control and Turbo Precontrol Actuators, both hold pressure and function correctly.
Tested Charge Control Actuator and it's functioning correctly.
Just need to test the Turbo Control Actuator now, but its a pig to get at, will jack car up and get at it tomorrow. Started re-running vacuum lines, but really need to remove the secondary turbo intake pipe to get to a couple of the barbs, will also do that while car car is jacked up.
Did a bunch of Uni work at home today, so split some time to work on this for an hour or so aswell.
Tested the Turbo Control Actuator, on the pressure side, functioned correctly. I tested the vacuum side too, didn't climb under the car and actually observe the valve, but the line did hold vacuum.
Plumbed up the actuator side of the metal pipe manifold that feeds the Charge Relief system.
Installed and plumbed in the Charge Relief Valve.
Updated my vacuum port reference map.
Will hopefully get a bit more time after dinner to have a further play, can hopefully get the injectors installed, secondary air system back together, Air Bypass Valve (blow off valve) installed and start in on the solenoid block.
