downtrail Posted July 7, 2015 Share Posted July 7, 2015 and test from the body of the ignitor to the case to confirm it is insulated correctly as one of the pins also shares the body can't remember what one. Should be using a plastic nut and bolt also to make sure it is insulated. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 7, 2015 Author Share Posted July 7, 2015 i haven't got a connector on hand at the moment, but i can bodge it up for a moment and see if it fixes the issue. will report back Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 7, 2015 Author Share Posted July 7, 2015 will have to wait to tomorrow when i grab a multimeter from work, but the BIP is fitted with a mica insulator, and a plastic collar on the screw to insulate, so fairly confident it shouldnt be the issue. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 7, 2015 Author Share Posted July 7, 2015 Yep removing the coil wire from the db37 has done it! i have spark now, and the engine even tried to fire. im not expecting it to actually run just yet, as the engine is timed on hopes and dreams, and ill be picking up my timing light this weekend. but ill probably have a decent play with it tomorrow afternoon if its not miserable like it is now. also, the coil doesn't seem to get warm now, i assume it was something to do with it constantly being earthed before. im a happy man, and one of the first places i go when its running will have to be over to your shop to drop off a box of beer or something, cant thank you enough downtrail! now to go bug the avionics guys tomorrow into finding me a little connector 1 Quote Link to comment Share on other sites More sharing options...
downtrail Posted July 7, 2015 Share Posted July 7, 2015 Good man yeah I believe thst most of thoose pins in that line are at earth potential On the 2.2 board. youll find the v3 boards are like that picture. You can see how the megasquirt has been given a bad name tho. little things like that make some people throw in the towel then procede to poo poo them from there on out. 1 Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 7, 2015 Author Share Posted July 7, 2015 oh yeah i agree with its false rap. you'd have the same problems if the Link came in kitset form too. ive found the 2.2 to be less well documented compared to the new versions, but really what do you expect, its older tech these days. but still gonna do exactly what i need! Quote Link to comment Share on other sites More sharing options...
downtrail Posted July 7, 2015 Share Posted July 7, 2015 yeah the 2.2 is technically obsolete but it still had a high enough demand that they continue to make em. Your right they are old technology but they work fine in a lot of situations where all you need to do is run the motor. When it comes time to get all fancy doing different bosst levels is different gears that's where the larger name ecus are handy Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 7, 2015 Author Share Posted July 7, 2015 i would like to have a go with that high level of control one day, but on my still carburated N/A engine, im already only using about 40% of the 2.2s capability haha. i am keen on little features like knock sensing and limiters/launch control but ill get the engine running first Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 7, 2015 Share Posted July 7, 2015 Good work Team, great to see this resolved! 3 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted July 7, 2015 Share Posted July 7, 2015 It was an adventure. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted July 7, 2015 Share Posted July 7, 2015 Must add that I'm looking forward to building and fitting another MS ecu. To me it's just that next fun level of learning and satisfaction of really 'building' your own car. If there are little bugs or hiccups there is always great help and advice on here to see one through. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 7, 2015 Author Share Posted July 7, 2015 i completely agree Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 15, 2015 Author Share Posted July 15, 2015 got my timing light on it and had it started up and running smoothly in a matter of minutes! aside from my oil pressure gauge popping its wire off and giving me a heart attack, first test drive went very well, even on the base map its gotten way smoother and a little more power. now to fit the extra bulkhead plug i got for the coil wire and tidy/fasten the loom in place and tinker with the spark map for a while! will update my build thread with pictures/videos pretty soon. also next week ill be able to take it for some timed 1/4 mile runs which should be great to see the results. 1 Quote Link to comment Share on other sites More sharing options...
downtrail Posted July 15, 2015 Share Posted July 15, 2015 Sweet hook your wideband into the megasquirt so you can log it against where your at in the map. You'll need megalog viewer to view the log files. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 15, 2015 Author Share Posted July 15, 2015 i need to get another threaded boss actually. the idiots who did my exhaust replaced that section of pipe and didst keep the boss Quote Link to comment Share on other sites More sharing options...
Testament Posted July 15, 2015 Share Posted July 15, 2015 get MSdroid and log on your phone then you get gps speed etc. too. maybe not the best refresh rate but still useful. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted July 17, 2015 Share Posted July 17, 2015 I can never get MSdroid to work properly with my phone (samsung note 2). Works for a short while then siganl goes. Plus every time I open the app the gauges are all funny/different sizes/in wrong place/missing. Ive uninstalled/re-installed several times and written to fella on MS forum but no luck. I wish the fella who developed TS would make it so his dashboard thingee also allows tuning. Quote Link to comment Share on other sites More sharing options...
Rookie Posted July 17, 2015 Share Posted July 17, 2015 I had trouble with the v2 msdroid, v1 worked mint, but then when I updated it stopped working. We tried a bunch of stuff and it worked fine with Toms phone, so I think it is a hardware incompatibility. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted July 17, 2015 Author Share Posted July 17, 2015 haven't had a chance to try the android app. but i have driven the car around a little and the engine is super crisp now, sounds phenomenal. its sitting on bricks now as the wheels are having new non fucked tires put on, then i can really take it for a thrash. and start to figure out how i should be adjusting the ignition map, though its not bad as is tbh Quote Link to comment Share on other sites More sharing options...
peteretep Posted July 19, 2015 Share Posted July 19, 2015 Ignition map should really wait for knock sensor and/or dyno Quote Link to comment Share on other sites More sharing options...
