yoeddynz Posted July 7, 2015 Share Posted July 7, 2015 Can anyone help. I keep looking on net but either they want moonbeams or the sites go through several redirections and end up at random crocodile porn..or something. Our lights are/have been iffy for.. (embarrassed face) years and getting stranded halfway between nelson and motueka tonight is that final kick up the bum I've needed to make me think.." gee whizz.. I really need to look into this problem Pronto! I'll do it next week..' Problem being this. I turn the lights on but only the sidelights come on. The blue high beam telltale is on too. But no mains. Flick in and out of high/dip does nothing. Blue light stays on but still no mains. But I can activate high beam by pulling light switch back. Usually if I leave it and just start driving with sidelights only (not fun at night..) the mains will suddenly just come on. Could be 10 secs, could be a few minutes. Sometimes ages. Tonight I just thought fuck it and drove along pulling switch back keeping full beam on. After a minute or so I let it off and the mains stayed on. Random. I've checked in the past all the relays etc and it's just a annoying intermittent fault. Really considering ditching the "they look expensive" stock relays and redoing the lot with common garden variety relays but with a diagram I might find somewhere else to check first. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted July 7, 2015 Share Posted July 7, 2015 My money is on the switch. Can you open it up and give the contacts a tickle up with some sand paper? 1 Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted July 7, 2015 Share Posted July 7, 2015 I would agree with AllTorque on this one too Quote Link to comment Share on other sites More sharing options...
UTERUS Posted July 7, 2015 Share Posted July 7, 2015 http://www.aliexpress.com/item/WIPER-SWITCH-INDICATOR-SWITCH-FOR-TOYOTA-HIACE-1989-2006-LH1-RZH10-11/32247719105.html actually maybe this is closer to what you want http://www.ebay.com/itm/Indicator-Headlight-Blinker-Stalk-Switch-Hiace-LH50-LH51-LH61-LH70-LH71-1982-87-/400823526414?pt=LH_DefaultDomain_15&fits=Model%3AHiace&hash=item5d52f1a40e&vxp=mtr Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted July 7, 2015 Author Share Posted July 7, 2015 i was thinking the switch but when you move it between positions you can hear the relays click on and off. I think if it was the switch it would be less random. Aliens!? Edit- cheers simon. Ive actually got a complete spare switch unit from when we bought and stripped another LH66 for its engine etc. Sadly some idiot (me) didnt think ahead and cut through the cable before the multi plug. Why? Haste/stupidity.. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted July 7, 2015 Share Posted July 7, 2015 Yes but is it switching the right ones! Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted July 7, 2015 Author Share Posted July 7, 2015 Good point! I'll take it apart and have a look. Any ideas on where to find a wiring diagram? Free. Without links to porn/how to become a millionaire etc Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted July 7, 2015 Share Posted July 7, 2015 MAAAATE get out the multi meter and trace some wires. Must be like 3 wires in the whole van Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted July 7, 2015 Author Share Posted July 7, 2015 I get off on scanning them mazes. Quote Link to comment Share on other sites More sharing options...
UTERUS Posted July 7, 2015 Share Posted July 7, 2015 Plug in a relay that you know works. Not too uncommon for relays to burn out the contacts. 2 Quote Link to comment Share on other sites More sharing options...
UTERUS Posted July 7, 2015 Share Posted July 7, 2015 Alternatively, shove some wire in the relay socket to rule out dodgy relay. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted July 7, 2015 Share Posted July 7, 2015 Alternatively, shove some wire in the relay socket to rule out dodgy relay.You still won't know if the fault is in the relay or switch tho. Quote Link to comment Share on other sites More sharing options...
bigfoot Posted July 7, 2015 Share Posted July 7, 2015 if you get stuck for ideas il bring a switch from work to hamner Quote Link to comment Share on other sites More sharing options...
UTERUS Posted July 7, 2015 Share Posted July 7, 2015 You still won't know if the fault is in the relay or switch tho. Wat. If you operate the switch and the relay clicks, but the lights don't work then the relay contacts are toast. Putting a jumper across the two terminals in the relay socket can confirm this if the light bulbs and wiring to them is sweet. You may also set your multimeter to current setting and jam the probes in the socket. 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted July 7, 2015 Share Posted July 7, 2015 Oh yeah, if the relay clicks, go hard. Quote Link to comment Share on other sites More sharing options...
4AGEMAD Posted July 8, 2015 Share Posted July 8, 2015 https://www.dropbox.com/s/8cee0fl6mloj3mh/LN%20Hiace%20headlight%20switch%20wiring%20diagram%20.pdf?dl=0 Thank me later Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted July 8, 2015 Author Share Posted July 8, 2015 Oh cool- cheers man! With that and my multi meter, some coffee and sunshine Im sure i'll work it out. While on the subject of lights- ours hi ace has the square lights with sealed beams. They are useless. So bad Im tempted to drive at 4 mph and get hannah to walk in front with a lantern instead. I would like to have non sealed units with seperate bulbs so I can fit some decent wattage bulbs. Anyone got any ideas on cars/vans that might have the same units but not sealed. Otherwise Id love to change the grill over to the round headlight version and then I can get 8" non sealed units to fit. I much prefer the look of round lights on these hiaces anyways. Quote Link to comment Share on other sites More sharing options...
Lochky Posted October 7, 2018 Share Posted October 7, 2018 Hi everybody Im Stéphane, from France, happy owner of hiace 1987 4WD lh66. Very rare véhicule here but I know it’s more popular in NZ or OZ as I remember when I was there ;) At the moment I’m working on some upgrades in the van but I need to find the entire wiring diagram to organise my electrical modifications in better way. But... impossible to find it here and even on internet I spent an entire day trying to find it but without any success. May I ask you if you could help me if you have these diagrams somewhere ? Many thanks Stephane And this is my beast ;) 4 Quote Link to comment Share on other sites More sharing options...
4AGEMAD Posted October 11, 2018 Share Posted October 11, 2018 On 08/10/2018 at 09:09, Lochky said: Hi everybody Im Stéphane, from France, happy owner of hiace 1987 4WD lh66. Very rare véhicule here but I know it’s more popular in NZ or OZ as I remember when I was there At the moment I’m working on some upgrades in the van but I need to find the entire wiring diagram to organise my electrical modifications in better way. But... impossible to find it here and even on internet I spent an entire day trying to find it but without any success. May I ask you if you could help me if you have these diagrams somewhere ? Many thanks Stephane And this is my beast Ive got electrical diagram for LH10_, 11_ & 125 series if that helps 1 Quote Link to comment Share on other sites More sharing options...
Lochky Posted October 12, 2018 Share Posted October 12, 2018 That could maybe helps a bit as the logics are the same. Can you give me a link ? And if anyone knows about the original documents of this van, I will still be super happy to know it Quote Link to comment Share on other sites More sharing options...
