Frost Plug installation
Zeubin
Hello hello,
I am about to replace a leaking frost plug that leaked coolant all through my clutch assembly as below:
I am pretty keen for this to never EVER EVER happen again so would be keen on any advice regarding sealant or not sealant.
Has anyone done a few of these with or without sealant? what was the result?
Looking at other forums they use silicone but I thought i'd check out here just in case.
Thanks for reading
They shouldn't need sealant if the are installed correctly and don't distort or bend.
However in saying that I use a product from CRC called Aviation Gasket Sealant for all of my cooling system fittings.
So that's what I would use. But I'm sure using Three Bond sealant would do the job very well also.
