shrike Posted July 8, 2022 Share Posted July 8, 2022 @chris rare we taking bets on KWATW? Factory is meant to be what 112kw at the fly? So maybe 90-100kw atw stock? Did you have a factory dyno number? I'm guessing with the exhaust, better head, compression bump and a good tune (what fuel are you going to run?) Assuming you can run optimum timing for power (without knock) You might gain what 10-20kw atw? Quote Link to comment Share on other sites More sharing options...
chris r Posted July 8, 2022 Author Share Posted July 8, 2022 Yeah factory meant to be 110kw at the flywheel factory. Just running 95, if I sacrifice a bit of power so be it, it's intended to be a fun daily/I'm too cheap to pay for 98 all the time My crx made 115 wkw from memory (same dyno as this will be going on) , that was type r b18c so more compression and revs/it also had aftermarket cams. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post chris r Posted July 10, 2022 Author Popular Post Share Posted July 10, 2022 Dyno booked for Wednesday Rangi up a intake while I wait for the factory arm to arrive. I'll ask tuner to pull off factory airbox and see what gains/losses there are. I'll try and get the factory heat shield over the exhaust too, it'll need some trimming but will be nice to have it stock ish 11 1 Quote Link to comment Share on other sites More sharing options...
Popular Post chris r Posted July 13, 2022 Author Popular Post Share Posted July 13, 2022 Dyno run was a success. 107.4 wkw and 142 talks There is a slight air flow restriction up top but is is not the factory airbox/cheap filter combo which is interesting, could be the stock b20 throttle body Correction. The vortech/doort master intake pipe picked up power but it was still dropping back a cell in the map up top so the factory intake is not the restriction, most likely the stock 62mm b20 throttle body. Factory intake setup below 17 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted July 13, 2022 Author Share Posted July 13, 2022 Pretty stoked with that as it's a 300k+ bottom end rebuilt in the shed with a unknown Facebook marketplace head. No leaks or shitty noises. If I can find some b16a or type r cams I'll get more power all round but dont know if a cbf changing them when this works well enough 8 Quote Link to comment Share on other sites More sharing options...
chris r Posted July 14, 2022 Author Share Posted July 14, 2022 Factory intake arm arrived thanks brock/auto parts farm/I forgot your os name Fitted that and used a old bit of auto trans cooler hose as the rocker cover vent hose as the cabin gets pretty fumy (still need to do shifter cable grommets) Unsurprisingly my orb fitting didn't seal, good to know catch can is doing its thing though 5 Quote Link to comment Share on other sites More sharing options...
chris r Posted July 15, 2022 Author Share Posted July 15, 2022 Borrowed old works host. Driveshaft, new pads and rotors fitted. Heat shield stuff applied to firewall around shifter as the cat sits right below it I grabbed a shorter belt for the power steering and that now works 6 Quote Link to comment Share on other sites More sharing options...
Roman Posted July 15, 2022 Share Posted July 15, 2022 Did Jonno tune this? Quote Link to comment Share on other sites More sharing options...
chris r Posted July 15, 2022 Author Share Posted July 15, 2022 11 hours ago, Roman said: Did Jonno tune this? Yes he did, we were chatting after and mentioned he knew you Quote Link to comment Share on other sites More sharing options...
chris r Posted July 16, 2022 Author Share Posted July 16, 2022 Couple small things today. Fixed the door card fabric that's been flapping pretty much the while time I've owned the car Mounted the ecu Factory trim even fits back on Next on the list is to cut out a bit of metal to fill in the gap where the crv shifter boot doesn't quite match the orthia surround. Stock civic/orthia shift boots will be too short to fit and share a similar size hole to the auto shifter Just need to make some brackets for the headers to help support them and clean/drive it and see what else comes up. 8 Quote Link to comment Share on other sites More sharing options...
chris r Posted July 17, 2022 Author Share Posted July 17, 2022 Couple things have cropped up, srs light has made a appearance and didn't fix itself with a reset. I'll have to do some trouble shooting. Flash codes come out as 23, 13, and 12 2-3 short circuited To a Wire In Passenger's Inflatable Air Bag Module Or low Resistance 1-3 short circuited To a Wire In Driver's Inflatable Air Bag Module Or low Resistance 1-4 short circuited To 12 volt power or VSS. Driver's Inflatable Air Bag Module Also the cluster lights for the needles don't work so I'll need to pull the cluster out and investigate Quote Link to comment Share on other sites More sharing options...
