Nominal Posted Tuesday at 18:25 Posted Tuesday at 18:25 What's this doodad under my Toyota @AllTorque? Quote
AllTorque Posted Tuesday at 19:34 Posted Tuesday at 19:34 Good question. Maybe a vacuum accumulator for engaging 4WD? Where do the vacuum lines go? 1 Quote
Nominal Posted Wednesday at 04:01 Posted Wednesday at 04:01 Why yes I can, there are a lot of possibilities but @AllTorque nailed it. 1 Quote
Nominal Posted Wednesday at 04:05 Posted Wednesday at 04:05 Backstory is that I was out in the hills a few weeks ago and bounced up a fairly rough track and forward progress stopped. It would still run but not very well so I ended up getting towed up. Was OK along flat/downhill but no power uphill. When I got out of the forest it had a big backfire and seemed fine after that mostly, I drove home from Whangamata to Waihi with no further drama until close to home. Has been unused until now but seems fine driving around locally. I'd like to find something to fix really, will get a new set of plugs and leads (if I can). Have been looking around for vac leaks. 3 Quote
HighLUX Posted Wednesday at 08:09 Posted Wednesday at 08:09 Intermittent vacuum leak or it stirred up the crud in the tank doing some hektic 4wd stz which got thru the filter and made things sad? 3 Quote
Nominal Posted Wednesday at 08:32 Posted Wednesday at 08:32 21 minutes ago, HighLUX said: Intermittent vacuum leak or it stirred up the crud in the tank doing some hektic 4wd stz which got thru the filter and made things sad? Had a good look at that vac tank and valves, looks OK but I don't have a vac pump to check, will see about getting one / aliex. Did wonder if that might be the issue since it seemed OK in 2WD. Fuel filter is on the hit list too. Quote
HighLUX Posted Wednesday at 08:49 Posted Wednesday at 08:49 Being Ok in 2wd would point to something with the vac stz for the 4wd since it ran like shit when trying to do 4wd stuff. I remember 90s surf stuff having vac actuated front diff carryon that would fail but being a diesel you didnt experience the same symptoms as a petrol with a vacuum leak. Could be worth a google about surf vacuum 4wd stuff as its probably the same system in a different package 1 Quote
h4nd Posted Friday at 19:43 Posted Friday at 19:43 I'm sure I said I was gonna stop diagnosing and fixing other peoples shitty products? Anyway, added some decoupling caps that should have been there, and now the shitty internet plug switches shit. and doesn't reset and forget all its settings every couple of days. Side note, the PCB safety separation design was surprisingly good. The wiring to the socket: so - so. 3 Quote
Nominal Posted yesterday at 06:47 Posted yesterday at 06:47 On 04/11/2026 at 17:05, Nominal said: Backstory is that I was out in the hills a few weeks ago and bounced up a fairly rough track and forward progress stopped. It would still run but not very well so I ended up getting towed up. Was OK along flat/downhill but no power uphill. When I got out of the forest it had a big backfire and seemed fine after that mostly, I drove home from Whangamata to Waihi with no further drama until close to home. Has been unused until now but seems fine driving around locally. I'd like to find something to fix really, will get a new set of plugs and leads (if I can). Have been looking around for vac leaks. New plugs, replaced plastic fuel filter. Put a vac guage into the line that feeds that reservoir and it seems to be behaving fine. 4WD switching works as expected. Took it for a blat down the beach and a short gravel rd 4wd run and it seems fine so I dunno. Got a new set of leads on order from Amayama. Plan is to head down Taumarunui was in a few weeks for some more offroading so will find out then I guess. 4 Quote
