flyingbrick Posted January 30, 2015 Share Posted January 30, 2015 Tech Article Do you still have to shrink the perimiter if you were to use a bead roller and stop shy of the edge? Quote Link to comment Share on other sites More sharing options...
JoKer Posted January 30, 2015 Share Posted January 30, 2015 I cant help but mention "basic" went out the window as soon as you clamped it in a folder #knowwhatimean 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted January 31, 2015 Author Share Posted January 31, 2015 Yeah hahaha. a fingerbrake probably costs more than a bead roller. Gosh I'd love a swaging machine Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted January 31, 2015 Share Posted January 31, 2015 Do you still have to shrink the perimiter if you were to use a bead roller and stop shy of the edge? i have only used one twice and did not shrink anything, this does not mean that it does not need to be done though, just not in my very limited experience. 1 Quote Link to comment Share on other sites More sharing options...
NickJ Posted January 31, 2015 Share Posted January 31, 2015 I have a panel in the boot to replace, have been unsure how to do it nicely, this post was good timing if I ever saw it, cheers and thank you! Quote Link to comment Share on other sites More sharing options...
JasonK Posted January 31, 2015 Share Posted January 31, 2015 Tech Article Do you still have to shrink the perimiter if you were to use a bead roller and stop shy of the edge? No you shouldn't need to Quote Link to comment Share on other sites More sharing options...
Nominal Posted January 31, 2015 Share Posted January 31, 2015 I had to heat and flatten the ends of this firewall panel around the ends of the beading. Another way around it is to pre-stretch the beaded area. It also depends on whether you need the peice to be totally flat when done. Running the bead right across then shrinking the end bits worked for me. Quote Link to comment Share on other sites More sharing options...
