RUNAMUCK Posted January 19 Posted January 19 Very little redeeming features then. Slow, thirsty, and no fruit? Quote
igor Posted January 19 Posted January 19 Yep, all of the gas hogging and no overdrive on the auto. It wasn't terrible as a family wagon though. Quote
h4nd Posted January 27 Posted January 27 Anyone know if these dots speak tensile? (From my split rims). I can only find refs like these Thanks brains Quote
HighLUX Posted February 4 Posted February 4 J160 gearbox tutuing Has anyone done the mod with the remote shifter to move it forward a bit? @Roman? Quote
HighLUX Posted February 4 Posted February 4 And is the gearbox output spline the same as a W series gearbag? Quote
Roman Posted February 4 Author Posted February 4 Yep same as w box. There are two positions on the factory box for the shifter, easy to flip it to use the front set of holes. Otherwise sq engineering etc sell kits tbat move it way forward. 1 Quote
Dudley Posted February 5 Posted February 5 5 hours ago, HighLUX said: J160 gearbox tutuing Has anyone done the mod with the remote shifter to move it forward a bit? @Roman? @kpr and @_Matt projec threads have them doing this mod  Quote
HighLUX Posted February 5 Posted February 5 Just got the gearbox and being a 1G box it already has the shifter in the forward position Guess I just offer it up to the tunnel now and see how far back it is compared to the hole for the gear stick Quote
kpr Posted February 5 Posted February 5  I hear the sq one doesn't feel amazing. as it turns it into a short shifter as well.    Quote
SOHC Posted February 7 Posted February 7 I found if you run slightly too much ignition advance it makes the engine carbon up a bit , knock back the timing and it burns really clean. Quote
kws Posted February 12 Posted February 12 Anyone got experience in building engines and balancing rod weights? Due to production changes the new rod for the Alto started at 9g heavier than the old ones. Using my balance jig I have removed about 4g off the big end which is within about 1.2g of the lightest rod, the problem is now that I need to take another 5g off the little end of the rod. There's no material to remove there, but one of the production changes was to add raised bosses in the middle of the rod with the text on it instead of being flat. Is it safe for me to take a die grinder to that raised area in the middle and try to shave it down flat (or as close as needed to get the weight within spec)? I want the rods within a gram or two of each other since the engine will regularly see about 9000rpm. Quote
kws Posted February 12 Posted February 12 9 minutes ago, kpr said: yep, thats where i would be taking it off I suppose the other question is, is it worth pissing around or should i just send it as it is now? The difference is something like 1.2% of the total weight of a rod... Quote
chris r Posted February 12 Posted February 12 7 hours ago, kws said: I suppose the other question is, is it worth pissing around or should i just send it as it is now? The difference is something like 1.2% of the total weight of a rod... I think it is worth the pissing around 3 Quote
kpr Posted February 13 Posted February 13 22 hours ago, kws said: I suppose the other question is, is it worth pissing around or should i just send it as it is now? The difference is something like 1.2% of the total weight of a rod... Yeah 5g is worth a zing.  if spinning it up to 9k 1 Quote
kws Posted February 14 Posted February 14 19 hours ago, kpr said: Yeah 5g is worth a zing.  if spinning it up to 9k I did it, took all the casting lines off the edges and zipped down the text a bit. Its now the same as rod 2, and 1.74g heavier than rod 1. Good enough. 3 1 Quote
ThePog Posted February 18 Posted February 18 This is the clutch slave off that Mk4 golf gti box I am looking at to swap into the x, does anyone know what that fluid connection type is? Quote
Beaver Posted February 18 Posted February 18 It's a quick connect style, think they are common across VAG stuff. Can get adaptors (or even make one. Man of your skills) https://www.ebay.com/itm/235164096323 1 Quote
ThePog Posted February 18 Posted February 18 15 minutes ago, Beaver said: It's a quick connect style, think they are common across VAG stuff. Can get adaptors (or even make one. Man of your skills) https://www.ebay.com/itm/235164096323 50 smackers and you are bang on the money, I'd make that myself... Quote
cubastreet Posted February 19 Posted February 19 So an update on my mate's Mercedes w203 that threw all the codes after a flat battery and wouldn't shift out of park... He found a hack to bypass the shifter lock by taking the ashtray out and jamming a screwdriver down into the gearbox and got it to the garage. They said the ABS pump module is bung and it's coded to the car so has to be repaired. They quoted $2700 to fix it, $1200 to put the broken module back in, and $700 if he wanted them to leave the module out. seems kinda pricey? 2 Quote
