  • Replies 109
15 hours ago, kempy said:
Pedals you dare not pedal unless you want to catapult yourself over the front as they are way too long and touch the ground, easily.
are they solid arms? cut em short, i have a left and right tap here for pedals.
plus it would be funny to have tiny little cranks
Not sure how the motor controller will act when you go over speed, it will likely brake or regen?
Can't you just get a non speed limited motor controller from AliExpress? Even one for an electric motorbike?
I suggest, slap a V meter on the battery and just see what happens when you overspeed it: I'd wild-arse guess the controller will just stop driving, but as long as it's not trying to brake/re-gen, then you should be able to ignore it and jet let the turbine(s) do their thing? If it's doing re-gen / braking, you'll see the volts climb.
