64 Valiants 68 VW Beetle
64valiant
yeah it is the plan. i hate points and all that extra stuff as well.
change my ap5 over to electronic and boy what a change!!! so amazing!!!!!!
but fark i need to fix some bloody oil leaks.
thing leaks like hayholes mums box after a night with bigvalve (everyone can fill it with there own description)
  • Replies 497
fuck man, you know these are the easiest engine in the world to remove right?
4 bolts and yank.
4 bolts and yank would be easy if i knew that. still learning things with this. the closer and closer i look at this the rougher and rougher it is from the dude before me. i will fix it correctly dont you worry :)
Rough. just rough. You obviusly dont have any respect for this thing so Ill take it off your hands for you.
Dont drill any more holes in it or cut shit off for gods sake.
yea it was but dont worry il fix the hole.
and not with a grommet.
its no where near what i want as a finished product so there are a lot of things i want to do/clean up. huge list. il get there and clean it up one day. but for now its sweet and lol il cut holes if i want :) its the same with my wagon. il do them up for me not for someone else. might take the long way around but il get there.
these are the two cars that il base mine off eventually
1891281_592298664180071_1541283149_n_zps
a hole lot of work to get where i want to be. i plan on having it for a while.
for example
this is the gap between drivers door and roof
the lovely paint job he gave it with a rattle can
spot the red in this one and the bog
random hole.....
and i didnt drill this one
this guard where the bumper broke is munched
and check out how well the guards line up at the front
so dont worry i didnt pay the likes of 10 grand for it. and its not the mintest one out there at all but its some where to start and something i can work on and fix how i like when i like :)
yeah fully, I would have been pissed if it was a 55 or something, but I realize it an't a minter.
just trying to save you some work in the long run.
Feel free to ask any questions, I've a wealth of useless infomation.
the drivers door always sag, you can get over sized stainless hinge pins, once you get the old ones out.
this is what you need to remove the old pin
I drilled mine out, which is quite a mission but worked, till I did the bottom one. I removed the running board, jacked the car up and drill from below, I forgot the car was on a angle and drilled out the side of the hinge, another thing I still need to fix!
