Popular Post chris r Posted February 28, 2024 Author Popular Post Posted February 28, 2024 Intake noises sound good (imo) with the vortex / 3d printed intake And final power run. Pretty happy with how the exhaust sounds, first time I've heard it from outside the car Solid red was old tune, dotted green is B16a intake cam with timing optimised. Dotted blue is the doort tube. So the factory airbox/filter is a 3kw drop I'm pretty happy with the midrange gains just from a cam swap. Final numbers were 107.8 fwkw @6905 rpm and 165.7 talks @6072 rpm. Tuned on 95. Static compression ratio should be 10.23:1 with the B18 head (vs stock 9.6:1 with the original non vtec head) 11 Quote
j.e.d. Posted February 28, 2024 Posted February 28, 2024 Those teddy bears are spinning pretty fast.. I think you should call it 107.8 fwtb instead of 107.8 fwkw 1 5 Quote
chris r Posted March 4, 2024 Author Posted March 4, 2024 Bum dyno says the orthia has more midrange and it certainly feels nicer to drive. The Mrs says it feels better too Had a few hours to work on the shuttle today. So younger me did think about removing the loom and put plugs inside so it was easy enough to disconnect. Not the tidiest work but its been functioning for 10 ish years like that so I must have done something right. I'll be redoing it all anyway The car is a mess as its storage/I've just thrown stuff in it Rare NZ new povo spec AC delete vent out The EF sedan evaporator bolted in nicely The low-pressure hard line even bolts up nicely I have two options for the low pressure/suction side, I can cut and attempt to braze the hose (with r134 connector) onto the ef hard line. Or see if I can get the flex line crimped onto the EF line and fit an R134 service port adapter 6 Quote
chris r Posted March 4, 2024 Author Posted March 4, 2024 @Raizer machined the cast v-band adaptor housing to fit/work with a v-band flange Sat the turbo in the engine bay now the Ac compressor is sitting there and there is more space than I was expecting, even with the stock manifold in place Plan is to have a coupler from the turbo into the intercooler The intercooler should (will one way or another) fit just in front of the vertical brace for the bonnet support behind the bumper 3 Quote
chris r Posted March 4, 2024 Author Posted March 4, 2024 I'll need to get the aircon condenser at least roughly in place with a idea on where the hoses need to go so I can figure out where the turbo and its plumbing can go. I'll most likely need to figure out some shrouds for the radiator etc and the intercooler. Never had an issue with the current radiator with its pusher fan but that is stock power levels and without an intercooler and ac condenser in front. I'll also need to figure out what size fan will fit on the back of the radiator. Depending on where the intercooler ends up sitting I might see if I can get a small fan for one side of it which we can control via ecu if temps get too high I spent a few hours looking through a Air Con catalogue looking at different sized condensers etc. Basically nothing OEM will fit nicely. I have found and ordered a universal 12"x16" condenser which should mount onto the front of my radiator nicely. Will see if I can pop to zebra tomorrow and with a bit of luck the Civic there will have a un butchered high side line from the evaporator to the receiver drier so I won't have to fuck around with brazing a bunch of hoses together I'll leave this link here so I can find it again later (all the fitting sizes etc - http://www.gpdtechtips.com/techtip136.html 3 Quote
chris r Posted March 5, 2024 Author Posted March 5, 2024 Had a chat to the local ac guys and they can't just re crimp the end of the hose. Need to replace the flexi hose and new crimps on both ends as the hose is a different size apparently. Bit more than I wanted to spend but atleast I know it'll be done properly and shouldn't leak. The sticker shock gave me a bit of encouragement to attempt the rest of the lines I must not be the only honda sicko wanting to reinstate aircon into their ef. Everything had been taken from the ef civic at zebra, I grabbed some lines off a ek civic as they are longer and looked like they'd be usable Among the lines I grabbed when I was at pick a part (fucking cunts for cutting them to degass them) the daihatsu lines had a nice block for the service port and pressure switch. I cut the lines off and drilled them out so I could fit my lines in and make it less difficult to braze them Took a few attempts One side leaked with the 0.5 psi my lungs could generate. Re braze that and the other side leaked so redid that too. Doesn't appear to be any more leaks now A bonus of using the ek lines is they match the receiver drier I already have 'in stock' that I got for the orthia. I don't like the pressure switch sitting on that block by the strut tower. I'll swap the blank off the receiver drier and install it on the receiver drier so it's nicely tucked away 3 Quote
