The Dude Posted September 20, 2021 Posted September 20, 2021 Im looking forward to driving this fine car home, providing it runs 1 Quote
chris r Posted September 20, 2021 Author Posted September 20, 2021 Oh and a massive thanks to @The Dude for arranging collection etc etc 2 Quote
mjrstar Posted September 20, 2021 Posted September 20, 2021 What you are saying is that you have the parts to do a K swap yeah? 6 Quote
chris r Posted September 21, 2021 Author Posted September 21, 2021 4 hours ago, mjrstar said: What you are saying is that you have the parts to do a K swap yeah? I wish. The motor is the cheap part Quote
chris r Posted September 24, 2021 Author Posted September 24, 2021 Fresh crisp wof gee.  Clean sheet even  Now for sale. 3k firm for osgc but will chuck it on Facebook for 3.5 2 Quote
chris r Posted September 25, 2021 Author Posted September 25, 2021 Info dump of manwell stuff while I've found it ) gearbox from CR-V (first gen) GF-RD1 4WD. Serial number of gearbox is SBXM. To find Orthia 4WD manual gearbox impossible. There were too small amount produced. 2) Pedals from Civic 6 gen (ek) 3) Starter from any B-series manual transmission, example DENSO (31200-P3F-J01) 4) Flywheel (22100-P75-005) with bolts (90011-PH3-000) 5) Clutch master cylinder (46920-S10-003) and clutch second cylinder (46930-SR3-013) also reservoir and pipes for fluid 6) shifting arm from CR-V, Orthia, Partner or Accord Euro R 7) clutch disk (22200-P3F-035) with clutch basket (22300-P3F-005) and bolts (90034-689-000) 8 ) engine mounts for mounting gearbox: rear (50827-S10-J00), upper (50825-S10-J01) and down (50843-S10-J00) 9) half-axel (44500-S10-000) 10) and rear t bracket gearbox (50827-S10-J00) can be used from CR-V  A quick look suggests crv stuff shares the same part numbers so if I grab axles/mounts/shifter/everything off the crv I should be good 3 Quote
chris r Posted October 20, 2021 Author Posted October 20, 2021 Nothing like a midnight delivery/pickup Still wof until December so that's a win. Will give it a look over after work today 4 Quote
chris r Posted October 20, 2021 Author Posted October 20, 2021 That sticker is the reason I bidded Mrs Chris r took it for a spin around the block and we did some wagon stuff Couple of bits of rust starting around the boot It'll need gaskets as it leaks oil pretty bad 3 Quote
shrike Posted October 20, 2021 Posted October 20, 2021 But did you let the fridge settle before you turned it on? and waiting on rear diff pics to conform AWDness 2 Quote
Raizer Posted October 20, 2021 Posted October 20, 2021 4 minutes ago, shrike said: But did you let the fridge settle before you turned it on? and waiting on heli vids to conform AWDness  1 Quote
chris r Posted October 20, 2021 Author Posted October 20, 2021 52 minutes ago, shrike said: But did you let the fridge settle before you turned it on? and waiting on rear diff pics to conform AWDness Yes the fridge is sitting on the back deck settling. Will grab diff pics tomorrow. I eyeballed it today and can confirm it exists 1 Quote
chris r Posted October 20, 2021 Author Posted October 20, 2021 49 minutes ago, Raizer said:  Reverse donuts? 1 Quote
chris r Posted October 20, 2021 Author Posted October 20, 2021 2 hours ago, tortron said: Ol 2 pump Chris On a good day Quote
chris r Posted October 21, 2021 Author Posted October 21, 2021 Can confirm diff is presen and correct and does diff things https://i.imgur.com/CJ5GDiz.mp4 Be amazed by the powah  I'm pleasantly surprised at how clean it is. Rocker cover and cam seal are leaking but easy fix 5 Quote
87creepin Posted October 22, 2021 Posted October 22, 2021 Honda have been using the same power steering and washer reservoirs for 30+ years, my 87 ba5 had the same. I also don't miss the engine being the wrong way round Quote
chris r Posted October 22, 2021 Author Posted October 22, 2021 30 minutes ago, 87creepin said: Honda have been using the same power steering and washer reservoirs for 30+ years, my 87 ba5 had the same. I also don't miss the engine being the wrong way round If it ain't broke don't fix it lol 1 Quote
shrike Posted October 23, 2021 Posted October 23, 2021 On 22/10/2021 at 09:48, chris r said: Can confirm diff is presen and correct and does diff things https://i.imgur.com/CJ5GDiz.mp4 Be amazed by the powah  I'm pleasantly surprised at how clean it is. Rocker cover and cam seal are leaking but easy fix Same as the CRV drivetrain? 1 Quote
chris r Posted October 23, 2021 Author Posted October 23, 2021 4 hours ago, shrike said: Same as the CRV drivetrain? Yeah exactly the same as the CRV stuff, Gearbox/engine are the same too and share the same mounts so that makes stuff less difficult to get. The rear trailing arms are apparently different (as are wheel bearings after trawling the catalogues) Quote
shrike Posted October 24, 2021 Posted October 24, 2021 21 hours ago, chris r said: Yeah exactly the same as the CRV stuff, Gearbox/engine are the same too and share the same mounts so that makes stuff less difficult to get. The rear trailing arms are apparently different (as are wheel bearings after trawling the catalogues) So B16/18 VTEC head/intake swap on the cards? (with ECU to suit) Quote
