Bling Posted September 2 Posted September 2 Can you strip it down to just narrow down the fan part itself? I'd 100% just use a generic one, a fan is a fan IMO. 1 Quote
ThePog Posted September 2 Posted September 2 27 minutes ago, Bling said: Can you strip it down to just narrow down the fan part itself? I'd 100% just use a generic one, a fan is a fan IMO. Yea I pulled it apart to see what the layout was, there are 2x fans that are mirrored, but I cannot find a part number for just that one. Quote
ThePog Posted September 2 Posted September 2 Actually I have just found a listing for the fans only https://www.aliexpress.com/w/wholesale-dell-7560-gpu-fan.html?spm=a2g0o.productlist.search.0 Quote
Bling Posted September 2 Posted September 2 Pricing seems better to me! I ended up with this one, but US Amazon: https://www.amazon.com.au/BestParts-Replacement-Precision-UMA-Version/dp/B0GGJFW56G And I don't know which model laptop / spec it needs to suit. But if you can source fans alone, you should be sorted. 1 Quote
Bling Posted September 2 Posted September 2 Sounds like you're sorted then. Dell won't be making their own fans, so if you find some that match i'd go for it. I had to do that for a fuel pump today, looks the same so hoping for the best. Quote
mjrstar Posted September 2 Posted September 2 Just search fleshy leaf on only fans then? 1 hour ago, ThePog said: I am quite fancying the Fleshy Leaf brand. 1 2 Quote
ajg193 Posted September 2 Posted September 2 5 hours ago, ThePog said: Its a Precision 7560 with an Nvidia RTX GPU Chances are the fans just have a plain bearing. Pull them apart, put a drop of 3 in 1 oil or similar in and they will be good for years again. 3 Quote
ThePog Posted September 2 Posted September 2 5 minutes ago, ajg193 said: Chances are the fans just have a plain bearing. Pull them apart, put a drop of 3 in 1 oil or similar in and they will be good for years again. Worth a go for sure. Quote
ThePog Posted September 4 Posted September 4 On 02/09/2026 at 21:13, ajg193 said: Chances are the fans just have a plain bearing. Pull them apart, put a drop of 3 in 1 oil or similar in and they will be good for years again. I did this and it has quietened down a fair bit. But that fan you could physically rock the moving assembly a tiny bit, which you couldn't with the other one. But at least now I have the specific fan model so have ordered one off Alix. But in the meantime it isn't screeching at me 4 Quote
h4nd Posted Monday at 03:43 Posted Monday at 03:43 I'm doing a wee PCB with some radio boards. Interestingly ,as uProcessors and peripheral devices are getting more complex and more configurable, there's less 'glue' logic and parts these days. I have just now added R31 and R32, so I get some small satisfaction from that Quote
igor Posted Tuesday at 21:16 Posted Tuesday at 21:16 Is anybody here having issues with accessing their xtra email through thunderbird today? My dad can't access his email and my very limited technical skills are not much help. Quote
igor Posted Tuesday at 22:56 Posted Tuesday at 22:56 Crisis averted. The issue seems to have been largely due to a mild case of oldgeezeritis. The program was hung up somehow, wouldn't open properly or close. When I went to restart the machine I saw it had updates pending so went "load updates and restart" and it did that and now everything just works. 1 Quote
