scooters Posted July 30, 2017 Posted July 30, 2017 2 minutes ago, kiwi808 said: Oh yeah, I totally fucked my one. See this is why I can't have nice things. 1 Quote
scooters Posted July 30, 2017 Posted July 30, 2017 3 minutes ago, kiwi808 said: Oh yeah, I totally fucked my one. see this is why I can't have nice things. Quote
Willdat? Posted July 30, 2017 Posted July 30, 2017 1 hour ago, scooters said: see this is why I can't have nice things. http://www.trademe.co.nz/motors/used-cars/honda/auction-1383211105.htm Not exactly nice - but strip the plasti-dip off the wheels and you'll be period correct as... edit: Just had to check if it had a monster-tacho, you betcha! Quote
scooters Posted July 30, 2017 Posted July 30, 2017 32 minutes ago, Willdat? said: http://www.trademe.co.nz/motors/used-cars/honda/auction-1383211105.htm Not exactly nice - but strip the plasti-dip off the wheels and you'll be period correct as... edit: Just had to check if it had a monster-tacho, you betcha! There is is Hi octane 2 spec. dead give away with the mesh in the rear bar. I wont even talk about paint and wheels. It's making the meth worms itch in my arms a little. Quote
chris r Posted July 31, 2017 Author Posted July 31, 2017 On 7/30/2017 at 22:44, scooters said: There is is Hi octane 2 spec. dead give away with the mesh in the rear bar. I wont even talk about paint and wheels. It's making the meth worms itch in my arms a little. Fuck thats horrid. Notice the china manifold thats had a whole packet of filler rods thrown at it Here is a slightly less horrible one http://www.trademe.co.nz/motors/used-cars/honda/auction-1379740387.htm Quote
scooters Posted August 1, 2017 Posted August 1, 2017 21 hours ago, chris r said: Fuck thats horrid. Notice the china manifold thats had a whole packet of filler rods thrown at it Here is a slightly less horrible one http://www.trademe.co.nz/motors/used-cars/honda/auction-1379740387.htm In my eyes the only manifold that should exist for turbo 4 bangers is the rams horn header. EDIT.... stainless or steam pipe. 1 Quote
chris r Posted August 1, 2017 Author Posted August 1, 2017 5 minutes ago, scooters said: In my eyes the only manifold that should exist for turbo 4 bangers is the rams horn header. EDIT.... stainless or steam pipe. nah mayte cast factory shit with adaptor is how I roll. Want to make me a nice one lol 1 Quote
scooters Posted August 1, 2017 Posted August 1, 2017 3 minutes ago, chris r said: nah mayte cast factory shit with adaptor is how I roll. Want to make me a nice one lol Sure i'll go get my arc welder warmed up. What are the runner lengths you require? 3 Quote
chris r Posted August 1, 2017 Author Posted August 1, 2017 mayte no need for a welder I've got some jumper leads here 1 Quote
scooters Posted August 1, 2017 Posted August 1, 2017 3 minutes ago, chris r said: mayte no need for a welder I've got some jumper leads here There is nothing on Earth like the rage thats starts within me when the welder makes the sub audible hum when the shitty wet old sticks get stuck trying to get the arc started on the thing iv tried to weld for the 17th time running. 1 Quote
chris r Posted August 1, 2017 Author Posted August 1, 2017 14 minutes ago, scooters said: There is nothing on Earth like the rage thats starts within me when the welder makes the sub audible hum when the shitty wet old sticks get stuck trying to get the arc started on the thing iv tried to weld for the 17th time running. Tell me about it. It's nothing like the rage of no arc striking at all on the 20th time because the welder has given up 1 Quote
chris r Posted October 19, 2017 Author Posted October 19, 2017 Just a note with these repro tanks, the EF8 fuel sender doesn't fit nicely. I used a non vtec Ef sender in its place as the fuel light section of my one doesn't work. I'll make a up a voltage switching thingee to turn on the fuel light when its low Nice new tank And everythign installed And because everyone likes basic maintenance photos here is one of a replacement thermostat. I just need to let the loctite chooch and I can fire it up 2 Quote
tortron Posted October 19, 2017 Posted October 19, 2017 Hey M8 im currently making up some of these, and you just select a zener diode to match your low fuel voltage (diagram is missing an earth from chip pin 4) have a bunch of extra components if you like 2 Quote
chris r Posted October 19, 2017 Author Posted October 19, 2017 Hmm I'll do some testing and see how the factory fuel light actually works Quote
chris r Posted October 21, 2017 Author Posted October 21, 2017 I swapped the dash today with one that doesn't have holes all through it. while it was out I swapped the ac evaporator box for a nz new non ac duct so save a bit of space. The high pressure side of the fuel system is all good. I'm not sure if the filler tube is not properly sealed or if it was water leaking out when I filled it but I'll check that out tomorrow. I few more test drives and a final check over and its ready for the dyno. I will need to replace the rear muffler as it is still too loud ofr this old man It took a while to figure out why I couldn't pull it out even though all the bolts were removed, then I saw this. At least the screen won't leak I guess 1 Quote
chris r Posted October 22, 2017 Author Posted October 22, 2017 Got rid of the crappy bumper with the cutout for the big bore Quote
chris r Posted October 23, 2017 Author Posted October 23, 2017 I picked up a few bits today, spare seat rails, radio surround and bumper supports. It'll be nice not to have screws doing through the bumper and guard holding stuff together Quote
flyingbrick Posted October 23, 2017 Posted October 23, 2017 On 19/10/2017 at 21:19, tortron said: Hey M8 im currently making up some of these, and you just select a zener diode to match your low fuel voltage (diagram is missing an earth from chip pin 4) have a bunch of extra components if you like Hey man. Should just use an arduino nano. Probably cheaper and infinately more variable. Quote
tortron Posted October 23, 2017 Posted October 23, 2017 9 hours ago, flyingbrick said: Hey man. Should just use an arduino nano. Probably cheaper and infinately more variable. Total board was like $1 and a pack of standard zenner diodes is fine for estimating a few L left Don't complicate it 1 Quote
