11 minutes ago, RXFORD said:
Boosted?  If so, is the non-return between intake and booster around the correct way?
Yeah boosted, pretty sure the arrow points towards the intake.
  • Replies 7.4k
Just now, Leone said:
thanks... im soooo average at sharpening, even after watching many vidyas on the subject.
Its fuckin eassssssssssyyyy mang, so many people over-complicate it in videos and talk like its rocket surgery.
All that matters, is that the leading(cutting) edge, is higher than the trailing, otherwise it doesn't cut, it just skates over the surface.
Start grinding at the trailing edge and roll toward leading, flicking off the leading edge quickly so it doesn't end up radiused. Flip and do other edge keeping in mind the centrepoint needs to be center.
Different angles are fun to play with, I had one recently ground by someone else really steep that I thought was going to be garbage and/or break my arm but drilled amazing. Also if you grind one edge slightly longer/angled you can make it drill slightly oversize if you need an odd ball size.
Yeah, that is why i do it.
Every.
Single.
Time.
  • Haha 3
I use the wurth bits for spotwelds. Tried one of the spikey ones first but might have just been a cheap shitty one as it blunted down pretty quick. I have found if you go slow-medium speed the wurth ones last a decent amount of time.
Bloody snapped one the other day though, dropped it when putting my tools away. Picked it up to put in the drill case and only found half of it lol.
Expensive though.
21 hours ago, Leone said:
Drilling out spot welds, what the tech?I have used the below in the past, but waste of time, figured someone has some tech...... please help
I have had decent results with these in certain situations when they are in the sweet spot they only take a few seconds.
You need a decent centre pop to keep the point in check, and quite a bit of downward pressure.
On curved surfaces they can be  PITA.
I grind an almost 90deg and back off the cutting edge leaving a sharp "bubble" in the middle, (has to be centre - so measure). It will centre without a pilot hole or centre punch  and you can drill out the spot weld without while minimising damage to the bottom panel. A 10mm drill covers most spot welds. Being a blind old bastard it took a while to get the technique right!  The drill in the pictures has done quite a bit of work and is due for a sharpen.
  • Like 9
Anyone bought alloy wheel tapered seats, the steel insert the tapered wheel nut/bolt mates to? Need to replace 4 on one wheel but dont see anywhere that sells them.
I'd wager you only own steel.cap work boots  and jandals.
So I'm gonna call fake news.
Crocs maybe?
Put your crocs Into sport mode......
  • Haha 2
I have never owned a set of crocs, nor tried a set on.
I also have hunting boots, gumboots, some snazzy dress boots i bought for a wedding a few years back, and sneakers for the treadmill i don't use.
I may also have dedicated front door and back door jandals, so i never have to wear them through the house.
Oh. And a set of steelcaps i turned into slides. Perfect for those quick trips to the shed that might end up being a long trip to the shed.
Sup team,
For coolant running through the throttle body do you think this is particularly needed in a weekend car that is unlikely to be driven much in winter?
Thanks
1 hour ago, Leone said:
Sup team,
Thanks
Nope, ditch it IMO.
8 hours ago, Leone said:
Sup team,
Thanks
I've recently done this on a 3uz. We don't need warm air... Ditched stock water fed t/b and replaced with a Bosch 82mm. Drilled/tapped & orb plugged the water pipe outlets to t/b to tidy up the front of motor.
  • Haha 1
13 hours ago, Leone said:
Sup team,
Thanks
Don't run it on my lancer, doesn't cause any issues
