cletus Posted June 29 Posted June 29 1 hour ago, ThePog said: Has anybody used a pwm signal related to speed to run a dc motor through an esc to drive a mechanical speedo? heaps of early commodores with ls swaps have a magic box that does that, as theres no speedo drive on a late model commode box it is quite expensive though https://www.google.com/aclk?sa=L&ai=DChsSEwjL9tq-o6uVAxWjKYMDHWmPAEAYACICCAEQARoCc2Y&co=1&ase=2&gclid=Cj0KCQjwjIPSBhCCARIsABGyK7s0_dw-5m-mtMZLeAkT4iDqHUmuumV-8vyCa_EaDMxh4fj3Ee4USOQaAqAkEALw_wcB&cid=CAAS3gHkaI3-9OTsYmX0bbnZNRI-dd2t479miKdfmeShzEpxy366ShBUaw6rnYiI9qkxsibygbUBx8hltsoENoaD-8e4kXeSS28GD8WxAtebB6sG89YzWa_uGbUQFWbJ_15dm-nDQ-uIVVara1Cb5-TAnsxV6pqHF6u_Xo67LWg-wYoUNkW0TpxLmMo6HEV9gWaNfF8fcjUuTzEN6AqTq2PYQreLfg_5-VJBpBAUWjzUEZQnkbabuOnySuANHXIHh_fW3Lzj-oCRXTnLcIHYnvFBpxJ2Xw-Xhf7jvEr9P5Q1WHY&cce=2&category=acrcp_v1_32&sig=AOD64_2AHDBJ01Mi5_p3qd2itDdI2KFkTQ&ctype=5&q=&nis=4&ved=2ahUKEwiBhNi-o6uVAxXuSGwGHaFrJV8Q9aACKAB6BAgJEA8&adurl= Quote
ThePog Posted June 29 Posted June 29 57 minutes ago, cletus said: heaps of early commodores with ls swaps have a magic box that does that, as theres no speedo drive on a late model commode box it is quite expensive though https://www.google.com/aclk?sa=L&ai=DChsSEwjL9tq-o6uVAxWjKYMDHWmPAEAYACICCAEQARoCc2Y&co=1&ase=2&gclid=Cj0KCQjwjIPSBhCCARIsABGyK7s0_dw-5m-mtMZLeAkT4iDqHUmuumV-8vyCa_EaDMxh4fj3Ee4USOQaAqAkEALw_wcB&cid=CAAS3gHkaI3-9OTsYmX0bbnZNRI-dd2t479miKdfmeShzEpxy366ShBUaw6rnYiI9qkxsibygbUBx8hltsoENoaD-8e4kXeSS28GD8WxAtebB6sG89YzWa_uGbUQFWbJ_15dm-nDQ-uIVVara1Cb5-TAnsxV6pqHF6u_Xo67LWg-wYoUNkW0TpxLmMo6HEV9gWaNfF8fcjUuTzEN6AqTq2PYQreLfg_5-VJBpBAUWjzUEZQnkbabuOnySuANHXIHh_fW3Lzj-oCRXTnLcIHYnvFBpxJ2Xw-Xhf7jvEr9P5Q1WHY&cce=2&category=acrcp_v1_32&sig=AOD64_2AHDBJ01Mi5_p3qd2itDdI2KFkTQ&ctype=5&q=&nis=4&ved=2ahUKEwiBhNi-o6uVAxXuSGwGHaFrJV8Q9aACKAB6BAgJEA8&adurl= Do you think I am fuckin made of money? 2 Quote
tortron Posted June 29 Posted June 29 1 hour ago, yoeddynz said: use some crazy shaft size for the needle? This is easy to correct, you can enbiggen or debiggen the needle hole via watchmakers block 2 Quote
yoeddynz Posted June 29 Posted June 29 1 hour ago, cletus said: early commodores have a magic box I think Dylan will like that. 2 5 1 Quote
cubastreet Posted June 29 Posted June 29 4 hours ago, ThePog said: Has anybody used a pwm signal related to speed to run a dc motor through an esc to drive a mechanical speedo? a little stepper motor might work well for this, then use arduino/esp32 to translate the signal? Quote
ThePog Posted June 29 Posted June 29 Just now, cubastreet said: a little stepper motor might work well for this, then use arduino/esp32 to translate the signal? I have looked at this but a lot of the spec does not have the actual speed they can run at, I need about 2000rpm for my wheel size assuming the speedo signal is 1:1 Quote
cubastreet Posted June 29 Posted June 29 speedo cables are normally on a worm drive no? maybe try spinning it with a cordless drill to try? Quote
ThePog Posted June 29 Posted June 29 3 minutes ago, cubastreet said: speedo cables are normally on a worm drive no? maybe try spinning it with a cordless drill to try? It is but I am pretty sure the ratio is 1:1 on mine. I am pretty sure I checked that but I will again. Good call Quote
ThePog Posted June 29 Posted June 29 1 hour ago, tortron said: This is easy to correct, you can enbiggen or debiggen the needle hole via watchmakers block I also have hot melt 1 Quote
cletus Posted June 29 Posted June 29 i imagine @h4nd could make something like this with one eye closed Quote
h4nd Posted June 29 Posted June 29 The mech bit and motor choice is the hard bit, I can help after that 1 Quote
RUNAMUCK Posted July 1 Posted July 1 I couldn't find the 4 link design thread, so I'll post up here instead. Thinking about the back end of one of the cars I own. The guy who started building it four linked the rear. But when he sold it to the guy I got it off, he kept the 9" link bars, and coil overs . Since whichever axle I use will need to be extensively narrowed, I might as well run the mount plates which completely encircle the axle tube. I was thinking it's no biggie to have something laser cut, or plasma cut them myself. I'm literally the worst drawer who ever lived. But imagine this is a plate with an axle tube hole in the centre, and a pivot bolt top and bottom for the links. seeing what already exists in the market, I found these for sale for way too much money. You can see that this one has