Popular Post sleeektoy Posted May 27, 2021 Author Popular Post Share Posted May 27, 2021 10 days ago it emerged into the sunlight .. very bright and shiny Delivered to the shed and straight into reassembly 48 Quote Link to comment Share on other sites More sharing options...
Popular Post sleeektoy Posted June 8, 2021 Author Popular Post Share Posted June 8, 2021 More reassembly progress 23 1 Quote Link to comment Share on other sites More sharing options...
Popular Post sleeektoy Posted July 25, 2021 Author Popular Post Share Posted July 25, 2021 I decided the engine bay looked crud against the new paint, soo... engine out, strip the front suspension and steering etc. 15 Quote Link to comment Share on other sites More sharing options...
Popular Post sleeektoy Posted September 13, 2021 Author Popular Post Share Posted September 13, 2021 Loud pedal floor repair - now i can really mash it without fear of pushing it through the floor Cleaned all the remaining crap off the floor and blinged it up a little And sand, sand, sand all the engine bay paint 15 Quote Link to comment Share on other sites More sharing options...
Popular Post sleeektoy Posted September 20, 2021 Author Popular Post Share Posted September 20, 2021 Bay primer done 16 Quote Link to comment Share on other sites More sharing options...
Popular Post sleeektoy Posted October 17, 2021 Author Popular Post Share Posted October 17, 2021 Finally got the red onto the engine bay 19 Quote Link to comment Share on other sites More sharing options...
Popular Post sleeektoy Posted November 7, 2021 Author Popular Post Share Posted November 7, 2021 Throwing it all back in as much as i can. Awaiting some brake parts (fittings/booster) and some more plating and then it will be progressed more. 19 Quote Link to comment Share on other sites More sharing options...
Popular Post sleeektoy Posted November 14, 2021 Author Popular Post Share Posted November 14, 2021 Booster and brake plumbing all done - I previously deleted the bias valve and replaced it with a wilwood adjustable, and upgraded the master to a bigger MA70 one Brakes all round means the front steering and suspension is all in too I previously disliked the wiring and relay/fuse for the electric fan As the alternator is internally regulated now - I figured up-cycle the old regulator housing to sneak the fan gubbins in... Next mission is to test fit the bigger W55 gearbox and apply clearance to any parts, and run a return fuel line that also clears it. Then onto checking the engine and see what needs freshening on it. 18 Quote Link to comment Share on other sites More sharing options...
Popular Post sleeektoy Posted May 18, 2022 Author Popular Post Share Posted May 18, 2022 Long time update: Gearbox fitted, and engine dismantled for some tricks and refresh Testing a 3D print timing gear drive for bottom end 16 Quote Link to comment Share on other sites More sharing options...
Popular Post sleeektoy Posted January 9 Author Popular Post Share Posted January 9 So... a little yarn at @sheepers place about his motor build and also borrowing a large valve spring compressor from him inspired some work on the motor for this. It has sat a long time and nothing was done - the gear drive became a "too hard basket" and i got put off trying to get it sorted. So it has a chain put back in there for now. There were valve to piston clearance issues with cam timing and some light touching happened. Big end bearings are now replaced, cam lifter buckets replaced and valves checked for bentness found to be ok. So in a "roadkill garage" style fix(found on youtube), an old stainless valve was fashioned into a rough as guts cutter and piston cutout reshaping has been done. Result is a nice reshaping of the cutouts slightly bigger at the same time - the engine has been blinged up to go into the nice clean engine bay 21 Quote Link to comment Share on other sites More sharing options...
Popular Post sleeektoy Posted January 11 Author Popular Post Share Posted January 11 Engine mostly assembled - water pump, alternator, and flywheel/clutch still to sort. Headers might get an acid dip and repaint too. trial of a Kameari 2T-GEU cam chain tensioner in this 18R-GEU head also happening 17 1 Quote Link to comment Share on other sites More sharing options...
Popular Post sleeektoy Posted February 14 Author Popular Post Share Posted February 14 Finally bunged it back in the hole. Carbs to have a birthday, extractors to be stripped/coated and driveshaft needs shortening +10,000 other small things 17 1 Quote Link to comment Share on other sites More sharing options...
