So clutch master stuff
Crv on the left and s2000 on the right (gene) the s2000 need a spacer to be fitted to civics etc)
Left two are s2000 and right is the crv.
The crv has a shorter u clip and push rod.
I swapped the pushrods and u clip over. Will test fit tomorrow
  • Replies 719
Stripped the block this morning.
Looks super clean for 300 thousand
Bearings look a bit worn but not fucked
I'll need to do a bit of 'porting' on the oil drains on the vtec head so it matches up with the 2L bottom end
Trip to wash world to blast the worse of the oil sludge off
Onto the healing bench in my 'clean room'
Rangi de glaze
Yes I know I should mic everything and measure it blah blah.
If I don't measure it I don't know how bad it is so I can live happily in denial. My theory is it was running well enough and not making bad noises before so it'll be good enough to go back together as it was.
Vtec oil pump fitted
The aliexpress oil feed kit is as good as the manifold and valve compressor tool
Somehow the oil is meant to magic its way through that fitting on the block. Then through that fitting and into the head
The fitting also seperates the un filtered oil and filtered oil with fresh air and hopes so doesn't instill much confidence at all.
What did I expect for $50...
Glad I figured it out now rather than once everything was installed and on startup
  • Haha 2
Gave the pistons a bath in simple Green and exoff
Before on bottom and top after the first soak
Bit of scotchbrite and a pick for the ring grooves
Figured out the shift lights on the orthia/crv. Had to do some modifications to the indicator so it doesn't need the ecu/module doesn't need to be there
https://i.imgur.com/u8MT9Mv.mp4
Inhibitor wired up
https://i.imgur.com/ghxEWGn.mp4
On 13/03/2022 at 20:47, chris r said:
The neighborhood kids were screaming so I made some of my own happy noises with the grinder and flap wheel.
It's not vtec officer....
It's all ready for a couple coats of paint now, trying to decide between pink or purple, might go with both.
Pink plz with purple highlights on the Honda
Not shit oil fitting arrived
Openings for the oil feed are actually at the top of the fittingand are open and not obstructed
Past me loctite the fittings into the shit sandwich plate so they'll need to get warm to be taken out. Hopefully they aren't complete chinesium and strip on the way out
Fitted main bearings and crank today
Cheap and cheerful one size fits all rock auto bearings are within spec which is nice
Smidge bigger than 0.02 which is factory spec ish so that's a win
Will do pistons/rods/arp rod bolts tomorrow.
Attempted to fit oil pump today and managed to mangle that seal. Luckily I ordered another by mistake with my last amayama order so that should be here next week
  • Like 8
More clutch schenanagins
Circlip didn't want to come out nicely
The rod is a bit longer
But not long enough
Will rummage around in the bolt box tomorrow and see if I can find one long enough to barry to suit
bolt box came up a winner
bit of angle grinder/drill action and we are all good
crv hard line even fits pretty good
got correct rod bearings and clearances are what they are so I'm gonna send it
Assembles the rings onto the pistons, I lost my good ring compressor so grabbed a cheapie.... And paid the price. tap tap, piston feels a bit stuck so back it out and try again
Will have to order another ring set now which has ripped my undies
  • Sad 6
3/4 ain't bad. Mains and rods torqued to spec and it spins freely which is good zuX5qTu.jpeg
More spaghetti
Turned it into this. Vtec wire re run and run the reverse light wires
That's all I can do on the loom until I get the motor/box into the car. Those rings are holding up the process a fair bit
  • Like 9
Reinstalled the konis into the shuttle and put the yuck 17s off the orthia on
Got drivers side front in and realised that I've got two right hand side ef forks which sucks. I thought I had hoarded more but clearly not.
Did a service on the beagle and the 'you might need to keep a eye on it' oil leak did need a eye kept on it.
Both sides are that bad, it'll drip onto the drive shafts and go everywhere. Atleast it won't rust I guess
I nipped up the sump bolts which were a Smidge loose but not horrible
Wanged the phone down and had a look at what I could see.
I'm wondering if the $4 rock auto filter was weeping or if the oil cooler o ring has perished and is leaking.
I'll throw another bottle of stop leak and some degreaser at it then have a look later
Entertaining read.
Crikey - who would ever bother to spend so much effort swapping all those bits between several similar models, rewiring things and what not just to create a slightly better non-discript Japanese shopping car?!!...
:tongue:
  • Haha 5
Shrink wrapped the block so I could make some progress on everything else.
Barry crane setup and got the block in
Flywheel and clutch on/torqued up
After falling off the jack four times the gearbox just slid on with no dramas
Drivers cv/axle installed
  • Like 9
As the resident honda foamer, do you want this timing kit?
fits sohc and dohc from what i can gather. maybe D16a or something. belt, tensioner and 2 brackets
I ended up with it from somewhere along the line
pm me your address if you want it and ill post it
More wiring
Sat head on so I could figure out where plugs etc wanted to go
Intake for the same reason
Some split conduit and a roll abd a half of tape later
Vtax wire is pinned into the ecu, reverse light switch wires are run to the plug and I'll pick a couple of wires from the inhibitor/auto stuff that I can repurpose for the lights.
I grabbed a jaycar speedo corrector as the crv has a different final drive etc and it'd be nice to have a correct speedo.
Other ring set arrived from rock and my dipstick and some seals arrived from amayama
Got a decent list of stuff to do tomorrow, hopefully I can get most of it done and have it drivable in a week, my tuner only has a small window of time and I start a new job in a couple of weeks so it'd be nice to have everything done before then/before I loose access to the hoist at my current job
  • Like 9
Got the bottom end assembled, windage tray and oil pickup on. Sump gasket pood onto the sump with black schmoo like factory.
Replaced bypass spring and valve as it was cheap enough
Had a cunt of a time with the crank seal in the oil pump, after about 10 attempts I got it in properly.
Attempted to wrinkle black the rocker cover. Etch primed it in the paint booth and peaked there
Sat the head on and test fitted the cheap headers, I'll get away with a 2.5" 90 bend off them and it'll line up nicely with the rest of the exhaust. Hopefully I can move the cat up and fit the reso and flexi in
Unsurprisingly the dowel pins that came with aliexpress kit are shit, flop around in the head and don't for the block or the head bolts.
Fitted the shifter cables and sat the crv shifter in to see where stuff wants to sit. I'll need to very carefully drill the firewall and miss the heater core and ducting.
I can pretend I'm a rally/race driver as the crv shifter is super tall
Mounted the oil feed plate to feel better about fighting the rings and crank seal today