the pivot point where the arms attach forward of the axle centreline. Is this done to reduce the instance the arms/rod ends contacting the axle tube at the extremities of travel? Or some other rationale? (Better transmission of forward motion to the chassis, or superior ability to resist the rotational forces of the differential? You tell me????) So back to my truely incredible technical drawings, I could do a plate like this, (Yes, making one with a row of holes top and bottom would be a lot smarter. The hole options in the mounting plates on the chassis have already been drilled Assuming they're at uniform centres, the centre to centre measurements of the arm mounting holes would need to mirror this pre-ordained distance to maintain the top and bottom remaining parallel through range of motion. (But this drawing is just for the sake of trying to convey the guts of my query) So far, it's all semi straightforward. But as for the coilover mounts on the diff, (there were coil overs on the diff the builder had in there) it seems to me like these could similarly be integrated into the same bracket too. (Mounted to the rear of the axle tube) More CAD quality draughtsmanship from me, Now as this is one piece, the shock mounting ear could be sited pretty much anywhere through the 180-ish degrees on the rear side of the axle tube. Depending on the size of the bottom eye of whatever coilover was used, there could easily be a spacer (if it here narrower than the width of the ends of the link bars) or a crush tube could be employed to improve the strength. (Additionally a Brace could welded across the two plates along the bottom side to aid rigidity too. If you're still following, my two questions are, Is there an ideal offset from the axle centreline to the centreline of the link bar mounting points? (Or does this matter?) And, is there a preferred offset from the axle centreline back to the centre of the coilover mounting point? My time fucking about with cars has taught me that such things are never left to change by the OEM. And the blokes who design this shit are a fuckton clever-er than me. Ta. 1 Quote
JustHarry Posted July 1 Posted July 1 57 minutes ago, RUNAMUCK said: I couldn't find the 4 link design thread, so I'll post up here instead. Thinking about the back end of one of the cars I own. The guy who started building it four linked the rear. But when he sold it to the guy I got it off, he kept the 9" link bars, and coil overs . Since whichever axle I use will need to be extensively narrowed, I might as well run the mount plates which completely encircle the axle tube. I was thinking it's no biggie to have something laser cut, or plasma cut them myself. I'm literally the worst drawer who ever lived. But imagine this is a plate with an axle tube hole in the centre, and a pivot bolt top and bottom for the links. seeing what already exists in the market, I found these for sale for way too much money. You can see that this one has the pivot point where the arms attach forward of the axle centreline. Is this done to reduce the instance the arms/rod ends contacting the axle tube at the extremities of travel? Or some other rationale? (Better transmission of forward motion to the chassis, or superior ability to resist the rotational forces of the differential? You tell me????) So back to my truely incredible technical drawings, I could do a plate like this, (Yes, making one with a row of holes top and bottom would be a lot smarter. The hole options in the mounting plates on the chassis have already been drilled Assuming they're at uniform centres, the centre to centre measurements of the arm mounting holes would need to mirror this pre-ordained distance to maintain the top and bottom remaining parallel through range of motion. (But this drawing is just for the sake of trying to convey the guts of my query) So far, it's all semi straightforward. But as for the coilover mounts on the diff, (there were coil overs on the diff the builder had in there) it seems to me like these could similarly be integrated into the same bracket too. (Mounted to the rear of the axle tube) More CAD quality draughtsmanship from me, Now as this is one piece, the shock mounting ear could be sited pretty much anywhere through the 180-ish degrees on the rear side of the axle tube. Depending on the size of the bottom eye of whatever coilover was used, there could easily be a spacer (if it here narrower than the width of the ends of the link bars) or a crush tube