piazzanoob Posted May 24, 2020 Share Posted May 24, 2020 unfortunately its all the small finishing off bits that take all the time to get nice. so close but so far away right 2 Quote Link to comment Share on other sites More sharing options...
Kiwibirdman Posted May 25, 2020 Author Share Posted May 25, 2020 You are not wrong. A year ago I said Put it together, get @cletus to certify and get it registered. Easy, should be done in no time! Still not finished.Its's amazing how much time goes on little bits. I can't believe the amount of time that I have spent on wiring. Windscreens are booked for Thursday, getting close. 1 Quote Link to comment Share on other sites More sharing options...
sheepers Posted June 15, 2020 Share Posted June 15, 2020 The injectors are probably just stuck, happens all the time. Just give them a bit of a wack then pulse them with 12 volts off the battery with a couple of fly leads. They should free up. 2 Quote Link to comment Share on other sites More sharing options...
igor Posted November 8, 2020 Share Posted November 8, 2020 Looking good. The wheels suit it. Like that you've retained the factory 'special' badges. It certainly is. 2 Quote Link to comment Share on other sites More sharing options...
1964Holden Posted November 16, 2021 Share Posted November 16, 2021 Hi, Your EJ looks awesome! I have an EH wagon I'm building and am up to the brake booster puzzle, I sourced a VS Commodore booster as people had recommended it but seems too big to me. I know that the bonnet hinge can be modified but it looks to me it'll also contact the inner guard if I line it up with the original push rod. Any ideas? I'm also looking at the VPW ones you used, did your line up/connect to the original push rod location? I was also wondering if standard master cylinders fit the VPW boosters eg Willwood or Commodore? Cheers Quote Link to comment Share on other sites More sharing options...
Kiwibirdman Posted November 17, 2021 Author Share Posted November 17, 2021 1 hour ago, 1964Holden said: Hi, Your EJ looks awesome! I have an EH wagon I'm building and am up to the brake booster puzzle, I sourced a VS Commodore booster as people had recommended it but seems too big to me. I know that the bonnet hinge can be modified but it looks to me it'll also contact the inner guard if I line it up with the original push rod. Any ideas? I'm also looking at the VPW ones you used, did your line up/connect to the original push rod location? I was also wondering if standard master cylinders fit the VPW boosters eg Willwood or Commodore? Cheers Funnily enough I was about to drag this thread up from the dead. After the car came back from the final cert inspection it got parked with a cover over it and ignored. A couple of days ago I fitted a horn, adjusted the bonnet stops and got it ready for compliance. Its booked in tomorrow, so wish me luck. To answer your question, it is not possible to used a booster and keep the original brake pedal location. I used the clutch pedal and bent it over to the right and then used a commodore automatic foot plate and rubber. This has to be TIG welded and the crack tested. The 7 inch booster does bugger all, at some point I might get an 8 inch dual diaphragm and swap it out. I also ended up stealing the master cylinder off my 1968 firebird because it has exits on the right hand side and is very narrow. The bolt pattern on the booster is standard GM. Also to get a brake light switch I used a Willwood distribution block with a light switch and built in proportioning valve. To pass the brake test I had to get some really good pads and the proportioning valve is not used. I guess I could wind it in for doing burnouts. Send me a PM if you need any more info. 1 Quote Link to comment Share on other sites More sharing options...
j.e.d. Posted November 17, 2021 Share Posted November 17, 2021 would be great to see an update mate Quote Link to comment Share on other sites More sharing options...
Kiwibirdman Posted November 17, 2021 Author Share Posted November 17, 2021 Once the Holden cam home from the certifier it got parked and pretty much ignored. I started on my Firebird, the wife gave me some budget after Americarna and then I bought a new to me motor bike. I really should start a build thread on the Firebird. 3 Quote Link to comment Share on other sites More sharing options...
j.e.d. Posted November 23, 2021 Share Posted November 23, 2021 yes please.. you've had that a while now.. I admire long term car ownership, something I aspire to & regret the older I get 2 Quote Link to comment Share on other sites More sharing options...
grunta Posted November 24, 2021 Share Posted November 24, 2021 so... Wagnats.... 1 1 Quote Link to comment Share on other sites More sharing options...
Kiwibirdman Posted November 25, 2021 Author Share Posted November 25, 2021 If I can get it registered and get out of Auckland yes. 3 Quote Link to comment Share on other sites More sharing options...