chris r Posted March 6, 2024 Author Posted March 6, 2024 Orthia update. Done a few hundred km since the tune. Turns out more midrange torque/power means better economy. Best since the vtec conversion. The 7.8 L/100 was when it was stock auto non vtec The local ac shop redid the suction hose for me, was a bit more than I expected to pay but it's hopefully done right. I'll get a conversion fitting for the service port and let's hope that's it. 7 Quote
Willdat? Posted March 6, 2024 Posted March 6, 2024 6 hours ago, chris r said: Orthia update. Done a few hundred km since the tune. Turns out more midrange torque/power means better economy. Best since the vtec conversion. The 7.8 L/100 was when it was stock auto non vtec The local ac shop redid the suction hose for me, was a bit more than I expected to pay but it's hopefully done right. I'll get a conversion fitting for the service port and let's hope that's it. Pretty impressive, DOHC ZC Beagle was 10L/100km... Quote
chris r Posted March 11, 2024 Author Posted March 11, 2024 On 06/03/2024 at 20:58, Willdat? said: Pretty impressive, DOHC ZC Beagle was 10L/100km... My other sohc auto beagle is about the same as yours. I'll see if it stays like this for a while 1 Quote
chris r Posted March 11, 2024 Author Posted March 11, 2024 I went to go pressure test my brazed hose the other day and noticed I've damaged the sight glass so I'll need to re make that line or keep looking for a factory one 2 Quote
tortron Posted March 12, 2024 Posted March 12, 2024 3 hours ago, chris r said: I went to go pressure test my brazed hose the other day and noticed I've damaged the sight glass so I'll need to re make that line or keep looking for a factory one Size of sight glass? Perhaps a motorcycle master cyl replacement glass/oring would fit? I have a few bags of different size Quote
chris r Posted March 12, 2024 Author Posted March 12, 2024 5 hours ago, tortron said: Size of sight glass? Perhaps a motorcycle master cyl replacement glass/oring would fit? I have a few bags of different size Hmm possibly. This does look pressed in or some other wizardry My only worry with master cylinder glass is would it like the high pressures of the ac system Quote
tortron Posted March 12, 2024 Posted March 12, 2024 Yeah, is it on the high or low pressure side? They are are real tight press fit It otherwise looks the same to me. But idk Quote
chris r Posted March 12, 2024 Author Posted March 12, 2024 High side unfortunately. If low side I'd be tempted to give it a go Quote
chris r Posted March 14, 2024 Author Posted March 14, 2024 I saw some fittings cheap on AliExpress and they arrived in a couple of weeks which was a surprise. Ordered a bit of tube with the hope/plan to use it as a sleeve It even fits nicely in the compressor Very spenny hose fits and lines up as well The scumbag /barry in me is very tempted to cut the end of the factory hose and crimp or clamp onto the fitting. 1 Quote
chris r Posted March 19, 2024 Author Posted March 19, 2024 On 14/03/2024 at 20:07, 87creepin said: How much was the power steering hose? It's the low pressure ac line. Was $250 all said and done. From memory the last power steer hose I had made up was a similar amount 1 Quote
chris r Posted March 19, 2024 Author Posted March 19, 2024 I went on a barry rabbit hole and found out pretty much all 92-2001 small hondas (b and d series motors) all have the same ac compressor. I noticed the orthia has a nicer shaped discharge (heh) hose, the crv has the same shaped hose so I grabed one from pick a part. It brings the line closer to the chassis rail and away from potential turbo stuff. Found a service port adapter and valve removal tool on rock auto for cheap so got them with some other stuff I had coming. Now low side has a R134 service port, it took me a few attempts to realise I needed to remove the old valve before screwing that fitting on I also grabbed a high pressure line off a ba Falcon so I can use the service port off that or just use the line as sleeve. I also figured out the self install or diy ac line kits use oetiker or double ear clamps on their lines. Once the condenser arrives I plan to chop the crv condenser end off and use the ear clamps on one of the fittings I got off AliExpress. If it doesn't work it was a $30 experiment and I can still use the crv alloy shaped hose and braze a mior fitting onto it 1 Quote
chris r Posted March 27, 2024 Author Posted March 27, 2024 Condenser arrived today, dougs given his approval Fits in the space nicely, little bit of overhang so I'll need to figure out some shroud /bracket arrangements. From all the the info I found condenser ideally shouldn't be more than 13mm away from the rad so I can keep it nice and close 5 Quote
chris r Posted April 2, 2024 Author Posted April 2, 2024 I was poking around looking for bulkhead connectors and found a deutsch connector which looked nice and worked with the crimper I already own. Little bit more poking around on the Te connectivity website and saw a sample button next to a version of the connector, but more poking around and there were more products with a sample button. Apparently it is not too good to be true and everything arrived. Now comes the part where I hope my spreadsheet and counting was correct and I do actually have enough pins to do what I want 5 1 Quote