could be employed to improve the strength. (Additionally a Brace could welded across the two plates along the bottom side to aid rigidity too. If you're still following, my two questions are, Is there an ideal offset from the axle centreline to the centreline of the link bar mounting points? (Or does this matter?) And, is there a preferred offset from the axle centreline back to the centre of the coilover mounting point? My time fucking about with cars has taught me that such things are never left to change by the OEM. And the blokes who design this shit are a fuckton clever-er than me. Ta. Is it worth doing a triangulated 4 link to negate the need for a watts link/ panhard bar too? Also presumably this is the datsun wagon drag car. Why not just run a ladder bar?(maybe the wrong term) to make the body and axle separate at launch Quote
Nominal Posted July 1 Posted July 1 I would put the coilovers as close as possible to the diff centreline, I think the fairly large offset is the reason the Mercury has ride quality issues. If the suspension weight loading is a long way from the coilover mounts it puts a forward loading on the upper links and pulls on the lower links (assuming it is behind the axle) 1 Quote
cletus Posted July 1 Posted July 1 You need some equivalent of Richard holdener spec youtube 4 link videos Its a big subject to get your head around and its quite interesting to learn about how the geometry of the bars affects how the car works Probably need to figure out what engine, box, tyre type, how fast you want to go, is it going to be road legal or not, etc Quote
RUNAMUCK Posted July 1 Posted July 1 I only know enough to know, there's a shitload about it that I don't know..... Although I don't recall the specifics, I did read somewhere that altering the pinion angle can improve the way the tyre grabs/improve traction. However that could have been for circuit cars? @shizzl put me onto a website called Rod ends NZ. They seem to have a lot of the stuff you wouldn't want to buy off aliexpress. I havent had anything laser cut for a long time. But those store bought plates I posted up are pretty damn spendy. 1 Quote
RUNAMUCK Posted July 1 Posted July 1 Okay a quick Google, (I don't want to learn, just give me the answers) reveals a whole heap of reading which I'll have to struggle through when it's not an hour past my bedtime. 1 Quote
shizzl Posted July 1 Posted July 1 It’s a rabbit hole. i found that once you’ve read about one thing, something else will contradict that with something else. 6 weeks later and it’s still confusing. We have a great laser cutter near home , if I drop him some chicken scratch drawings showing measurements, he will pop out some legit pro spec parts. At a fraction of the price of catalogue stuff that often doesn’t fit anyway. im just street use, so I just set my bars up to have the IC around the bumper and pinion angle perfect. lower link bar will be dead level once it’s dropped another 20mm in the rear (soon to be done). cut some concepts out of cardboard and do some chalk art showing range of movement etc. it’ll show what your pinion angle will do at different bar lengths, angles and spread. but don’t take this advice, I’m not trained or skilled in it 1 2 Quote
xsspeed Posted July 3 Posted July 3 Not sure if here or hifi thread, but has anyone put together a bench test rig for old car audio gear to run it up more than just check power comes on. I'm thinking amps hooked to speakers Google has led me to believe a qje 30 or 50 amp will do the job maybe with a battery hooked up (and maybe with an ideal diode as can't seem to find if the unit has any protection itself) 4th generation PS50SWIV vehicle base shortwave radio DC communication switching power supply 13.8V 50A https://a.aliexpress.com/_mPuPSBp Any experience? Quote
Bling Posted July 3 Posted July 3 I wired up an old PC power supply I had, put it in a box and ran a headunit with speakers etc. So unless you're talking about testing out woofers and the likes, i'd just pick up an old power supply and wire it accordingly. They have 12V power feeds and 5V feeds. So it's pretty easy to do. There are two wires you need to connect to fire it up, I think it's just a trigger and doesn't need to be a permanent connection, then away you go. Then you just used the 12V and ground wires as you would if it was a car. if that makes sense. Plenty of tutorials online these days. I don't remember exactly how I wired mine, but can try dig it out later. Quote
