  • Replies 719
Thanks @brocky41 for the deal on the glass and surrounds. All installed and water tight now
Sold the euro r (took my amp and speakers out)
Installed sound deadening and used Industy standard techniques to install the speakers
I need to find some decent 6" for the front. I incorrect measured and ordered 5.25 which were out of stock luckily
That's a pretty likeable father to be honest.
Also what's the main relay like? If you plan on keeping it for a lot of kms I have a new one laying about, sometimes the resoldering is only good for x amount of ks, may or may not fit as its for older honduhs..
Yeah I got good wholesome dad vibes from that note. Dad was probably paying for aa to look after the car too.
Main relay has been fine so far (touch wood)
Could be keen on it for the shuttle though
Send me pics of yours and I'll take a look at mine and see if it'll work. I got it for the lude because the original was too far gone. It should work as I used an ef part no.
Fixed the dizzy o ring and cam seal o ring so should fix those leaks. Did plugs and leads too while it was apart
Did the sound deadening on the passengers door
They have a cast Ali chamber on top for reasons? Maybe increase plenum volume or reduce doort noises?
One of the earlier pics has shows the plenum sitting on top
Mixed success at pick a part. Soneone beat me to the manual crv so that saved me some money.
I grabbed the flywheel and a pedal box for hording though.
Nabbed a set of pioneer speakers and nz new radio for the accord and nabbed the washer bottle cap as the old one was fucked
Front speakers finally arrived for the orthia
Had to trim the mounting tabs so they would fit
Holes don't perfectly line up but they are attached
Amp fits perfectly under the seat which is good. Until you need to tune it
  • Like 8
New old stock sub for more doof
Went 10" as it needs a smaller box so will be easier to live with. The 12" takes up most of the boot space
Nz new radio and trim fitted. Goes hard for what it is now.
Had air conditioning regased today. The compressor is fucked and had black poo all through the lines. It kinda works on the motorway now. Will Rock auto a tx valve, filter and seal set over and find a compressor locally then find some caring and will clean the lines and condenser out in the future
The gc who did the regas noticed a coolant leak.
Clearly I missed that spring clip.
It must have popped off on the drive over as it was still dripping. Didn't get hot or cold on the gauge. Refitted and refilled and it's as good as it was
  • Sad 1
8 minutes ago, 87creepin said:
How much was the regas? Cold air sounds lush
Dude quoted 160 but did me a solid as compressor was fucked/ill have to go back for another regas once I fix everything
Kashmir Auto Repairs shop in mt Roskill. Really good service and dude was a solid gc
1 hour ago, 87creepin said:
That's a good price. Tempted for the daily to have nice cold air so im not sweating my tits off. Haha
Do it. Its so worth it. The other two hondas have working ac and it's so nice
