On 12/07/2024 at 21:42, SOHC said:
Dose anyone know anything about Buick Dynaflow transmissions? This one seems to be stuck in L. I put it in D and its reving it's nuts off, car has been sitting for 40+ years.
I think I've got a book at work. Will check tomorrow. Other wise ring Erick at Automan Automatics. The main thing with a dynaflow is most of the gears are done on different vane pitch in the torque converter. There's 3 different types too from memory. What's it in?
  • Replies 7.3k
Its in a 1949 Super 8, it has L and D, I think L just locks the vains in one position,
@SOHCThe earliest the book I could lay my hands on is 1953. Excessive slip in drive only indicates incorrect adjustment of the manual linkage (should go from carb to valve on the size of the transmission). Or low pressure at high accumulator from a leaking gasket internally. Or stuck clutch piston check ball.
There is a chance the earlier ones have differences.
Funnily enough I've got to get the converter off a 1960 Invicta which is a mish on its own, requiring the disassembly of the converter.
Dose the book mention any vacuum line or anything? I cant find any information on this problem of be stuck in L
8 hours ago, rusty360 said:
Calling the cad gurus. I gotta draw up a grill for a tractor. Think lots of slots what technique would ya use, patterns?
What software package are ya running and possible for a pic of roughly where you want to be? could be a simple pattern or a nasty surface projection...
I have a question for the os brains trust. We have a van at work with an electric door opener, we need to fit something to pull the door handle before the opener starts to operate. The opener operates off a momentary signal from the central locking. Is there such a device that can operate a solenoid and then a few seconds later send a signal to open the door?
Get a proper automotive one, they are more likely to work in a car environment. I tried a 12v timer board from AliX, it was fine running on the car when the engine wasn't running, but didn't work right with the engine running, too much electrical noise from the ignition probably.
Was actually much easier than expected. Fusion has a great pattern tool I found.
Has anyone got any decent links to wiring pinouts for modern cars?  Trying to fit an NZ toyota radio to a JPN toyota car and can't find comprehensive pinouts for either.  It's fucking frustrating as it works for radio, but won't connect to the phone because microphone isn't connected but can't find the factory jpn wiring colours for microphone .  (Reverse camera is next)
Have you tried the12volt.com? Whilst not a Japanese site it might have a model similar enough that shares the same radio wire colours.
