Chris R's various honda thread including punishing modern non os daily driver updates
chris r
  • Replies 626
Info dump of manwell stuff while I've found it
) gearbox from CR-V (first gen) GF-RD1 4WD. Serial number of gearbox is SBXM. To find Orthia 4WD manual gearbox impossible. There were too small amount produced.
2) Pedals from Civic 6 gen (ek)
3) Starter from any B-series manual transmission, example DENSO (31200-P3F-J01)
4) Flywheel (22100-P75-005) with bolts (90011-PH3-000)
5) Clutch master cylinder (46920-S10-003) and clutch second cylinder (46930-SR3-013) also reservoir and pipes for fluid
6) shifting arm from CR-V, Orthia, Partner or Accord Euro R
7) clutch disk (22200-P3F-035) with clutch basket (22300-P3F-005) and bolts (90034-689-000)
8 ) engine mounts for mounting gearbox: rear (50827-S10-J00), upper (50825-S10-J01) and down (50843-S10-J00)
9) half-axel (44500-S10-000)
10) and rear t bracket gearbox (50827-S10-J00) can be used from CR-V
A quick look suggests crv stuff shares the same part numbers so if I grab axles/mounts/shifter/everything off the crv I should be good
  • 4 weeks later...
52 minutes ago, shrike said:
But did you let the fridge settle before you turned it on? and waiting on rear diff pics to conform AWDness :P
Yes the fridge is sitting on the back deck settling.
Will grab diff pics tomorrow. I eyeballed it today and can confirm it exists
4 hours ago, shrike said:
Same as the CRV drivetrain?
Yeah exactly the same as the CRV stuff, Gearbox/engine are the same too and share the same mounts so that makes stuff less difficult to get. The rear trailing arms are apparently different (as are wheel bearings after trawling the catalogues)
So B16/18 VTEC head/intake swap on the cards? (with ECU to suit)