mjrstar Posted July 17, 2022 Share Posted July 17, 2022 The clock spring in my EK was a pretty fragile ribbon cable sort of thing, that's the first place I would look. We'll that any any other yellow (or was it orange) electrical plug you might have played with. 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted July 17, 2022 Author Share Posted July 17, 2022 I'm leaning towards clock spring, I had the coloum out and didn't re center/check the clock springso I'm hoping that's the issue. I had the srs loom out when I was running the shifter cables and was super careful not to damage it 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted July 22, 2022 Author Share Posted July 22, 2022 Checked the loom, no visual damage at all checked everything for continuity/shorts and all good there, clock spring had continuity and no shorts so I'm guessing ecu shit the bed Grabbed a couple of bulbs from pap while I was there and fixed the cluster/not being able to see the speed needles at night Chucked some coolant in it as it didn't leak any of the water or make milkshakes Crimped/sorted the amp power wiring and made a new earth cable while I had the crimpers out 7 Quote Link to comment Share on other sites More sharing options...
chris r Posted July 24, 2022 Author Share Posted July 24, 2022 Did some reading and there is a manual srs reset process to follow, disconnecting battery isn't enough as it turns out Made up a button to help with that Success Got sick of not having the alarm control the locking so sorted that Had a look at the diagrams and there was a optional remote for this, checked and the drivers door had a factory motor in it which was nice. Had to probe the module but found the lock/unlock triggers Soldered the wires on and put it back in the case Now it works as it should https://i.imgur.com/t4YwJkj.mp4 9 Quote Link to comment Share on other sites More sharing options...
chris r Posted July 28, 2022 Author Share Posted July 28, 2022 So this happened again tonight Replaced the clock spring as I grabbed one when I was last at pick a part and it's the only part of the system that shares a 12v supply with something else (horn) Here's a edited version of the reset process so I can find it easier again next time 1st step in erasing the memory is to turn the ignition off and connect the tool/switch to the MES Plug 2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off. 3rd Disconnect tool/turn off switch within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again. 4th Reconnect tool/turn on switch within 4 seconds after SRS light comes on. SRS indicator light will go off. 5th Disconnect tool/turn off switch within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times. 6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. 3 Quote Link to comment Share on other sites More sharing options...
chris r Posted July 28, 2022 Author Share Posted July 28, 2022 The ac has been intermettent for a while and there was a old receipt for a repair on heater controls not working so I pulled it out and took it to the healing bench I suspected dry solder joints so had a go at them with the cheapie soldering iron. Yes best practise is to de solder and re solder everything but i don't have the energy/can't find the tools in the mess. Reflow and a bit of fresh solder in the mix will do the job for now Success (mostly) Annoyingly the illumination lights aren't working. I've ordered all the illumination bulbs for both parts from amayama as they were a couple of dollars each and being genuine I know they'll work fit/be right. 5 Quote Link to comment Share on other sites More sharing options...
chris r Posted August 21, 2022 Author Share Posted August 21, 2022 Re fixed the rust as I did a rush job last time and it crept back. Got some proper rust converter acid stuff this time Ran out of time to finish priming etc Grabbed a new set of cheap tyres no point in wearing out the 003 commuting. I've gone up to a 205 55/15 now. Speedo is only 10k out now not 20 Installed the mugen shocks I had in the shuttle Yeah na it's going to need a lot of rolling to even be close to not shredding the tyres. I put the stock stuff back in The fronts stick out even more so it'll stay stock height as I'm not cool enough to run stanceboy camber to fit it all in. 4 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted August 31, 2022 Author Share Posted August 31, 2022 The colour match isn't exactly right but it's silver so it'll do 7 Quote Link to comment Share on other sites More sharing options...
chris r Posted September 8, 2022 Author Share Posted September 8, 2022 Pood some seam sealer on it today Drivers seat foam had given up. I grabbed a passengers side at pick a part a while ago and was finally annoyed enough today to change it Seat out and replacement base Pulled the material off both so I can swap it over Yup foam isn't doing foam stuff any more 11ty cable ties for the material to go back on. It then went dark so I didn't get any pics of it going back together but it's in now and feels better. 5 Quote Link to comment Share on other sites More sharing options...
